DAČOKTT
0 NeutralAbout DAČOKTT
- Birthday 12/19/1990
Davor.
VW T4 2.5 Tdi.
Tehnika
Kupujem modul volana koji podržava tempomat i mf volan za octaviu 2, golf 5 ..... Tko ima nek pošalje sms na 095 595 5845 Pozz. Davor.
Lijep pozdrav Trebam pomoć susjed mi je dao radio Blaupunkt beta bvx 1J0 035 152 F (VWZ1ZC8962835) 815 7 649 234 360 To je orginal vw dali netko zna kod za radio kak da to otkodiram htio bih starome stavit u kombija pa ak netko zna ima kakvu ideju bio bih zahvalan.
kupujem tablet obavezno mora imat 3g sim utor, quad core moze i jači dual. Minimalno giga rama i min kamera 5mpx. Cijena po dog.
P.Stalke za zvucne kutije od granita Africa Red
DAČOKTT replied to DAČOKTT's topic in Ponuda :: Ostalo
1600 -
dodajem u oglas. Prodajem Rockford T3002 pojacalo u odlicnom stanju,nije popravljano,ima crtu na poklopcu vidi se na slici. 2-channel car amplifier •50 watts RMS x 2 at 4 ohms (100 watts x 2 at 2 ohms) •200 watts RMS x 1 bridged output at 4 ohms, 300 watts RMS x 1 bridged output at 2 ohms (2-ohm stable in bridged mode) •variable high- and low-pass filters (40-400 Hz at 12 dB per octave) •ParaPunch bass boost (0-18 dB, variable 35-70 Hz) with wired remote •Tri-way capable (Tri-Way crossover required) •MOSFET power supply •CEA-2006 compliant •preamp inputs and outputs •fuse rating: 40A x 2 •4-gauge power and ground leads with 80 amp fuse mijerena snaga pojacala u rms-ima 1 × 210 Watt Kanal 1 an 4 Ohm 2 × 190 Watt Kanal 1 + 2 an 4 Ohm Stromaufnahme 41,2A Wirkungsgrad 68,5% 1 × 576 Watt Kanal 1 + 2 gebrückt an 4 Ohm bei 13,4V Versorgungsspannung Stromaufnahme 72,7A Wirkungsgrad 59,1% 1 × 745 Watt Kanal 1 + 2 gebrückt an 2 Ohm bei 13,4V Versorgungsspannung Stromaufnahme 112A Wirkungsgrad 49,6% 1100kn Moguce zamijene cijena u zamijeni veca. moguca dostava do zg www.njuskalo.hr/auto-zvucnici-pojacala/auto-pojacalo-rockford-t3002-oglas-11120635 091 557 4413 sms pm poziv tak svejedno na sve odgovaram.
Prodajem stalke za zvucnike od granita Africa Red 1 stalak ima oko 35kg. gornja ploca je debljine 3cm 30 x 20 cm ukupna visina 85,3cm donja ploca je debljine 5cm 40 x 20cm stup je nakosit prema nazad i debljine je 7,5 cm 50x22 profilirani stup i donja ploca polu c obrada. vrhunska izrada. cijena 1700kn. moguca izrada od raznog kamena oblika i velicina. moguca zamijena za auto akustiku i uz moju nadoplatu.cijena u zamijeni je veca. 091 557 4413 ili pm http://www.njuskalo.hr/zvucnici/stalci-zvucne-kutije-granit-africa-red-oglas-11089925
Prodano
Prodajem zvučne kutije samostoječe i centralni zvučnik sve je u odlićnom stanju vizualno i funkcionalno. cijena je u kompletu 650kn. malo korišteno jer nemam vremena za to pa ih prodajem. Samostojeće kutije SUPERIORE LS-190 x2 komada 100w po komadu 90cm visine 2x16cm midbass i 1x visoki. Centralni zvučnik Alpha:MODEL : E 1005 CENTER x 1 komad Power (max) : 100 watts Frequency response : 80 Hz - 20 KHz Sensitivity (dB/m/w):88 dB Dimenzije:41x 15 x 24 Moguca zamjena za autoakustiku ili nesto ponudite. u zamjeni cijena veća moguca i moja nadoplata. Moguce slanje hp expressom moguca dostava do zg http://www.njuskalo.hr/zvucnici/samostojece-zvucne-kutije-centralni-zvucnik-oglas-11009013
