Peksy 0 Posted February 1, 2017 Ovako ekipa.....iman udare na cca 60-70kmh.....Ne dolaze toliko do izrazaja dok je motor pod opterecenjrm,al nizbrdo,u leru sa stisnutim kumplugom udari su ajme....pogledao sam kineticke i nemaju luft neki ni nista....e sad dali zamajac moze radit te udare sa stisnutim kumplugom i u leru i najvise na 60-70kmh.... A udari su takvi koda je guma kriva,npr 4-5 puta imam udar i onda prestane par sec i opet pocme Share this post Link to post Share on other sites
Peksy 0 Posted February 2, 2017 Nitko nista? nikakav savjet? Share this post Link to post Share on other sites
Peksy 0 Posted February 4, 2017 Gleda sam samo vozacev kineticki,jucer sam pogledao i ovaj drugi i los je.. .tkd uzea sam oba kineticka unutatnja,spona je jedna imala lufta onda sam uzea i obe spone i fixni set kumpluga Share this post Link to post Share on other sites
<TDI> 404 Posted February 4, 2017 Ajd, ovo je bio rješiv kvar za razliku od onog problema sa kočnicama. Share this post Link to post Share on other sites
Peksy 0 Posted February 4, 2017 Ono jos nije rijeseno hahahah ? Share this post Link to post Share on other sites
<TDI> 404 Posted February 4, 2017 Bit će, samo strpljivo. Share this post Link to post Share on other sites
Peksy 0 Posted February 4, 2017 A nemam sta vise,sve sam minjao Share this post Link to post Share on other sites
ekusetic 0 Posted February 5, 2017 A sta je s kocnicom? propada ti ili? Share this post Link to post Share on other sites
Peksy 0 Posted February 5, 2017 Niska...ima kocionu silu al niska Share this post Link to post Share on other sites
ksasa 0 Posted February 5, 2017 imao slican problem sa kocnicom na 4orci i problem je bilo kratko plasticno vakum crijevo koje je spojeno na servo od kocnica. dobilo laganu pukotinu na jednoj strani. par slojeva izolirke i tako vozio 2 godine bez problema dok nisam auto prodao. Share this post Link to post Share on other sites
Peksy 0 Posted February 5, 2017 Al nebi trebala postat tvrda ako je problem s vakumom? Share this post Link to post Share on other sites
ksasa 0 Posted February 5, 2017 ne, mora biti sto tvrdje. zato je i ovo vise plasticno. ako stavis neko mekano vakum ce ti ga skupiti. nisam ni ja znao pa kupio komad nekog mekseg i nije radilo kako treba. originalno omotao izolirkom, vratio nazad i sve ok. Share this post Link to post Share on other sites
Peksy 0 Posted February 9, 2017 Prominjena oba kineticka,udari i dalje tu.......rijesenja tresnja kod ubrzavanja.. Rijesena* Share this post Link to post Share on other sites
Peksy 0 Posted February 10, 2017 Sve zivo pregledano,jedina stvar ostao zamajac...zamjena iduci tjedan Share this post Link to post Share on other sites
<TDI> 404 Posted February 10, 2017 Provjeri usput i nosače motora da nije do njih, pa ako mijenjaš zamašnjak promijeni i nosač ako je sumnjiv. Share this post Link to post Share on other sites
Peksy 0 Posted February 10, 2017 Sva 3 nova....Pregledao diff u getribi(odlican) prominija ulje,i onda kad smo vidili koliko zamajac klapa sokirali se hahaha Share this post Link to post Share on other sites
<TDI> 404 Posted February 10, 2017 Aha, a ništa, onda van s njim. Koliko km imaš na tahu? Share this post Link to post Share on other sites
<TDI> 404 Posted February 10, 2017 E, pa nije ni čudo onda. Share this post Link to post Share on other sites
Peksy 0 Posted February 10, 2017 Sad cemo mi njega novoga Share this post Link to post Share on other sites
<TDI> 404 Posted February 10, 2017 Javi se kada staviš novi zamašnjak, da se pohvališ kako sada mirno radi. Share this post Link to post Share on other sites
Peksy 0 Posted February 10, 2017 Bas cemo vidit,budem Share this post Link to post Share on other sites
Peksy 0 Posted February 20, 2017 Prominut zamasnjak,udari i dalje tu Share this post Link to post Share on other sites
