limp19 6 Posted September 14, 2015 Oba strane dolaze sa desna Share this post Link to post Share on other sites
markol5 15 Posted September 14, 2015 To ti je 15min posla,tako ces se mucit bzvz. Tesko je,al probaj ti ako mislis da mores. Share this post Link to post Share on other sites
tommek10 7 Posted September 14, 2015 Budem probao malo kopkat s zicom mozda upecam sto.... ako ne onda cemo skidat branik :-/ Share this post Link to post Share on other sites
tommek10 7 Posted September 15, 2015 Rijesio sam problem ali nisam uspuo skroz skinuti branik.... skinuo sam kod svakog kotaca po 3 sarafa, ispod branika 2 sarafa, ispod farova po 3 komada na svakoj strani i vise nisam nasao ali se drzao jos kao da ima negdje jos sarafa. Uglavnom nalo je olabavio pa sam uspio zavuci ruku ispod i napipati zicu i provuci je natrag. Uglavnom rijesio :-) al da je jednostavno skinuti za nekog prvi put i nije bas Share this post Link to post Share on other sites
markol5 15 Posted September 15, 2015 Imas po jedan na svakoj strani di se spaja branik i stup di ti je rezervoar,mozda nisi te odvio. Ili ga nisi izvuka iz kopci na koje sjedne. Nek si rijesio problem Share this post Link to post Share on other sites
RI VW 4 Posted September 15, 2015 Imao isti problem, skinuo branik i vratio nazad, najjednostavnija opcija... Share this post Link to post Share on other sites
gangxxxta 0 Posted November 18, 2015 Golf mkv ima ko kakvu preporuku jer nista ne oem ne traje dulje od mj dana ?! Hvala Golf mkv ima ko kakvu preporuku jer nista ne oem ne traje dulje od mj dana ?! Hvala Share this post Link to post Share on other sites
tommek10 7 Posted November 18, 2015 Ja sam uzeo s ebay-a 20$ rade bez greske i lijepo sijaju. Share this post Link to post Share on other sites
alen_gti 0 Posted November 18, 2015 tommek moze link Share this post Link to post Share on other sites
Lycan 0 Posted November 19, 2015 http://www.ebay.com/itm/2x-OEM-VW-GOLF-PASSAT-SCIROCCO-SEAT-LED-license-plate-lights-1K8943021-C-/271497461648?hash=item3f36827f90:g:VIsAAOxy7vJTehEm Ja uzo ove, malo je veca cijena al su brzo tu:) Share this post Link to post Share on other sites
tommek10 7 Posted November 19, 2015 http://www.ebay.com/itm/LED-License-Plate-Light-Volkswagen-VW-Golf-GTi-MK4-MK5-/180549624869?hash=item2a0998a425 za tjedan dana su dosle i ja prezadovoljan Share this post Link to post Share on other sites
gangxxxta 0 Posted November 19, 2015 mene muci sto imam kameru na mjestu osvjetljenja pa mi treba neka 36 mm cjevasta ledica sta ce uci u kuciste kamere Share this post Link to post Share on other sites
svirex 0 Posted November 19, 2015 http://www.ebay.com/itm/2x-OEM-VW-GOLF-PASSAT-SCIROCCO-SEAT-LED-license-plate-lights-1K8943021-C-/271497461648?hash=item3f36827f90:g:VIsAAOxy7vJTehEm Ja uzo ove, malo je veca cijena al su brzo tu:) Planiram uzeti ovakve samo me zanima jel se ove samo ukopcaju u djek kad se skinu stara kucista netrebaju nikakvi adapteri i sl. ? Share this post Link to post Share on other sites
Lycan 0 Posted November 19, 2015 Planiram uzeti ovakve samo me zanima jel se ove samo ukopcaju u djek kad se skinu stara kucista netrebaju nikakvi adapteri i sl. ? Ove su ajmo rec original schema, meni osobno izgledaju identicne ko OEM. Sad dal su kopija ili ne nebi znao. Ali za svaki slucaj prije nego narucis te ledice provjeri iza dal imas cijevaste zaruljice , onda ova konverzija ti je samo istekaj ustekaj i amen. A ako imas sada na autu t10 zaruljice , onda ti nece ove pasat. Trebo bi mjenjat konektore na autu. Share this post Link to post Share on other sites
