Hrvoje Lovric 0 Posted August 14, 2013 Pozdrav ekipa da vas pitam Sve znam u vezi tempomata za golfa 3 Al jedno me zanima gdje tocno se usteka kabel u osiguracku kutiju Nebi tio trazit jer ima milion kabela pa da nesto nepokvarim ako neko zna neka napise Ili neka slika Share this post Link to post Share on other sites
said 3 Posted August 14, 2013 (edited) mozda ti ovo pomogne http://www.a2resource.com/electrical/CE2.html uglavnom, nemas sta pokidat, krivo ne mozes ustekat, jer je svaki utikac drugaciji Edited August 14, 2013 by said Share this post Link to post Share on other sites
Hrvoje Lovric 0 Posted August 14, 2013 Hvala na pomoci Nasa sam dole kraj kutije osigurača utikač koji pase valjda je dobro, kad ga spojim na vag com sve cu znat Share this post Link to post Share on other sites
ToZa 0 Posted July 5, 2014 sorry kaj dizem staru temu,ali planiram kupiti MK3 sa benzinskim motorom i gotovo full opremom za dijelove. Najzanimljivija stvar na njemu je tempomat. Dali se moze bez problema pripasati na moj MK3 1.9tdi AFN? Share this post Link to post Share on other sites
said 3 Posted July 5, 2014 ne znam bas jer je na tdi-u elektricni gas Share this post Link to post Share on other sites
GTi_G60 0 Posted July 5, 2014 moze, zato sta od cilog toga tempomata sa benzinca ti triba samo kabel koji ide sa rucice na instalaciju. (4 zice, 2 spoja) Share this post Link to post Share on other sites
said 3 Posted July 6, 2014 (edited) pa onda je to ista rucica za benzinca i tdi-a? mislio sam da na benzincima radi na neki drugi nacin Edited July 6, 2014 by said Share this post Link to post Share on other sites
ToZa 0 Posted July 6, 2014 Sjajno,hvala na odgovorima. Danas cu zvat lika za auto,pa se dogovorit za kupnju Share this post Link to post Share on other sites
DeMit 0906M 0 Posted July 6, 2014 dali je netko stavljao naknadno tempomat na golfa 5 ?! gledao sam na ebayu.. Share this post Link to post Share on other sites
GTi_G60 0 Posted July 6, 2014 pa onda je to ista rucica za benzinca i tdi-a? mislio sam da na benzincima radi na neki drugi nacin ista je rucica, i isti kabel ide sa nje. samo kod benzinaca sa gasom na sajlu ima nekih komplikacija oko pedala (vakuma i struje), koji su za tdi nepotrebni Share this post Link to post Share on other sites
said 3 Posted July 6, 2014 hmmmm sad mi se motaju neke ideje po glavi Share this post Link to post Share on other sites
TROJKA 2 Posted July 6, 2014 Hhhhhhh .i. Elektricar Share this post Link to post Share on other sites
Passat 0 Posted July 12, 2014 (edited) Ja imam kod sebe od VR-a nekog amera rucicu za tempomat na TDI -u i sve pase. Edited July 12, 2014 by Passat Share this post Link to post Share on other sites
ToZa 0 Posted July 12, 2014 dok sam se ja sjetio zvat za auto,lik ga je naravno prodao mislio sam iskoristit tempomat,farove,maglenke,felge,radio i jos mozda neke sitnice,a ostao prodat http://www.njuskalo.hr/auti/vw-golf-iii-gt-oglas-11717275 Share this post Link to post Share on other sites
RatZ 0 Posted July 19, 2014 (edited) pozdrav ja imam seat toleda 1.9tdi 66kw , posto je to golf trica sa drugaciom karoseriom ,sad citam o tempomatu i napalili ste me , jeli pase na toleda , kod mene je full oprema bez koze, sta trebam provjerit da vidim ima li moj sejo pripremu za tempomat? Edited July 19, 2014 by RatZ Share this post Link to post Share on other sites
Passat 0 Posted July 20, 2014 Nać konektor dolje kod osiguraća sa 4 žice koji nije iskorišten. I kad se prišteka ručica treba u ECU upisat putem dijagnostike kod za aktiviranje tempomata. Share this post Link to post Share on other sites
RatZ 0 Posted July 21, 2014 Sejo ima taj konektor, tj ima jos nekakvih , moze li ko slikat taj konektor pa da vidim jeli to taj? Share this post Link to post Share on other sites
Tolic 0 Posted July 24, 2014 imaš 4 žice, jedini konektor koji ima ovaj raspored boja zica:bijela, crvena, plava, crna. Share this post Link to post Share on other sites
ToZa 0 Posted September 10, 2014 moze, zato sta od cilog toga tempomata sa benzinca ti triba samo kabel koji ide sa rucice na instalaciju. (4 zice, 2 spoja) Nać konektor dolje kod osiguraća sa 4 žice koji nije iskorišten. I kad se prišteka ručica treba u ECU upisat putem dijagnostike kod za aktiviranje tempomata. evo,nabavio sam si OEM ruckicu za tempomat s konektorom(Ebay) Sada je samo treba instalirati,ukopcati u osiguracku kutiju i u ECU aktivirati putem dijagnostike? Share this post Link to post Share on other sites
said 3 Posted September 10, 2014 (edited) fali ti kabal jos ili ga imas a nema ga na slici? da to onda samo spojis i preko dijagnostike ga aktiviras kod je : 11463 i to ce ti morat netko s boljim kablom za dijagnostiku jer oni jeftini sto samo citaju greske to ne mogu Edited September 10, 2014 by said Share this post Link to post Share on other sites
ToZa 0 Posted September 11, 2014 mislis na ovaj kabel na slici koj se spojen s ruckom? ili je potreban jos neki? Di bi bilo najbolje ici na dijagnostiku za to? Hvala Share this post Link to post Share on other sites
Passat 0 Posted September 11, 2014 (edited) Fali ti kabal od tog konektora na ručki do osiguračke kutije. Probaj ako ti neko od frendova ima dijagnostiku. Ja sam uspio upisat kod sa čunga-lunga dijagnostikom. Sam ne nasjedaj na one fore da to košta 100 kn i da je komplicirano. 30 sec posla. Edited September 11, 2014 by Passat Share this post Link to post Share on other sites
said 3 Posted September 11, 2014 Passat ti je sve rekao nabavi si taj kabal jos.... Vidis ja nisam uspio imam dijagnostiku i kabal koji samo cita i brise greske al to nisam mogao s njim odraditi Share this post Link to post Share on other sites
ToZa 0 Posted September 11, 2014 ok,dal znate kak se "sluzbeno" zove taj kabel? da ga znam potraziti na Ebayu,otpadu,ili ak je neka sica u ducanu hvala svima na trudu Share this post Link to post Share on other sites
said 3 Posted September 12, 2014 (edited) ...krivo sam pisao o krivom kablu Pa pogledaj u ovlastenom mozda ipak nije skup...sad kako se to zove tocno ne znam Edited September 12, 2014 by said Share this post Link to post Share on other sites
