Analogic 0 Posted January 9, 2017 Pozdrav, odnedavno sam postao vlasnik Passata B7 2012 godina. Jedan kljuc nije radio jer se baterija istrosila. Nakon sto sam zamjenuo bateriju otkljucavanje dodirom na bravu i keyless start rade al nerade mi tipke na daljinskom za zakljucavanje i otkljucavanje . ako netko zna kako da to programiram ponovno svaka pomoc je dobrodosla. Hvala unaprije. Share this post Link to post Share on other sites
Mouse-RI 3 Posted January 9, 2017 Ja sam na polu programirao ovako: Trebaju ti 2 kljuca Manual Programming 1) Unlock the door to your car using the key blade 2) Insert your old key blade into the ignition and turn it to the "on" position, but do not start the car. 3) Roll down your driver's side window 4) Step out of the car and insert your new key into the driver's door lock, now turn the key to the left and hold it in that position for 10 seconds. 5) Now press the lock button on the FOB 6) Now press the unlock button on the FOB The car should blink its flashers or beep, letting you know that programming is now complete. I have seen 2001 and older cars that this did not work on. If the microswitch in the driver's door lock is broken, this method will not work. Share this post Link to post Share on other sites
Analogic 0 Posted January 11, 2017 Kod mene je ovakav kljuc , a na vratima mogu otkljucati sa pomocnim kljucem Share this post Link to post Share on other sites
Mouse-RI 3 Posted January 12, 2017 Onda ce vjerovatno trebat dijagnostika samo.. Share this post Link to post Share on other sites
dr.restaurator 5 Posted January 13, 2017 da triba dijagnostika Share this post Link to post Share on other sites
Analogic 0 Posted January 18, 2017 sto se tiče ključa on radi,kad ga stavim u bravu auto pali, radi i keyless, samo nerade tipke za zaključavanje i otključavanje. kad pritisnem tipku zasvjetli lampica al nedesava se nista. Imam i drugi kljuc kojemu treba ubrzo bateriju mjenjati pa da znam sta mi je raditi Share this post Link to post Share on other sites
Kingo 0 Posted January 19, 2017 Ja imam passata B6 s istim ključem kao i ti, pomogo mi je sync od kolege perotok, možda bi moglo i tebi pomoći. Tu je moj post s problemom i linkom. http://www.vwclubcroatia.com/forum/index.php?/topic/89184-daljinski-kljuc-passat-b6/&do=findComment&comment=849929 Share this post Link to post Share on other sites
Tihi 0 Posted January 19, 2017 odnesi ključ nekome da ga testira. to što lampica svijetli ne znači da šalje signal. Prijava samo preko dijagnostike za B7 Share this post Link to post Share on other sites
Analogic 0 Posted January 23, 2017 Da al kad je baterija bila skroz prazna auto nije prepoznavalo kljuc. kad sam promijenio bateriju Keyless Acces prepoznaje kljuc, tj uhvatim za bravu rukom i auto se otkljuca i zakljuca . Isto tako, kad znaci uhvatim rukom za bravu zasvijetli lampica na daljinskom kljucu. Keyless paljenje auta isto funkcionira. samo neradi zakljucavanje i otkljucavanje, iako u knjizi od auta pise slican proces sinkronizacije kljuca kao sto je Marijan naveo. Share this post Link to post Share on other sites
