Dejo 0 Posted February 21, 2010 (edited) Evo ovako danas krenem se vozit i nakon kretanja sa semafora upalila mi se lampica EPC i pisalo je da odma na servis idem i zatim se upalila lampica od lamda sonde i pocela blicat EPC se u gasio a sonda nastavila blicat i auto je poceo trest i gubit snagu O cemu se radi??? :( da nadodam da auto kad se ugrije radi ok.... Edited February 21, 2010 by Dejo Share this post Link to post Share on other sites
CitiuS 0 Posted February 21, 2010 Tesko je govorit napamet, ako nemas VCDS (VagCom). Sutra ujutro prvo u servis pa ces za 5 min znati o cemu je rijec. Moze biti milijun stvari. Ovako je nemoguce odgovoriti. Share this post Link to post Share on other sites
Galaxy 0 Posted February 21, 2010 Pošto imaš garanciju,pravac u ovlašteni i nek ti riješe to Share this post Link to post Share on other sites
MarioIV 11 Posted February 21, 2010 da nije gorivo lose Share this post Link to post Share on other sites
Galaxy 0 Posted February 21, 2010 Ja imam isti takav motor u G5,točim omv100 i dosad nisam imao nikakvih problema.... Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 ma i prije je on malo cugao dok se ne ugrije al danas se bas tresao i nije imao snage bas malo tu listam i vidim da dosta tih novih auta ima slicnih problema Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 da nije gorivo lose tocim tifon class Share this post Link to post Share on other sites
Dusko 0 Posted February 21, 2010 Gas u servis....... Share this post Link to post Share on other sites
MarioIV 11 Posted February 21, 2010 probaj se svejedno prebacit na omv 100 imam osjecaj da je zbog tog ali javi ako sta otkriju u servisu Share this post Link to post Share on other sites
AUTOFREAK 217 Posted February 21, 2010 javi šta su našli u servisu... moguce je da te gorivo zeza al javi nam koja je greška... traži da ti isprintaju s diagnostike Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 Evo ovako danas krenem se vozit i nakon kretanja sa semafora upalila mi se lampica EPC i pisalo je da odma na servis idem i zatim se upalila lampica od lamda sonde i pocela blicat EPC se u gasio a sonda nastavila blicat i auto je poceo trest i gubit snagu O cemu se radi??? :( da nadodam da auto kad se ugrije radi ok.... Evo sad upalim auto i radi na leru drzi ga na 1200 okr nekih pol minute minutu i onda padne na 700 800 i pocnem se vozit malo trza al ide cim gasa dam lagano onda pocne mal trest a u S modu da visim okretajima ne trese i cim auto se ugrije malo sve 5 cudno .... ujutro ide na servis valjda ce me primit odma .... Share this post Link to post Share on other sites
Galaxy 0 Posted February 21, 2010 Potpuno normalno je to dok ga hladnog upališ da su okretaji na 1200,i onda nakon minute padnu na oko 800 o/min Share this post Link to post Share on other sites
gfos 0 Posted February 21, 2010 (edited) garant sve isto kao meni i jebi me al ovo ce ti bit greske Random/Multiple Cylinder Misfire Detected & Cylinder 1: Misfire Detected doduse smao je pitanje na kojem cilindru. http://www.vwclubcroatia.com/forums/index....mp;#entry406147 Edited February 21, 2010 by gfos Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 garant sve isto kao meni i jebi me al ovo ce ti bit greske Random/Multiple Cylinder Misfire Detected & Cylinder 1: Misfire Detected doduse smao je pitanje na kojem cilindru. http://www.vwclubcroatia.com/forums/index....mp;#entry406147 i sta jesi bio u servisu da li si rjesio to*? Share this post Link to post Share on other sites
gfos 0 Posted February 21, 2010 to ti se pojavljivalo jedno jutro da pa dva ne pa opet jedan dan ujutro da pa tri ne itd. uglavnom svaki put kad mi se pojavilo sam sam spajao na VAG i iscitavao jednu te istu gresku koju sam ti napisao gore. Sad se ne pojavljuje greska vec dva tjedna, auto malo kao da zna zatreskat dok sjedis u njemu na leru, normalno ide, sipam otkad znam za sebe OMV100, mjenjao bombinu s prvog na cetvrti cilindar itd. jos nisam bio u servisu cekam ne znam ni sam sta?!? Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 to ti se pojavljivalo jedno jutro da pa dva ne pa opet jedan dan ujutro da pa tri ne itd. uglavnom svaki put kad mi se pojavilo sam sam spajao na VAG i iscitavao jednu te istu gresku koju sam ti napisao gore. Sad se ne pojavljuje greska vec dva tjedna, auto malo kao da zna zatreskat dok sjedis u njemu na leru, normalno ide, sipam otkad znam za sebe OMV100, mjenjao bombinu s prvog na cetvrti cilindar itd. jos nisam bio u servisu cekam ne znam ni sam sta?!? ja sutra ode mislim da imamo istu stvar kao sta si rekao jer meni ista stvar se desava samo po dva tri tjedna radi normalno i onda to Share this post Link to post Share on other sites
gfos 0 Posted February 21, 2010 ovo ti se upali? blinka i onda ostane svijetliti. ugasis auto i ponovo upalis i nema lampice? http://img17.imageshack.us/img17/3909/456tjl.jpg de mi reci jel ti radi auto ovako kad slusas na auspuhu ujutro? koliko konja imas? Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 ovo ti se upali? blinka i onda ostane svijetliti. ugasis auto i ponovo upalis i nema lampice? http://img17.imageshack.us/img17/3909/456tjl.jpg de mi reci jel ti radi auto ovako kad slusas na auspuhu ujutro? koliko konja imas? da ta lampica se upali i blica al danas mi se upalio i EPC i ja ugasio auto i upalim on se nije upalio al druga ta lampica od ispuha je blicala i kad se auto ugrije sve super mislim da radi isto ko tvoj 160 ks Share this post Link to post Share on other sites
Dejo 0 Posted February 21, 2010 kak svijetli EPC? pise EPC i svjetli hehe Share this post Link to post Share on other sites
gfos 0 Posted February 21, 2010 e jbg nisam ja to skonto Share this post Link to post Share on other sites
Igor031 0 Posted February 21, 2010 koliko konja imas? presudno je kolko konja ima... da ima koji vise mozda se nebi tresao svakako idi u ovlasteni posto je auto novi a nemoj se zahebavat sam s time, ni nissta pokusavat...mozda je neka mana ko na toyotama Share this post Link to post Share on other sites
Dejo 0 Posted February 22, 2010 Evo ovako bio sam na servisu na autu nema gresaka stavljen je najnoviji software i receno mi je da auto ne drzim dugo u reezervi i da ga ponekad odem ispuhat negdje auto radi normalno eto valjda nece vise bit toga Share this post Link to post Share on other sites
dino46 0 Posted February 22, 2010 sused kupi se jettu mk2 i neces imati takvih problema... , naravno u bijeloj boji..... hehe Share this post Link to post Share on other sites
Dejo 0 Posted February 22, 2010 sused kupi se jettu mk2 i neces imati takvih problema... , naravno u bijeloj boji..... hehe bas tako ah ta elektronika danasnja hehehe Share this post Link to post Share on other sites
