marioST 0 Posted May 25, 2015 Pozdrav.imam golf 6 highline 1.6tdi pa me zanima kako znati jel mi na autu serijala ovjes ili je spusten 15mm kao sportski..imam u planu stavljati vece felge pa zato Share this post Link to post Share on other sites
MarioIV 11 Posted May 25, 2015 ako su 16 nemas ako su 17 original onda imas sport podvozje -15mm Share this post Link to post Share on other sites
RI VW 4 Posted May 25, 2015 Odes u ovlasteni i vidis po broju sasije Share this post Link to post Share on other sites
marioST 0 Posted May 25, 2015 16ke su..znaci ipak je normalan ovjes.. Share this post Link to post Share on other sites
RI VW 4 Posted May 25, 2015 Neznam kako na sestici ali na petici bez obzira na felge svi sportline su 15 mm spusteni Share this post Link to post Share on other sites
MarioIV 11 Posted May 25, 2015 zato sto je sportline oprema znacila -15mm a sad su promjenili na highline i ubacili 15mm na 17 sport paket a na 18 sport paket ide 20mm Share this post Link to post Share on other sites
marioST 0 Posted May 25, 2015 U mene je isto highline.a u papirima mi ima samo upisano 15 i 16 cola felge.. eto nadam se da vidite Share this post Link to post Share on other sites
tihca 0 Posted May 25, 2015 meni se čini da je normalan ovjes,ništa niži...ja sam sebi stavio Eibach Sportline opruge i udobnost je ostala 95% ista na 16"gumama,a spusti ti ga oko 5cm ako ti nije previše Share this post Link to post Share on other sites
marioST 0 Posted May 25, 2015 Ma isao bi na 17ke od vw PORTO.. nebi ga tia spustat..cisto bi malo da vise dode do izrazaja auto.. Share this post Link to post Share on other sites
marioST 0 Posted May 25, 2015 Evo ova 2 auta.meni skroz ok izgledaju sa ovim felgama..a najvise mi je jesu li iste visine kao i moj auto Share this post Link to post Share on other sites
MarioIV 11 Posted May 25, 2015 to na slici je sa sport ovjesom Share this post Link to post Share on other sites
marioST 0 Posted May 25, 2015 A nemogu nigdi nac je nornalan ovjes.. Share this post Link to post Share on other sites
bruiser 0 Posted May 25, 2015 Stavit ces gewinde kad tad Share this post Link to post Share on other sites
AUTOFREAK 217 Posted May 25, 2015 bitno da nije 1.4tsi pa imat ce kad mislit na ovjes Share this post Link to post Share on other sites
boko123 0 Posted May 26, 2015 U mene je isto highline.a u papirima mi ima samo upisano 15 i 16 cola felge.. eto nadam se da vidite Slicnu problematiku imam ovih dana. Kod mene je highline sa 18 tockovima,a izgleda mi da je kao traktor visok.Nesto mi sumnjivo da su kod mene sportline opruge. Da li mozes da vidis koliko tacno imas od centra tocka do ruba,kako napred tako i nazad? Share this post Link to post Share on other sites
marioST 0 Posted May 28, 2015 37.2 sprijeda i 38cm straga..s tim da nije auto bilo na skroz ravnom terenu..miria sam od sredine plasticnog vw cepa sa felge do blatobrana Share this post Link to post Share on other sites
ljubobj 103 Posted May 28, 2015 Pa ne mjeri se tako ili od poda do blatobrana ili od gume do blatobrana Share this post Link to post Share on other sites
boko123 0 Posted May 28, 2015 marioST Hvala,sutra cu da pogledam koliko je kod mene. @ljuboj izvini ali nisi u pravu,jedino ispravno je od sredine tocka,jer se tako eliminise efekat ralicite velicine tockova,kao i potrosenost guma. Share this post Link to post Share on other sites
marioST 0 Posted May 28, 2015 Moze..i poslikaj da vidim kako u tebe izgleda na 18" Share this post Link to post Share on other sites
ljubobj 103 Posted May 29, 2015 (edited) Moj je sputen eibach pro kit -30mm Naprijed je 35cm i iza je 35cm Edited May 29, 2015 by ljubobj Share this post Link to post Share on other sites
marioST 0 Posted May 29, 2015 Moj je sputen eibach pro kit -30mm Naprijed je 35cm i iza je 35cm Mozes slikat auto? Share this post Link to post Share on other sites
ljubobj 103 Posted May 29, 2015 Evo kolega tu sam u temu stavio slike nedavno http://www.vwclubcroatia.com/forum/index.php?/topic/83008-udobnost-tvrdoca-sportskih-opruga-h-r-eibach/page-8 Share this post Link to post Share on other sites
gorup 0 Posted May 30, 2015 Znaci eibach pro kit i sportline ne promjene udobnost jako? Koje jos opruge su takve kaj se tice udobnosti a da spuste 3-4 cm? Share this post Link to post Share on other sites
ljubobj 103 Posted May 30, 2015 H&R su isto odlicne Share this post Link to post Share on other sites
marioST 0 Posted June 10, 2015 Nasao sam opruge od golf 6 1.4tsi.. samo me zanima jeli svaki tsi imao sportski ovjes i po cemu se moze razlikovat opruga od sportskog ovjesa ili kao u mene normalnoga. Share this post Link to post Share on other sites
