MarioIV 11 Posted February 17, 2016 nisam 100 posto ali mislim da ces morati jos jednom naruciti Share this post Link to post Share on other sites
GogiR32 0 Posted February 17, 2016 I nemoj preko ebaya, imas na njuskalu provjerenih Share this post Link to post Share on other sites
bozic.hrvoje 0 Posted February 17, 2016 I nemoj preko ebaya, imas na njuskalu provjerenihamo ti treba vcds javi se u inbox Share this post Link to post Share on other sites
GogiR32 0 Posted February 17, 2016 Imam hvala, ili si krivo quotao? Share this post Link to post Share on other sites
perotok 0 Posted February 17, 2016 Pozdrav, nedavno sam s ebay-a uzeo KKL kabel s Vag Com 409.1 dijagnostikom. Kad hocu nesto izmjeniti govori mi da ta verzija nije registrirana. Stoga me zanima ima li itko kakav registrirani 409.1 da pošalje u pm, jer ovi linkovi su istekli? Puno hvala Ta verzija 409.1 nikad i nije imala dobar crack Sa tim kabelom KKL koristi verziju VCDS Lite Poslao sam ti na PM P.S. Nadam se da znaš da sa tim kabelom možeš raditi samo vozila do 2004 g. Share this post Link to post Share on other sites
RaZ0R911 0 Posted February 17, 2016 Pozdrav Nemogu uključiti prednje maglenke u VCDS-u,pod central electronic nema front fog lights Auto je Golf mk5 2005 Trendline Share this post Link to post Share on other sites
MarioIV 11 Posted February 17, 2016 treba ti novi jaci modul central elektirk Share this post Link to post Share on other sites
royal23 0 Posted February 17, 2016 Pozdrav Nemogu uključiti prednje maglenke u VCDS-u,pod central electronic nema front fog lights Auto je Golf mk5 2005 Trendline Koji je broj CECM-a, iščitaj ga, npr. 3C0 937 049 C... Mora biti 23 byta da bi imao tu funkciju... Share this post Link to post Share on other sites
RaZ0R911 0 Posted February 18, 2016 Component: Bordnetz SG 1.0 H30 0704 VAG Number 1K0 937 049 S Ugl 17 byta :/ Kako da uključim lampicu motora,lampicu airbaga te pištanje za pojas? Uključio sam lampicu pojasa no ne pokazuje mi se,dok radim output test onda mi svijetli. Koja je otprilike cijena jačeg modula? Share this post Link to post Share on other sites
Mouse-RI 3 Posted February 18, 2016 Ima netko koji link na jeftini a dobar kabel za kodiranje za Vw Polo 9n3, nešto na ebay ili ali express... Share this post Link to post Share on other sites
RaZ0R911 0 Posted February 18, 2016 Ovaj sam ja kupio i radi mi kodiranje http://www.njuskalo.hr/ostala-autooprema/vag-12.12-hex-can-dodatni-programi-gratis-oglas-13221482 Čovjek došao na pola puta,pokazao funkcionalnost.. Share this post Link to post Share on other sites
perotok 0 Posted February 20, 2016 Ovaj sam ja kupio i radi mi kodiranje http://www.njuskalo.hr/ostala-autooprema/vag-12.12-hex-can-dodatni-programi-gratis-oglas-13221482 Čovjek došao na pola puta,pokazao funkcionalnost.. A jesi li probao sve funkcije long coding-a ....npr cornering Share this post Link to post Share on other sites
RaZ0R911 0 Posted February 21, 2016 Nisam jer mi modul ne podržava. Probao sam kodiranje pojasa,indikatora potrošenosti pločica,kodiranje zaključavanja vrata pri 15km/h,automatsko paljenje svjetala itd.. Output testovi mi rade na svemu što imam montirano na autu. Očitava mi parametre motora pri radu(dize,potrošnja goriva,snaga itd) Share this post Link to post Share on other sites
Tomx 0 Posted March 29, 2016 Da ne otvaram novi topic, jel ima neko u ZG-u da mi iskodira neke stvari na Polu 6R, tipa da mi nisu upaljena kratka svijetla kad je prekidac u poziciji 0 i takve neke sitnice ako je to moguce? Share this post Link to post Share on other sites
