srki
Najčešći problemi na forumu
U ovoj temi je objašnjejo kako rješiti neke od najleščih problema na forumu..
Trenutno su tu 2 česta problema, ali lista će se nadopunjavati ukoliko dođe do novih problema..
Ako se admini i modovi slažu , neka stave temu sticky
1. problem
Prikazivanje odgovora na temu kao popis
rješenje--> options---> switch to standard
i rješeno
2. problem
Ne prikazivanje opcija na nicku
rješenje--->na dnu ekrana prebaciti jezik sa Croatian na English
i rješeno
:bravo Riješio si me problema #2!
Inaće nigdje na internetu, mobu itd itd ne želim Croatian lang.... Englisch rulez!
Fala ti!
Ja imam problem kad hocu pogledat nove postove(View new Posts) da mi uvijek prvi put vrati ovakvu poruku:
" Board Message
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
Sorry, the board administrator has enabled search flood control. Please wait at least 20 seconds before trying again."
I onda sacekam 20 sec. i sve pet,ali to samo na mom kompu(koristim Firefox),a na poslu nemam taj problem(Internet Explorer)!
svako malo mi se pojavi slijedeci tekst....
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@vwclubcroatia.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.14 (Unix) mod_ssl/2.2.14 OpenSSL/0.9.8e-fips-rhel5 mod_bwlimited/1.4 mod_jk/1.2.25 Server at www.vwclubcroatia.com Port 80
nakon 5,6 refresha mi ponovno radi ok i onda nakon opet nekog vremena opet isto..... :rolleyes:
i meni se to isto događa....
mislim da ti je i samom jasno da je problem do postavki browsera koji koristis. nazalost, nemam ideju na koju postavku bih te uputio da je ispravis, ali pokusaj sa ciscenjem cookiea
ja isto imam taj problem ali na sreću nije često.... nisam mjenjao postavke browsera... to je počelo prije dva tri dana...
iskreno - ne vjerujem.. jucer sam dignuo windowse i stavio najnoviju mozillu.... :rolleyes:
...a opet mozda je stvarno... hmm...
Ja ne kuzim ovo...
Logiram se ( user i pass ) i stavim kvacicu na ono remember. Prolistam i odem na drugi sajt i za 15 min se vratim na forum i izlogiran sam ?!?
sta se to desava ??!!
Win7 imam ako sta znaci,
Ja ne kuzim ovo...
do tvog kompa je
meni je prije reinstalacija windowsa uvijek odlogirao
sada sam stavio novi XP i sada me nekad odlogira,nekada ostane prijavljen
probaj preko opere, mozzile ili internet explorera (ovisi sta sada koristis :palacg )
:zivio
ista stvar mi se desavala na xp-u imao mozilu ili IE.
Sad sma presao na win7 i probao u oba preglednika i isto je.
Stvarno mi vec to ide na zivce.
Ja ima win7 i imam cclener i sve zavisi kad ga očistim nekad mi ostane logiran nekad ne...
ne korisitm mozilu a u IE mi nisu upaljene opcije da cisti kad god ugasim...
i meni se to nekad dogodi ali ne cesto... pretpostavljam da je to t-coma i IP-a.... no big deal... :palacg
ja se svaki put moram ponovo logirat. vjerojatno je do kompa ali stvarno zivcira. ako ima ko kakav savjet neka pise hitno
zasto ne koristite tabove, ja kad sam na netu upaljeno mi je u komadu 10 stranica
net
index
vwclub, evo primjera!
netribas se ni odlogiravati nego dok si online si spojen i gotovo!
net
index
sve je to ljepo ali evo ti moj primjer. laptop + bezicni internet(usb stick). da imam obican komp vjerojatno ga nebi ni gasio ni odspajao sa neta ali u ovoj situaciji mi bas nije u interesu da mi je stalno na punjacu ili jos bolje da je stalno spojen na net(racun bi bio uhuhuhuu). znaci svaki put(dan) kad otvorim vwcc upisujem nick i password. dojadi nakon nekog vremena
net
index
POTPIS! :rolleyes:
pa cim krenes upisivati email jeli ti doli odma izbaci tvoj email kao vec gotov i napisan tj. kao soluciju?
ako je nebi tribalo biti frke sa rememberom!
meni radi bez problema!
@ john- pa koji preglednik koristis?
ja na operi npr ctrl+enter i logira se
1. problem
Nemogu pronaći taj "options"...a sljep sam
