Sime Posted August 12, 2022 Posted August 12, 2022 (edited) Pozdrav ekipa, Misljenje za promjenu volana na golfu 7. Trenutno imam onaj ruzni gumeni trendline volan. Stavio bi kozni ali jos nisam odlucio oce biti sa ili bez komandi. Ako idu komande moram i novi infotaiment jer ovaj nema bt. Isto ako neko ima preporuku za zatamnjivanje stakala. Hvala Edited August 12, 2022 by Sime Quote
zvonexp Posted August 29, 2022 Posted August 29, 2022 moze kozni i moze sa komandama, nemoras imat bt da bi tipke radile.. imas pojacavanje, mjenjanje stanice itd Quote
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
