u2boy4ever 0 Posted May 20, 2015 passat b6 se guši iznad 2500 obrtaja,kao da je u limp modu, pogotovo uzbrdo nijedna lampa ne svijetli evo diagnostike Wednesday,20,May,2015,17:50:01:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WVWZZZ3CZ6P154227 License Plate: 553AAQ Mileage: 218450km-135738mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C (3C0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D VIN: WVWZZZ3CZ6P154227 Mileage: 218450km/135738miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 03G 906 018 EJ HW: 03G 906 018 CH Component: R4 2.0l PPD1.5 G 9633 Revision: --H05--- Serial number: VWZCZ000000000 Coding: 0000072 Shop #: WSC 06958 995 88324 VCID: 71E9334F685CC1966BD-8024 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb Part No SW: 3C0 614 095 P HW: 3C0 614 095 P Component: ESP 440 C2 H015 0003 Revision: H015 Serial number: 0658581127 Coding: 0013581 Shop #: WSC 08250 995 90517 VCID: 2F6DF537BEE897663D9-807A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA Component: ClimatronicPQ46 050 0404 Revision: 00050005 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 60CF460BB3B6781EF43-8035 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 J HW: 3C0 937 049 J Component: Bordnetz-SG H37 1301 Revision: 00H37000 Serial number: 00000003751260 Coding: A1800F0700041A00000A00000F00000000095D435C0000 Shop #: WSC 00028 028 00001 VCID: 306FF64BA3D6889E243-8065 Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB Component: Wischer VW461 001 0101 Coding: 00063445 Shop #: WSC 00028 3 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 2 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 11.95 V ON ON OFF OFF OFF 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 12.00 V ON ON OFF OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 12.05 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 J HW: 3C0 909 605 J Component: 04 AIRBAG VW8 029 2521 Revision: 09029000 Serial number: 003A2PRXLWUB Coding: 0012340 Shop #: WSC 00028 028 00001 VCID: 2D51EF3FB4E4E5760F5-8078 Subsystem 1 - Serial number: 6332MSME0D71380E Subsystem 2 - Serial number: 6342MSME0D41425B Subsystem 3 - Serial number: 6351HTS61IK6MKJ2 Subsystem 4 - Serial number: 6361HTS61IK6AJJ2 Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 A HW: 3C0 953 549 A Component: Lenksäulenmodul 005 0010 Revision: 00005000 Serial number: 3C5953507B Coding: 0000011 Shop #: WSC 00028 028 00001 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 851 M HW: 3C0 920 851 M Component: KOMBIINSTRUMENT VD1 4242 Revision: V0042000 Serial number: 00000000000000 Coding: 0002103 Shop #: WSC 69550 995 93882 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C05C140685 Coding: 3DFD2C04C21002 Shop #: WSC 00028 028 00001 VCID: 2149030FF83C3116BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 M HW: 3C0 959 433 M Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 03009 425 94161 VCID: 3467FA5B57CEB4BE40B-8061 Subsystem 1 - Part No: 3C0 905 861 H Component: ELV 028 0380 3C0905861H ELV 028 0380 1 Fault Found: 02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 170 Mileage: 215885 km Time Indication: 0 Date: 2000.00.00 Time: 13:19:30 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2365 Coding: 0000181 Shop #: WSC 00028 028 00001 VCID: 3663C05341B2A6AE7EF-8063 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 M HW: 3C0 959 433 M Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 00910A0801860E76300416177008CF0B603CA0 Shop #: WSC 03009 425 94161 VCID: 3467FA5B57CEB4BE40B-8061 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2365 Coding: 0000180 Shop #: WSC 00028 028 00001 VCID: 377DCD5746B85FA6659-8062 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000011 Shop #: WSC 08250 995 90517 VCID: 2149030FF83C3116BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No: 1K0 035 186 P Component: Radio GR0 015 0019 Revision: 0001503S Serial number: VWZ2Z2E3302972 Coding: 0020202 Shop #: WSC 00028 028 00001 VCID: 3365F94752C0B386591-8066 1 Fault Found: 00857 - CD Changer Unit (R41) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 3467FA5B57CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D51EF3FB4E4E5760F5-8078 No fault code found. End --------------------------------------------------------------------- Share this post Link to post Share on other sites
