projektilski 274 Posted September 6, 2014 Aloha, Gdje mogu naci torx t20 sarafe za vw? Naime T25 ima, i vidim da ima je kataloski N90775001 ali T20 koji su u kabini nemrem nigdje naci... Share this post Link to post Share on other sites
MarkoTDI 0 Posted September 6, 2014 Prepostavljam Bauhaus... Share this post Link to post Share on other sites
projektilski 274 Posted September 6, 2014 Nekak sumnjam da u Bauhausu imaju te vag specificne sa sirokom glavom i t20... Ali da mozda danas odem samo bacit pogled... Share this post Link to post Share on other sites
Guest Laky Posted September 6, 2014 Pogledam ja navecer doma pa ti javim Share this post Link to post Share on other sites
DumiG4 0 Posted September 6, 2014 gledao sam ja u bauhausu prije par mjeseci i nije bilo. Share this post Link to post Share on other sites
AUTOFREAK 217 Posted September 6, 2014 Ovlasteni servis... gdje je komad koji pricvrscuju tu su i oni... Share this post Link to post Share on other sites
projektilski 274 Posted September 6, 2014 Ma da ok, znam za ovlasteni, imat ce i moj mehanicar ali volio bi saznati kataloski i zasto ga nema na google Share this post Link to post Share on other sites
Guest Laky Posted September 6, 2014 (edited) Daj reci koliko komada trebas? Pogledas u Etki bilo koji dio armature i mora ti bit vijak i kataloski broj Edited September 6, 2014 by Laky Share this post Link to post Share on other sites
AUTOFREAK 217 Posted September 7, 2014 To i ja govorim... gdje je dio tu su i oni i vidis kataloski... Narucis u ovl i miran. 25ica i 20tka cesto imaju isti navoj sto se tice takvih namjena Share this post Link to post Share on other sites
projektilski 274 Posted September 7, 2014 (edited) Daj reci koliko komada trebas? Pogledas u Etki bilo koji dio armature i mora ti bit vijak i kataloski broj Mislim da sam probal i tako i nista, sto me bas iznenadilo. Ajde, mozda po tko zna koji puta nisam dobro napravio domacu zadacu. Ako nadjem koji je kataloski, javim. Evo ga, cini se da je: N90698606 Edited September 7, 2014 by projektilski Share this post Link to post Share on other sites
AUTOFREAK 217 Posted September 7, 2014 Taj saraf pod tim brojem je 95lipa komad u ovlastenom.... Share this post Link to post Share on other sites
projektilski 274 Posted September 8, 2014 Da i ja vidjeh kad sam ga nasao u Etki ali jos uvijek nisam siguran dal je to taj. Bum izmjerio i narucio ako su to ti. Share this post Link to post Share on other sites
jady 5 Posted September 8, 2014 baumax.... kupio set jer su meni par falili...mislim nekih 100kn bilo. Share this post Link to post Share on other sites
projektilski 274 Posted September 8, 2014 Bum pogledal i u baumaxu ako ima kakav komplet razlicitih a da m pase. No ovlasteni mi se cini najbolji za to i cim zmjerim te u kabini one za branike, narucit cu si x komada. Share this post Link to post Share on other sites
Guest Laky Posted September 8, 2014 Mislim da ti je bolje u servisu narucit ako ih nemaju. Nije neka velika cijena Share this post Link to post Share on other sites
jady 5 Posted September 9, 2014 to je spec.alat kojeg placas ko suho zlato i nemogu ga za daljnu prodaju niti naruciti Share this post Link to post Share on other sites
projektilski 274 Posted September 9, 2014 to je spec.alat kojeg placas ko suho zlato i nemogu ga za daljnu prodaju niti naruciti ) Ne rugati se, nema nista lose u tome da sam htio saznati koji je to kataloski broj Share this post Link to post Share on other sites
Guest Laky Posted September 9, 2014 to je spec.alat kojeg placas ko suho zlato i nemogu ga za daljnu prodaju niti naruciti Na koji alat mislis? Share this post Link to post Share on other sites
projektilski 274 Posted September 10, 2014 Mislim da se malo zekao sa nama, kao radim dramu oko obicnih sarafa - sto je zapravo djelomicno i istina. Prokleta kisa, nis ne mogu raditi na autu... Share this post Link to post Share on other sites
Guest Laky Posted September 10, 2014 kod mene ista stvar, plus sto mi curi voda jer nisam stigao vrata slozit Share this post Link to post Share on other sites
jady 5 Posted September 10, 2014 Na koji alat mislis? na torx sa štiftom u sredini.... moji dečki ga duže kao spec.alat... Share this post Link to post Share on other sites
Guest Laky Posted September 10, 2014 pricas o sarafu ili kljucu za sarafe sa stiftom? takav torx kljuc za te sarafe sa stiftom u sredini mozes kupit u ducanu alata ja mislim na najobicnije sarafe koji drze radio, masku oko table itd Share this post Link to post Share on other sites
Jankkec 0 Posted September 10, 2014 Probaj iza karting staze u španskom http://www.imbus.hr/ Oni imaju specijalnih šrafa svih vrsta. Share this post Link to post Share on other sites
jady 5 Posted September 10, 2014 ja cijelo vrijeme citam da alat treba.... Share this post Link to post Share on other sites
tommek10 7 Posted September 8, 2018 Podizem temu iz mrtvih... gdje se moze povoljno naci torx set sa 5 zvjezdica i rupom u sredini, to su kao sigurnosni neki. Gledao sam po ebay i slicno dosta skupi a takvi ne trebaju bas za svakodnevnu upotrebu pa i ne trebaju biti profi. Share this post Link to post Share on other sites
