Dario_7R 34 Posted January 24, 2016 stavis gateway novi i onda flashas Rns sa novijim firmware-om a treba kodirat tipke ,nije dobro iskodirano Share this post Link to post Share on other sites
DangerousB 1 Posted January 24, 2016 Prijatelj mi je rekao da on misli da ima vec novi gateway zbog rns-a... kako mogu provjeriti koji je gateway? Share this post Link to post Share on other sites
Dario_7R 34 Posted January 25, 2016 vcds scan 09 central elec. Share this post Link to post Share on other sites
DangerousB 1 Posted January 26, 2016 Ipak je neki stari gateway jutros auto nije upalilo pokazuje na akumualtor... Share this post Link to post Share on other sites
Dark Beast 0 Posted January 29, 2016 kako updejtati mape od navijagcije, znaci mapu hrvatske nema nikako, ima njemacku i ostale zemlje, gdje skinuti mape i na koji nacin ih updejtati? Share this post Link to post Share on other sites
Dario_7R 34 Posted January 29, 2016 nac na torentu east europe v12 i updejtat v13 ide samo na novije RNSove ,jer ne citaju sve dual layer zaprzene DVDs Share this post Link to post Share on other sites
MarioIV 11 Posted January 29, 2016 Ili učitati preko sd kartice Share this post Link to post Share on other sites
Dark Beast 0 Posted January 29, 2016 a v12 ide na sve verzije rns510? jer ja imam A ili B verziju Share this post Link to post Share on other sites
DangerousB 1 Posted January 29, 2016 Jel moze poslati neko tutorial koji je najbolji firmware za B verziju trenutni sw je 0900... hvala Share this post Link to post Share on other sites
Dario_7R 34 Posted January 29, 2016 4020 by josi to ide na A i B Share this post Link to post Share on other sites
Dark Beast 0 Posted January 31, 2016 Sad me zanima sto se novo dobiva na toj 4020 verziji s obzirom na ove stare verzije, i ako se napravi update dali se mora sta mijenjati sa geatway-om ili sve ostaje po starom? Share this post Link to post Share on other sites
DangerousB 1 Posted January 31, 2016 Ja sam instalirao 5238-josi verziju sve super radi sad me samo interesuje kako mape da nabacim na hdd skinuo sam RNS 510 East Europe V13 CD_8350 i ne moze stati na jedan dvd.. jel treba double layer? i ako ima neko neki tutorial kako to odraditi? hvala Share this post Link to post Share on other sites
Dario_7R 34 Posted January 31, 2016 samo preko SD kartice ces ih prebacit http://www.christian-jeanin.ro/mapstool2/files/help/help.html Share this post Link to post Share on other sites
Petar_Kc 0 Posted February 1, 2016 Ja sam instalirao 5238-josi verziju sve super radi sad me samo interesuje kako mape da nabacim na hdd skinuo sam RNS 510 East Europe V13 CD_8350 i ne moze stati na jedan dvd.. jel treba double layer? i ako ima neko neki tutorial kako to odraditi? hvala Ja sam isto skinuo ovu verziju, nasnimio sam na dual layer dvd na najsporijoj brzini. Ubacio sam DVD u RNS i sve se odradilo kako treba. Evo link na kako se radi update na samom uređaju: DVD sam spržio sa programom ImgBurn. Negdje sam našao upute: "Burn on Verbatim DVD+R 8,5 Double Layer with ImgBurn (1x or slowest)!" Share this post Link to post Share on other sites
markol5 15 Posted January 24, 2017 Zna li netko koji je ovo model rns-a i di ga se moze kupit? Trazim po cilom netu al nikako naletit na bas ovakav,sa ovim rasporedom tipki mk5GT Share this post Link to post Share on other sites
MarioIV 11 Posted January 24, 2017 ti to ozbiljno ? pa to ti je kinez Share this post Link to post Share on other sites
markol5 15 Posted January 24, 2017 Znam da je kinez samo nigdi nemogu nac da ima sa ovim rasporedom tipki samo me to zanima nista drugo mk5GT Share this post Link to post Share on other sites
mihael 0 Posted January 24, 2017 Erisin, model 7800 mislim, ili nesto tako, ali uglavnom pogledaj na njihovoj stranici imas takav Poslano sa mog SM-G800F koristeći Tapatalk http://m.erisin.com/item_detail/541/#!detail Poslano sa mog SM-G800F koristeći Tapatalk Share this post Link to post Share on other sites
markol5 15 Posted January 24, 2017 Erisin, model 7800 mislim, ili nesto tako, ali uglavnom pogledaj na njihovoj stranici imas takav Poslano sa mog SM-G800F koristeći Tapatalk http://m.erisin.com/item_detail/541/#!detail Poslano sa mog SM-G800F koristeći Tapatalk Bravo. Hvala puno mk5GT Share this post Link to post Share on other sites
vw_dokii 1 Posted January 25, 2017 Isplati li se prodati RNS MFD2 OEM i uzeti kinjolu rns 510 radi svih modernih benefita ? Share this post Link to post Share on other sites
Mouse-RI 3 Posted January 25, 2017 Zasto vi svi to zovete kineski rns510? To se tako nigdje ne reklamira... A Erisin android je daleko bolji od oem sta se tice funkcija i mogucnosti povezivanja, a i kvaliteta zvuka je po meni bolja nego na original radiu, cijene su od 2300 kn na gore, ja bi uzimao novi model sa 8" zaslonom... Share this post Link to post Share on other sites
projektilski 274 Posted January 25, 2017 malo sam gledao specifikacije tih Erisinia za VW i nekako mi je jadno, ima puno boljih kineza (veca reza ekrana, jaci cpu i gpu, vise memorije itd...) Share this post Link to post Share on other sites
Mouse-RI 3 Posted January 25, 2017 Rezolucija ekrana je perfektna, na 7-8" mislim da ni ne moze biti bolja nego sta je... Tj ni bolju rezoluciju nebi vidio golim okom... A trenutno su to standardi sada sta se ugradjuju Android 5.1.1 OS, 1024*600 HD, Quad-Core 1608MHz CPU, 1GB RAM, 1.96GB ROM, 11.52GB Internal Memory Share this post Link to post Share on other sites
projektilski 274 Posted January 25, 2017 Ne postoji tako nesto kao previsoka rezolucija Share this post Link to post Share on other sites
Mouse-RI 3 Posted January 25, 2017 Previsoka je svaka ona koja se ne vidi golim okom, djabe tebi 1080p na ekranu od 7" Share this post Link to post Share on other sites
