Speedy-RI 0 Posted June 6, 2007 Alpine F#1 status glavna jedinica sa DVD audio / CD reproduktorom, te tunerom. Instalira se samo u kombinaciji s PXI-H990 ili DAI-C990 a o njima mo??ete saznati na dolje navedenim linkovima. Link za PXI-H990 i DAI-C990 LW: 153 - 281kHz ; MW: 531 - 1.602kHz ; FM: 87.5 - 108.0MHz Usable sensitivity LW: 31.6µV/30dB ; MW: 25.1µV/28dB ; FM: 9.3dBf (0.8µV/75?) Stereo separation FM: 45dB or greater S/N ratio FM: 80dB or greater CD/DVD section System: optical (compact disc) Number of quantum bits: 1 bit Number of channels: 2 channels (stereo) Dynamic range: 95dB (1kHz) or greater High frequency distortion ratio: 0.008 % (1kHz) or less Channel separation: 90dB (1kHz) or greater Wow & flutter: below measurable limits Signal system: NTSC / PAL Horizontal resolution: 500 or greater Image output level: 1Vp-p (75?) Image S/N ratio: DVD - 75dB Audio S/N ratio: 115dB or greater Frequency characteristics: CD/DVD video: 5Hz – 20 kHz; DVD audio: 5Hz – 40kHz Remote control Power source: DC 1.5V x 2 (UM-4) Size (W x H x D): 56 x 142.5 x 37 mm Weight: 72 g (excluding batteries) Main unit Power source: DC 14.4V (operational range: 11 – 16V) Size (W x H x D): 178 x 50 x 155 mm Weight: 1.6 kg Power supply unit Size (W x H x D): 160 x 40 x 120 mm Weight: 0.65 kg Cijenu i detaljnije informacije saznajte na ovom LINKU Share this post Link to post Share on other sites
Dottore 0 Posted June 6, 2007 cijena opali po glavi... cirka 16 tisuća kuna Share this post Link to post Share on other sites
Speedy-RI 0 Posted June 6, 2007 cijena opali po glavi... cirka 16 tisuća kuna A hebiga ali radio je stvarno mrcina i pol i to je F1 status radio, znaci najbolji modeli od Alpinea Share this post Link to post Share on other sites
Guest SuperDrive Posted June 6, 2007 16 tisuca kuna za dvd rom je malo previse i jos 17 tisuca za PXI-H990 bez kojeg nece radit jer je samo citac bez pojacala ili sam ja to nesto krivo skuzio? Share this post Link to post Share on other sites
