AUTOFREAK
PC 911 By Singer Vehicle Design
Restauracija legende s nesto modernijim materijalima al opet i s nekim starim detaljima... :palacg
Krenula je u slobodnu prodaju...
http://www.singervehicledesign.com/
pdf. specs
http://www.singervehicledesign.com/content/specs_2011.pdf
Skraćeno:
Chassis and Body
Singer Vehicle Design purchases fully road legal pre‐1994 Porsche 911 Coupes for the
basis of construction. When its transformation is complete, the newly born Singer 911
retains the Vehicle Identification Number (VIN) of its donating ‘parent’ 911
Engine Options:
o 300BHP
o 380BHP
o 425BHP
Transmission
The Singer 911 utilizes the 5 speed Getrag G50 transmission from the 964 series cars
and comes with the option of a limited slip differential.
 A 6 speed Getrag G50 transmission from the 993 series cars with close ratio gear
sets and limited slip differentials is available on all three engine options at extra
cost.
 A single mass flywheel and carbon twin‐plate clutch are fitted.
Transmission Options
1. Limited slip differential for 5 speed G50 transmission.
2. Close ratio 6 speed transmission.
A close ratio 6 speed Getrag G50/LSD unit is available as an option. This
gearbox has ratios specially chosen to maximize the power potential from the
engine for ultimate sporting and track use.
Suspension
 The standard suspension features uprated Bilstein adjustable dampers and coil over
springs.
EVO uprights from the racing 993 models further increases precision and
unsprung weight. The anti sway bars are uprated units from the 964 RS, and
these along with additional suspension components allow greater adjustability
while the advanced damping system can be further stiffened or softened
depending on usage.
Svetinja jest al ovo je dobro odrađeno... mada meni ima nekih detalja koji mi nisu naj rjesenje... :fakjea
p.s slike su izklesane tj takve nađene na netu :rolleyes:
Edited by AUTOFREAK
Skeptik sam malo, jer je original original, ali ovo jako dobro izgleda i što je najbolje, auto je nov :)
ovo i jest orginal (šasija) al ostatak je kao refresh-iran.... tj moderniziran... spešli ovjes i motorizacija...
Edited by AUTOFREAK
Retrovizori, rupa na haubi, sjedala... zašto sve što amer dotakne mora imat dašak Corvete?
Meni je ovo kao da uriniraš na groblje, jednostavno svetogrđe prema autu koje sanjam od djetinjstva.
po meni dobra kombinacija....nije pretjerano
cijena?
uuuuuuu....oce ko kupit golfa?!
nisam naisao na nikakve cijene!? :huh
To je za one koji će popeglat bez pitanja :D Ali meni se onaj zelenko jako sviđa :) Ne znam koliko su dostupni djelovi za restauraciju jedne takve 911ice...
Rupa na haubi je fora od tadasnjeg RSR modela.... a ostali detalji vjerovatno iz porsch-ove proslosti... sumljam da su s tim experimentirali.....
cjena je paprena :palacg
al to je tad jos bio prototip... sad je u prodaji :)
+ ima klimu :)
uuuuu.... auto je za poželit....
svaka im čast....
sve je na mijestu i kak treba biti... baš ono... to je to...
Vrhunski 911, sve u stilu i kako treba biti.
Jedan od najjačih detalja su mi sjedala, tapecirung pod prednjom haubom i čep goriva.
Tek sad vidim da se ovo mene tiče
Evo onda jedan filmić na istu temu
Nemam di bi stavila pa evo ovde https://autozona.rtl.hr/auti-i-ljudi/auti-i-ljudi/porsche-964-krk/ neka Admin premosti di triba ako triba
Poslano sa mog HUAWEI VNS-L21 koristeći Tapatalk
Odličan video Željko, i još bolji auto :) a i brada je umjetnicka :D