rapajic.st 2 Posted April 4, 2016 jel tko zna gdje se u vag-com nalaze opcije za istrošenost pločica, razine staklopera i sl? Share this post Link to post Share on other sites
perotok 0 Posted April 4, 2016 (edited) jel tko zna gdje se u vag-com nalaze opcije za istrošenost pločica, razine staklopera i sl? 17-Instruments>07-Coding>Long Coding helper ------ prebacuj Byte-ove , mijenjaj Bit-ove (stavljaj ili miči kvačice) Pogledaj ovdje --- LINK Edited April 4, 2016 by perotok Share this post Link to post Share on other sites
IVAN_VXR 0 Posted April 5, 2016 Gdje najpovoljnije kupiti original Vag Com ? U zadnje vrijeme radim dosta novih auta 2014-2016 i jednostavno ne mogu bez originala.. Share this post Link to post Share on other sites
perotok 0 Posted April 6, 2016 Gdje najpovoljnije kupiti original Vag Com ? U zadnje vrijeme radim dosta novih auta 2014-2016 i jednostavno ne mogu bez originala.. U Sloveniji ili Srbiji --- to je najbliže Link Share this post Link to post Share on other sites
IVAN_VXR 0 Posted April 7, 2016 A i ja sam gledao na stranici..nisam još slao upite,idem poslat danas: hvala Share this post Link to post Share on other sites
Dario_7R 34 Posted April 7, 2016 350€ ebay DE i par eura dostava Share this post Link to post Share on other sites
AUTOFREAK 217 Posted April 7, 2016 Javi se Belom... on ima neku rutu legalisa... Share this post Link to post Share on other sites
northman 0 Posted April 12, 2016 (edited) Pozdrav svima! Novi sam na forumu. Odnedavno ponosni vlasnik Passata b6 (2.0 tdi, higline iz 2008.).Kako na njemu ima nešto sitnica koje treba riješiti, a stari mi je old school automehaničar, mislim uzeti autodijagnostiku da mu olakšam servisiranje ovog mog auta, jer vidim da se npr. ne mogu promjeniti kočnice bez da se auto spaja na dijagnostiku. Pokušao sam pročitati sve teme na forumu koje se tiču VAG-COM i VCDS, no što više čitam to sam zbunjeniji... Da ne otvaram novu temu, pitat ću ovdje, znači za osobne potrebe (ne mislim se ovime baviti profesionalno niti naplaćivati ove usluge), koja dijagnostika trenutno je Best Buy?Vidim da se spominju kineski klonovi, pa onda neke verzije se ne smiju spojiti na internet, pa onda kabeli koji moraju biti hex-can...? Svakako bih volio da mi je program i sučelje (isprike ako koristim krive izraze) na hrvatskom jezikuNa njuškalu sam vidio ovaj oglas:http://www.njuskalo.hr/ostala-autooprema/auto-dijagnostika-vag-com-908.1-oglas-1339732Da li je netko od članova imao iskustva s ovim prodavačem?Da li je ova VAG COM 11.11.5 2013 VERZIJA -HRVATSKI 10.6 ok?Imamo li uopće na forumu člana sa područja Splita kojem bi se mogao javiti za savjet i da me uputi šta i kod koga kupiti?EDIT: Sad sam vidio da se u ovoj temi ne bi smjela postavljati pitanja, stoga molim admina da obriše ovaj post, a ja ću pitanje postaviti u tehničkom kutku... Edited April 12, 2016 by northman Share this post Link to post Share on other sites
projektilski 274 Posted April 12, 2016 To ti je preskupo za staru verziju. Share this post Link to post Share on other sites
IVAN_VXR 0 Posted April 12, 2016 U Sloveniji ili Srbiji --- to je najbliže Link Javili su mi,399 eura,poštarina gratis Share this post Link to post Share on other sites
ruscic 2 Posted April 17, 2016 Ja uskoro iman na prodaju orginal pošto dolazi WIFI interfejs Share this post Link to post Share on other sites
