Kosovic
1 Neutral
About Kosovic
    Aleksandar
    VW Passat B7 2.0TDI 170KS 2011god
    Vrbas / Novi Sad
  1. Kosovic
    VCDS - Sva pitanja i pomoc
    Trebala bi mi pomoć ukoliko se neko igrao s VCDS-om. Kabl: HEX-V2 kineski klon SW: VCDS 21.3 i 20.4 Auto: VW Passat B7 2.0TDI 170KS 2011. godište Želim pre svega da isključim start stop. Po svim mogućim forumima i klipovima gledano, ide se na CAN Gateway - Long Adaptation - Channel 13. Međutim, nemam channel 13. Slike u prilogu. Takođe sam probao i "punjenje" kazaljki (staging i indicator_celebration), međutim opet error da nemam taj channel koji je potreban. Ukoliko neko zna da mi razjasni gde nastaje "kvaka". Radio sam i auto scan, okacicu sad dole log. Wednesday,07,July,2021,00:20:19:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: WVWZZZ3CZBP348289 License Plate: Mileage: 224830km-139702mi Repair Order: Chassis Type: 3C-VW46 (7N0) Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62 6C 72 VIN: WVWZZZ3CZBP348289 Mileage: 224830km-139702miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 BD HW: 03L 907 309 N Component: R4 2,0L EDC H24 9953 Revision: 47H24--- Serial number: VWZCZ000000000 Coding: 001D0012042401080000 Shop #: WSC 37047 000 10485 ASAM Dataset: EV_ECM20TDI01103L906018BD 003007 ROD: EV_ECM20TDI01103L906018BD.rod VCID: 6DD17CB3BC91F7E318-8038 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 054 H HW: 02E 927 770 AL Component: GSG DSG AG6 511 2602 Revision: 05351113 Serial number: 00001103211305 Coding: 0000020 Shop #: WSC 00028 028 00001 VCID: 1B35626BDAA5C95336-804E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 614 109 N HW: 3AA 614 109 N Component: J104 C2 450M VDD6 0005 Revision: --H07--- Serial number: 00000004052461 Coding: 0007612 Shop #: WSC 00028 028 00001 VCID: 387F9DE74B53824B3B-806C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA Component: Climatronic H17 1010 Revision: 00003001 Coding: 0000000003 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW46.rod VCID: 6ED37BBFB1970CFB21-803A No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 A HW: 3AA 937 087 A Component: BCM PQ47 H 413 0452 Revision: BB413001 Coding: 000000000000000000180080540081E443516488406C85606480C7200041 Shop #: WSC 00028 028 00001 VCID: 387F9DE78B53824B3B-806C Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB Component: Wischer 16031 10 0603 Coding: 00B795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 120411 05 54 0403 Coding: 033028 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb Part No SW: 3AE 919 475 HW: 7N0 919 475 Component: PARKHILFE 8K H04 0009 Revision: -------- Serial number: 28291108052677 Coding: 308101 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_EPHVA18VW47X0000 001003 ROD: EV_EPHVA18VW47X0000.rod VCID: 7CF741F7F7EB6E6B9F-8028 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 R HW: 5N0 959 655 R Component: J234__101 VW10 HI 1918 Revision: 22014000 Serial number: 003K0P6A15H1 Coding: 0012337 Shop #: WSC 00028 028 00001 VCID: 4C97D1372FCB1EEB6F-8018 Subsystem 1 - Serial number: 6332MTS644950741 Subsystem 2 - Serial number: 6342MTS639920741 Subsystem 3 - Serial number: 6351HTS6D0TAS9KR Subsystem 4 - Serial number: 6361HTS6FNMGS9KJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T Component: LENKS.MODUL 014 0140 Revision: FF010041 Serial number: 20120618302051 Coding: 098A250000 Shop #: WSC 00015 115 12345 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 6FED66BBB69D05F32A-803A Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-TK6 H06 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3AA 920 870 A HW: 3AA 920 870 A Component: KOMBI H20 0420 Serial number: 00000000000000 Coding: 160F01 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod VCID: 306FA5C76B235A0B73-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 G HW: 1K0 907 951 Component: J533 Gateway H41 1614 Revision: H41 Serial number: 080411F1001546 Coding: 461006 Shop #: WSC 00028 028 00001 VCID: 3467A9D7973B662B17-8060 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 HW: 3AA 959 433 Component: IMMO 043 0399 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 76E353DF01C7343BE9-8022 Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 3C0 035 279 HW: 3C0 035 279 Component: RNS315 H05 0010 Serial number: VWZAZ2L3320721 Coding: 000004110400000000011000 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_RNS315VWEUV1UDS A01005 ROD: EV_RNS315VWEUV1UDS.rod VCID: 60CF15877B43AA8BA3-8034 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0529 Revision: 12110009 Serial number: 0002625995 Coding: 0200B7 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X_VW32.rod VCID: 356194D394417F2320-8060 Slave Driver: Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0408 Serial number: 00000002067605 Coding: 000090 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 L HW: 5N1 909 148 G Component: J500__APA-BS KL.311 0802 Revision: 1AH03729 Serial number: 00110880082601 Coding: 0000258 Shop #: WSC 00028 028 00001 VCID: 3B7582EB7A65A953D6-806E No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 HW: 3AA 959 433 Component: KSG PQ47 ELV 043 0631 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 01910A0002860E76300494157C084FCE707801 Shop #: WSC 00028 028 00001 VCID: 76E353DF01C7343BE9-8022 Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 214 Mileage: 224838 km Time Indication: 0 Date: 2015.11.28 Time: 00:18:36 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 1K0 907 951 Component: EZE_2 H41 1614 Revision: H41 Serial number: 080411F1001546 Coding: 00000008 Shop #: WSC 00028 028 00001 VCID: 6FED66BBBE9D05F32A-803A Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A Component: Analoguhr 004 0003 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0529 Revision: 14110009 Serial number: 0002622617 Coding: 0200B6 Shop #: WSC 00028 028 00022 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X_VW32.rod VCID: 366393DF8947743B29-8062 Slave Passenger: Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0408 Serial number: 00000002058163 Coding: 000090 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 E HW: 3AA 907 801 E Component: J540 EPB4 VW-55183 0007 Revision: H18 Serial number: 00000000276254 Coding: 0022067 Shop #: WSC 00028 028 00001 VCID: 3365AACB523561130E-8066 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 1K0 907 951 Component: Batt.regelung H41 1614 Serial number: 080411F1001546 Coding: 030B185A Shop #: WSC 00028 028 00001 VCID: 71E960C3A8A913033C-8024 Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A Component: J367-BDM H07 0150 Serial number: 00000000009370157395 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 3AE 907 441 HW: 3AE 907 441 Component: J772__Rearview 0020 Revision: 00H09000 Serial number: 525 PA8J134081 Coding: 0020006 Shop #: WSC 00028 028 00001 VCID: 72EB6FCF6DAF281BC5-8026 No fault code found. End-------------------------(Elapsed Time: 03:08)--------------------------
