ivan_zgd
About ivan_zgd
  • Birthday 04/05/1988
    Ivan
    Golf MK5 1,9 TDI
    Zagreb-Dubrava
  1. ivan_zgd
    P: Golf V 1.9 TDI sportline
    Auto prodan, može lock, hvala
  2. Prodajem Golf 5 1.9 tdi 66kw, sportline. Auto trenutno ima 128 800 km, na 98 000 napravljen veliki servis i promjenjeno kvačilo. Uz auto dolazi set celicnih felgi16 s zimskim gumama. Ostali upiti na mob ili PM. Ivan 091 612 - 1203 Cijena 7200e
  3. - dimenzija: presjek kabla 70mm2 - kabel od bakrene žice a ne od aluminijske legure - proizvođač: Dietz Njemačka - crveni Cijena 300 kn
  4. Prodajem navedeno pojačalo "Rockford Fosgate Punch 800.4" u odličnom stanju, jako malo korišten. Cijena: 1400 kn Tko želi slike, mogu poslikati i poslati mu ih. Specs 200W RMS x 4 at 2 ohms 400W RMS x 2 in bridged mode 2-, 3-, 4-channel or Tri-Way output Front and rear high-pass/low-pass crossovers (variable 50-210 Hz, 12 dB/octave) MOSFET power supply and output devices Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality NOMAD — advanced protection circuitry for "intelligent" shutdown protection Speaker-level inputs preamp outputs Punch Bass boosts bass up to 18 dB at 45 Hz 4-2 switch 60-amp fuse and fuse holder required Dimensions: 18-7/16"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
  5. Kupujem zadnju lijevu štop lampu i kromiranu lajsnu branika za phaeton-a 2003-2004 god. kontakt : 098/946 - 32 86 Ivan, 095/500 - 52 25 Domagoj
  6. Kao što se vidi iz naslova prodaju se crystal clear stop lampe za golfa 1, nikad bile na autu, stanje novo zapakirano u kutiji. Cijena: 600 kn Kontakt: 095 / 902 - 62 88 (Danijel) , ili 098 / 946 - 32 86 (Ivan)
  7. Eto frend prodaje felge Borbet 15" , 4x114,3 - 4 komada bez guma http://www.njuskalo.hr/alu-felge/borbet-15...a-oglas-4401353
  8. ivan_zgd
    P: Sicevi konig
    Molim lokot na ovo sicevi su prodani, hvala
  9. ivan_zgd
    P: Sicevi konig
    ....:::: B U M P ::::.... Nova cijena: 500kn
  10. ivan_zgd
    P: Porsche design aluminijske sanjke
    Tko je zainteresiran oko cijene se da porazgovarati ....:::: B U M P ::::....
  11. ivan_zgd
    P: IPHONE 4 32 GB BIJELI VIP GARANCIJA
    molim lokot na ovo
  12. ivan_zgd
    ....:::: B U M P ::::.... nova cijena 100 e
  13. ivan_zgd
    .....::::: BUMP :::::..... Cijena : 2800 kn
  14. Prodajem aluminijske porsche sanjke, korištene par puta. Sanjke doleze s originalnom futrolom te su sklopive radi lakšeg prijevoza. Slika je skinuta s neta ali to je to, svoje slike stavim kad poslikam sanjke. Cijena je 200 E te je simbolična i oko nje se da pregovarati. Mob: 098 / 946 - 3286
  15. Kao što se vidi iz naslova, prodajem iphone star mjesec dana s svom opremom i garancijom. Mobitel je za vrijeme cijelog korištenja bio u futroli tako da nema niti jedne crtice na sebi. Evo i link na njuškalo: http://www.njuskalo.hr/iphone-4-32-gb/ipho...a-oglas-3967264 Cijena: 3000 kn Broj telefona: 091/612 1203, 098/ 946 3286
