gangxxxta 0 Posted August 4, 2015 Dal je isti ovjes mk5 i mk6 tipa gewinde s 1.9 tdi 50 mm prihvat na mk6 1.6 tdi 105 konja Share this post Link to post Share on other sites
D.M 0 Posted August 5, 2015 @ Ivo_022 -koje imas amortizere? Share this post Link to post Share on other sites
marioST 0 Posted August 5, 2015 Mislim da nema potrebe za prokit stavljat tvrde amortizere..ka stavsam i napisa auto je priko rupa 10x bolje i mekse na eibavh nego na stock..veliki lezeci malo stvore problem al dobro je to sve Share this post Link to post Share on other sites
Ivo_022 1 Posted August 6, 2015 @ Ivo_022 -koje imas amortizere? Bilstein B8 sa Pro Kit -30. (B12 Pro Kit) Share this post Link to post Share on other sites
D.M 0 Posted August 6, 2015 Znaci,dobitna kombinacija,hvala na odg B-) Share this post Link to post Share on other sites
marioST 0 Posted August 27, 2015 Moze mi neko rec jesu ovo tocne opruge za golf 6 1.6tdi.. Share this post Link to post Share on other sites
MarioIV 11 Posted August 27, 2015 prepisi kod ... ja nesto i ne vidim Share this post Link to post Share on other sites
marioST 0 Posted August 27, 2015 Prednje 1500702va a zadnje 8501405ha Share this post Link to post Share on other sites
Ivo_022 1 Posted August 27, 2015 Nisu, za Golf V su Share this post Link to post Share on other sites
marioST 0 Posted August 27, 2015 Jel moguce da mi auto poskakuje preko neravnina radi toga..ta tezina za opruge. Share this post Link to post Share on other sites
Ivo_022 1 Posted August 27, 2015 Ove koje ti imaš imaju nosivost: 1150kg naprijed 1010kg straga, dok za Golf VI Pro Kit ima manju nosivost. Straga 940kg, a prednje imaju do 1010kg, i teža varijanta (kao tvoje) do 1120kg. Poskakivao bi on i na federima za G6. Ne može standardni amortizer umiriti 20-25% jače sile. Share this post Link to post Share on other sites
MarioIV 11 Posted August 28, 2015 Ja sam isto mislio Eibach ali koliko vidim samo problemi Nista, ja opet H&R gledam ... znam da su odlicne na serijskim amortizerima Share this post Link to post Share on other sites
marioST 0 Posted August 28, 2015 Steta sta neznam nekog iz st ko ima g6 spustenu pa da bas provozam.. Share this post Link to post Share on other sites
marioST 0 Posted August 28, 2015 A prednji kraj se super ponasa preko rupa i lezecih..a zadnji vjerovatno poskoci kako je lagan i tvrda opruga..mozda da je stavit neku originalnu samo da se mekoca neka dobije Share this post Link to post Share on other sites
polic na kvadrat 46 Posted April 11, 2018 Dižem temu ali trebam pomoć u vezi ovjesa tj stražnjih opruga za Golf 6 karavan. Pukla mi je jedna opruga i sada moram uzeti druge ali me brine kvaliteta istih tj nude mi Sachs i Lesjöfors opruge kao zamjena za Oem a priča se da sve te opruge iz iste tvornice izlaze kao i Kilen a te Kilen sam imao na VW polu 6n2 stražnje i popustile su nakon cca 6 godina tj bile niže cca 2cm nego što bi trebale biti...Dali je ovo sa slike ok ili Kayaba? kad danas svatko sve radi samo se brand otisne na proizvod.... Da ovjes je Oem ništa spuštano.... Poslano sa mog SM-A510F koristeći Tapatalk Share this post Link to post Share on other sites
G2 LTD 37 Posted April 11, 2018 Meni je Puks rekao da je Kayaba i Suplex koji cu staviti za zadnje slicna stvar. Tako da cu ic na varijatnu Kayaba naprijed ( njihovi amortizeri su mi se super pokazali ) i Suplex pojacani nazad. S eibachom sigurno neces pogrijesiti. Share this post Link to post Share on other sites
<TDI> 414 Posted April 12, 2018 (edited) Negdje sam naletio na info da je Kayaba OEM ili zamjena za OEM, a sad ga znaj. Edited April 12, 2018 by <TDI> Share this post Link to post Share on other sites
marioGt 2 Posted April 12, 2018 Kyb stavi RA6241 s nekim rabatom bu ti oko 500kn obje i miran si Share this post Link to post Share on other sites
polic na kvadrat 46 Posted April 12, 2018 Kyb stavi RA6241 s nekim rabatom bu ti oko 500kn obje i miran siGovoriš iz iskustva ili?Može i u inbox di da uzmem.. Bitno mi je da bude sve kako je i bilo i da s vremenom opruge ne sjednu da budu slabe itd... Iskreno neznam dali je auto tvornički spusten jer ona plastika bi mi i prije znala zastrugati na lezecem policajcu ako bi imao 5 osoba a sada baš moram paziti ako sam pun jer bas struze jako kako je pukla ta opruga... a dok je prazan ta strana je niža 4mm mislim smješno.... Poslano sa mog SM-A510F koristeći Tapatalk Share this post Link to post Share on other sites
