bojan24 Posted June 15, 2007 Posted June 15, 2007 zbog čega mi je vw forum u??asno spor...5x sporiji od hraweba ili seatforuma....?? mekaj u postavkama trebam?
Dino01 Posted June 17, 2007 Posted June 17, 2007 meni radi kao uvijek, nije bas pretjerano brz ali sve je to za ljude...
Bagi Posted June 20, 2007 Posted June 20, 2007 E, pa ovo je stvarno u qrcu!! Da se spajam preko 56k modema, razumio bih, ali f.cking ADSL??? Sve druge stranice i forume otvara prilično brzo, ali na VWCC se vuče ko lijena raga uzbrdo!!!
Dottore Posted June 20, 2007 Posted June 20, 2007 new post i sreach ide presporo gotovo čekam dvije minute
Tomma Posted June 20, 2007 Posted June 20, 2007 Da i meni je isto dosta spor forum za razliku od drugih....
Shen Posted June 20, 2007 Posted June 20, 2007 Izgleda da se server dosta muci sa MySQL bazom, ubija mu CPU a vjerojatno je i velika posjecenost servera (previse stranica hostano na 1 serveru) pa nema dovoljno BW-a i resursa ...
Dottore Posted June 20, 2007 Posted June 20, 2007 Izgleda da se server dosta muci sa MySQL bazom, ubija mu CPU a vjerojatno je i velika posjecenost servera (previse stranica hostano na 1 serveru) pa nema dovoljno BW-a i resursa ... na to mislim i na vručinu temperature
jady Posted June 20, 2007 Posted June 20, 2007 pa i meni prilicno dosta brzo radi......kad idem sa explorerom onda se nacekam ko bik....
Bagi Posted August 21, 2007 Posted August 21, 2007 Je li zna tko za??to sporo učitava stranicu. A jo?? veći problem mi je ako se ulogiram, i par minuta ni??ta ne radim ,vi??e mi uopće neće otvoriti stranicu: The page cannot be displayed The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings. -------------------------------------------------------------------------------- A kad mi i otvori nakon 10 poku??aja učitava mi stranicu po pola minute. Napominjem, da je samo slučaj kod VWCC. Bri??em uredno cookies, nije mi za??tita na "najvi??oj razini, i imam ADSL.
TheFog Posted August 21, 2007 Posted August 21, 2007 bagi, aj nemoj *ebat, vec 2mj sam na 56k (!!!!) i isto mi je ko i sve drugo
Bagi Posted August 21, 2007 Posted August 21, 2007 aj ti u k...c ja nisam na 56k, pa svejedno... ??dere mi ??ivce, ??to mi nekad uopće ne otvara, to je za popizdit
Vec Posted August 21, 2007 Posted August 21, 2007 meni isto sporo otvara kad mi internet radi cijeli dan,onda se jednostavno iskljucim s neta pa ponovo ukljucim odem na VWCC i sve radi ko podmazano,mozda tako pali samo kod mene,al svejedno
Bagi Posted August 21, 2007 Posted August 21, 2007 da, najbolje da ću sad isključivat ADSL, pa ponovno uključivat... pričo mi je pokojni did da su oni tako radili 1955. godine, zato ??to im je bila slaba struja u selu, pa su svi pizdili
Guest SuperDrive Posted August 21, 2007 Posted August 21, 2007 Ako ti ostale stranice normalno otvara i http://www.speedtest.net/ daje normalne rezultate, onda probaj provjerit postavke internet pretrazivaca i dali ti je ukljucena opcija cookies ili mozda imas neki zastitni program kojemu treba duze da provjeri stranicu od virusa i ostalih gluposti.
Bagi Posted August 21, 2007 Posted August 21, 2007 Napominjem, da je samo slučaj kod VWCC. Bri??em uredno cookies, nije mi za??tita na "najvi??oj razini, i imam ADSL.
ventovr6 Posted August 21, 2007 Posted August 21, 2007 ali evo da se i ja nadove??en, isto tako i kod mene sporo radi,a imam ADSL...... prije par tjedana mi je radio fenomenalno.....a sad u zadnjih par dana..sporooo