projektilski 274 Posted November 19, 2015 Ako su festoon, ove ledice meni rade vec cetvrtu godinu na Passat B6 http://www.ebay.com/itm/2x-36mm-White-SMD-LED-Festoon-BMW-Bulb-Light-No-ERROR-S-/200485991877?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eade575c5 Share this post Link to post Share on other sites
VWedran5 0 Posted November 19, 2015 Ja sam sebi na MK5 stavio OEM i prezadovoljan prije toga imao ovakve svijetlile odlicno cisto bijelo i bez problema 6mj samo su mi prejake bile. Share this post Link to post Share on other sites
gangxxxta 0 Posted November 20, 2015 meni su se te "pregrijavale" tipa radi 15 min pa se ugasi nakon nekog vremena se opet upali i tako u krug, ali sta je je svijetle nenormalno jako Share this post Link to post Share on other sites
svirex 0 Posted November 20, 2015 Uzimao sam i ja svakakve ali mi nijedne nisu radile duze od 3-4 mjeseca i pocnu titrati a ne prikazuju gresku. Narucivao sam i ove kao kod kolege tommek10 sa ebaya u vise navrata ali jos nikad nisu dosle. Sad su mi izletile ove kao oem sa oznakom 1k8 943 021 B dodju u orig. kutijama bez ikakvi kablova znaci samo kucista sa ledicama. Buni me ta oznaka B, C... jel sve pasu na golfa 5 jel to to, odgovara li prikljucak? Share this post Link to post Share on other sites
VWedran5 0 Posted November 20, 2015 Meni se cini da su kod mene sa C oznakom, javljale su gresku pa sam morao otpornik stavit ni kodiranje nije pomoglo. Share this post Link to post Share on other sites
svirex 0 Posted November 20, 2015 E to me buni pa mi se ne kupuju dok ne budem siguran da li odgovaraju?! I moraju li imati one adaptere i one kablove sa otpornikom? Share this post Link to post Share on other sites
VWedran5 0 Posted November 20, 2015 Konektor ti sam po sebi pase bez ikakvih adaptera smo je problem ako ti bude gresku javljalo jer onda nakon sto javi gresku ugasi LEDice i trebaju otpornici. Share this post Link to post Share on other sites
Leic 2 Posted November 20, 2015 Kakve vi to original imate na Golf 5 a da bacaju gresku???? Share this post Link to post Share on other sites
svirex 0 Posted November 20, 2015 Moze se desiti da ove PRC prijavljuju al mi nije jasno otkud bi orig. prijavljivale gresku ?! Share this post Link to post Share on other sites
projektilski 274 Posted November 20, 2015 (edited) A zasto ne bi prijavljivale ako CECM ne poznaje taj led modul? Kazem vam da one iz mog linka meni vec cetvrtu godinu rade ok, bez ikakvog kodiranja. Mislim da je sa novim CECM moguce bas iskodirati da se radi o LED osvijetljenju tablica i to onda radi, a na starijim modulima treba ugasiti Cold diagnose for licensce plate no za to nisam siguran da pomaze. Budem provjerio na svom, gdje imam vec novi CECM pa da vidimo sto kaze VCDS. Edited November 20, 2015 by projektilski Share this post Link to post Share on other sites
Leic 2 Posted November 20, 2015 (edited) Original Led na golf 5 ne bacaju gresku. Bez ikakvog kodiranja, bez otpornika bez kurca bez palca. Istekaju se stare i ove ustekaju, i naravno moraju bit ustekane obje. Isto vrijedi i za Passat b6 Edited November 20, 2015 by Leic Share this post Link to post Share on other sites
