GTI-VR6-R32 37 Posted December 6, 2018 (edited) I kod mene je ona letvica pukla na dosta mjesta.Grijaci su neki "no name" marka ima im 3 godine od kada sam ih stavio pa vjerujem da je do njih,danas u 17h idem na dijagnostiku kod majstora pa cu tada saznati sta je. A i kada upalim auto baci nesto bjelog dima. Edited December 6, 2018 by GTI-VR6-R32 Share this post Link to post Share on other sites
G2 LTD 37 Posted December 6, 2018 Grijace Beru samo uzimati. Ili bosch. Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 7, 2018 Evo javljam da nisu valjala 3 grijaca,ali nisam uspio da ih odvrnem jer bojim se da ce puknuti ili cu zeznuti navoj na glavi,a nisam ih pritegao kao sivonja jer stregao sam ih na 15Nm. Share this post Link to post Share on other sites
G2 LTD 37 Posted December 7, 2018 (edited) Maži sa wdom ili kakvom masti da se lagano topi. I kako ces se voziti bude lagano u navoj uslo. Ja sam bakrenu mast stavljao na vijke ispusne grane i vozio se tjedan dana i kada sam ju isao skidati, vijci isli kao od sale van. Edited December 7, 2018 by G2 LTD Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 7, 2018 (edited) Hvalaa,pokuaću tako. Nadam se da ću uspjeti da ih odvrnem. Javim ako sta bude. Edited December 7, 2018 by GTI-VR6-R32 Share this post Link to post Share on other sites
tommek10 7 Posted December 7, 2018 Jesi probao na vruć motor? Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 8, 2018 (edited) Kada sam pokusao da odvrnem grijace bio je mlak motor. Probat cu ovo sto mi je kolega G2 LTD predlozio. Edited December 8, 2018 by GTI-VR6-R32 Share this post Link to post Share on other sites
Neo 0 Posted December 9, 2018 na mojem je bilo problem s grijacima ali ovak dok probas ispada da su svi ispravni. moras skinut spojit na akumulator i gledat da se vrh grije a ne negde sastrane Share this post Link to post Share on other sites
jooka 1 Posted December 9, 2018 Kada sam pokusao da odvrnem grijace bio je mlak motor. Probat cu ovo sto mi je kolega G2 LTD predlozio. Bit će to sad muka za skinuti, nadam se da će uspjeti Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 10, 2018 Mozeli neko da snimi kako se cuje relej grijaca,da budem siguran da radi,i evo javljam da sam uspjesno odvrnuo grijace i stavio nove beru i stavio na navoj bakarne masti. Share this post Link to post Share on other sites
Tomislav Kt 5 Posted December 10, 2018 Pogledas jel dolazi 12 V na grijace i nemas sta gledat ni slusat relej. Sent from my TA-1012 using Tapatalk Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 10, 2018 Ne znam ti ja oko struje Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 18, 2018 Jos uvjek je prisutan problem i sa novim grijacima,relej je ispravan vozio sam auto kod auto elektricara, e sada sumnjam na senzor temperature,jer nesto sam citao po forumu da on odredjuje kada ce se upaliti grijaci a mjenjao sam ga stavio sam Topran mada znam da nije neka marka,ali trebalo bi da sluzi. Share this post Link to post Share on other sites
G2 LTD 37 Posted December 18, 2018 Nebi trebao da sluzi. Shit koji zna biti pokvaren i u kutiji. Iskopcaj ga mislim da ce onda uvijek paliti Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 18, 2018 Da ga iskopcam,oceli sta smetati autu pri radu i sta cu dobiti sa tim? Koji da stavim onda imate li neku preporuku,gledao sam original ali je on oko 40-50 eura. Share this post Link to post Share on other sites
jooka 1 Posted December 18, 2018 (edited) Da ga iskopcam,oceli sta smetati autu pri radu i sta cu dobiti sa tim? Koji da stavim onda imate li neku preporuku,gledao sam original ali je on oko 40-50 eura. Prvo ga iskopcaj i vidi ta će biti, lako će kupiti ako je do njega. Neće se nita dogoditi jedino će ti greka ostati pa ju treba obrisati Edited December 18, 2018 by jooka Share this post Link to post Share on other sites
AutoTdiP 0 Posted December 18, 2018 Pogledas jel dolazi 12 V na grijace i nemas sta gledat ni slusat relej. Sent from my TA-1012 using Tapatalk Evo po koji put ti ljudi govore i ja sam ti prije rekao ,provjeri struju na grijačima, dali opče ima,..... Pa nije to znanstvena fantastika.............. Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 18, 2018 Evo po koji put ti ljudi govore i ja sam ti prije rekao ,provjeri struju na grijačima, dali opče ima,..... Pa nije to znanstvena fantastika.............. Ima struje dolazi do grijaca,napisao sam da sam isao elektricaru. Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 22, 2018 Rijeseno,stavljen novi senzor temp. i sada pali ko mina. Share this post Link to post Share on other sites
luka93 19 Posted December 22, 2018 Koliko novaca je senzor Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 22, 2018 Kupio original 40 eura. Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 23, 2018 (edited) Evo mene opet hahaha jutros isao auto da upalim,dodam kontakt grijaci odradili 6-7 sek. i da ga upalim kad ono nista nema struje nikako niti se pojavljuju ikonice,nema sata,nema kilometraze,jedino se smrzla kazaljka goriva na polovini,kao da je neko iskopcao aku. akumulator ulazi u 6 godinu i pretjeram auto na sunce gurajuci i ostavim 1-2 sata i nekako upali uz puno verglanja. Koji aku. da uzmem,kontam da ga je ubila gradska voznja jer rijetko kada izadjem na otvoren put. Edited December 23, 2018 by GTI-VR6-R32 Share this post Link to post Share on other sites
<TDI> 416 Posted December 23, 2018 Taj sigurno nadopunjavanje nikad vidio nije a trebao je, isto kao provjeravat napon jednom mjesečno ali kao što sam više put napisao malo tko to radi a poželjno je. Uzmi Vartu, ako ti je preskupa Exide pa onda Topla ili neki koji ti je povoljan ali gledaj da ima jaču startu struju jer dobro dođe preko zime. Imaš i dosta otvorenih temu pa prelistaj ako se hoćeš malo više informirati. Share this post Link to post Share on other sites
GTI-VR6-R32 37 Posted December 23, 2018 Nije nadopunjavan nikad,ne znam da li cu postici ista nadopunjavanjem ili da uzmem novi,ali i godinu su ga stigle pa cu najvjerovatnije uzeti novi,ovaj sto sam imao je bio Topla 75Ah,jacina startne struje 750A.Hvala na savjetima prelistat cu malo. Share this post Link to post Share on other sites
<TDI> 416 Posted December 23, 2018 Možeš pokušati ako imaš volje pa vidjet. Share this post Link to post Share on other sites