KABLOVI PRODANI I ADAPTERI Sub MTX Thunder 5000 oldschool Subwoofer,25cm, na subu je bio probusen ovjes membrane te je stavit novi ovjes.i svira bez greske. Kutija je kompresijska i rađena je po mjerama za sub.cijena 300kn može i bez kutije 200kn. Oxygen audio 2-way skretnice, ljepi kondići, zavojnice, kvalitetne skretnice. 120kn Pyle tuba bez zvučnika unutra je bila 20-tka,tapacirana uz tubu ide zaštitna mrezica za zvucnik i mreža koja se zakači za siceve da tuba nepleše po gepeku. 46cm x 27cm rupa za zvučnik je 18cm. 100kn Pojacalo Soundstream usa 204 savrseno oldschool pojacalo u izvrsnom stanju nikad popravljano rucno proizvedeno u usa. mozda jedino u hr. 40w x 4 @ 4 ohms 60w x 4 @ 2 ohms 100w x 2 bridged @ 4 ohms 500kn Subwoofer Pioneer ts-w3001d4 3000w 1000rms-a u odlicnom stanju. sa orginalnom ambalažom. Moguce zamjene za autoakustiku i uz moju nadoplatu. Cijena 850kn 12 / 30 cm subwoofer snage 1000/3000W, frequency response 20 - 150 Hz, 2 x 4 Ohma zavojnice Opis Maximum output power 3.000 W Nominal output power 1.000 Wrms Frequency response 20 - 150 Hz Lowest resonance frequency (Hz) 33,3 Sensitivity (1W/1m) 92 dB Woofer size (cm) 30 cm Woofer material Composite IMPPtrade; cone woofer using Interlaced Carbon Fibre with Butyl Rubber Edge Dual 4#937; voice coils 2 or 8#937; Voice Coil bobbin type Phenol resin coated glass cloth bobbin Magnets Double-stacked, high power Recommended sealed enclosure (Litres) 22,6 Micro Fibre Surround na pm ili 091 557 4413 Davor moze i sms. moguce slanje hp ekspressom moguce razne kombinacije zamjene.
Kupujem mrv v12 seriju pojacala ali samo seriju tipa 250,t300,f300,f400,t500,1000 itd, ako tko sta ima u ormaru moze i pokvareni
Pyle tuba bez zvučnika unutra je bila 20-tka,tapacirana uz tubu ide zaštitna mrezica za zvucnik i mreža koja se zakači za siceve da tuba nepleše po gepeku. 46cm x 27cm rupa za zvučnik je 18cm. 100kn prodajem novi kabal za antenu za auto duzine 3m. 30kn Pojacalo Soundstream usa 204 savrseno oldschool pojacalo u izvrsnom stanju nikad popravljano rucno proizvedeno u usa. mozda jedino u hr. 40w x 4 @ 4 ohms 60w x 4 @ 2 ohms 100w x 2 bridged @ 4 ohms 500kn prodajem novi kabal za antenu za auto duzine 3m. 30kn prodajem adaptere za zvucnike za skodu octaviu za 16,5 cm zvucnike org od skode adapter. na njima su bili infinity reference 6510 cs zvucnici cijena 50kn 0915574413 ili pm
P: centrale prstenove 60.1 na 56.6 za felge i momo cepovi
DAČOKTT posted a topic in Ponuda :: Gume i felge
Prodajem centrale prstenove 60.1 na 56.6 za felge novi nikad korišteni kupljeni u sloveniji plaćeni 25 eura Prodajem za 20eura ili 150kn prodajem momo corse cepove za felge, meni nisu pasali pa ih prodajem. citavi ispravni. 150kn 0915574413 ili pm
