dzoni 17 Posted December 13, 2017 Preko VCDS 12.3 sam krenuo da povecam broj intervala za comfort zmigavac sa 3 blinkanja na 5 i gle cuda nema mi opcije ""Comfort Turn Signals (cycles)" pod Adapation u Central Electronics. Ne znam zasto, moze li se nekako drugacije promjenit? Passat B6 1.9 2007.g Changing number of flashes for comfort turn signal Go to 09 - Central Electronics Go to Code Go to long coding helper Go to Byte 16 Check bit 0 ("Comfort Blinking (Highway Blinking) active") Exit out and click Do It. Click on the Adaptation button in 09 - Central Electronics Open drop-down menu titled "Documented adaptation channels can be selected here" Select "Comfort Turn Signals (cycles)" near bottom of menu In the "New Value" area on the left side of the window, click the "Up" or "Down" buttons to get the number of flashes you'd prefer (range is 1-5 and default is 3). I selected the max 5 because 3 isn't really enough time to signal a lane change or turn. Click the Test button. Click the Save button and exit out. Once you are finished coding everything, disconnect the cable and cycle the ignition (not necessary to start the engine). Go back into ACC mode (or turn the car on). Go into the Settings menu on the MFI, select "Lights & Vision," and select "Factory Setting." Click "OK." Result: A soft pull of the turn signal should cause your turn signal to blink the number of times selected. This should not reset your other MFI settings for Lights & Vision, but double check to make sure. Share this post Link to post Share on other sites
projektilski 274 Posted December 13, 2017 Bum ja probal na svom pa javim. Sent from my SM-T819 using Tapatalk Share this post Link to post Share on other sites
