denisgti 0 Posted December 10, 2014 pozdrav radi se o motoru 2.8 vr6 96 godina. motor na leru radi super ali kada dam naglo gas pocme trokati,kada dajem polako sve uredu.kada istekam onaj plavi senzor temperature prima pun gas odlicno.spajo sam na tester izbacuje gresku senzor bregaste,dali je moguce ta je to zbog tog senzora..kablovi su novi svijecice takodjer,protocnik zraka,oba senzora na kucistu od vode....?hvala Share this post Link to post Share on other sites
jopa_vr6 0 Posted December 10, 2014 (edited) Senzor bregaste meni uvijeek prijavljivao..to mislim da nije problem.. Pumpa goriva?tp senzor? Neznam..jesi pitao cubela Edited December 10, 2014 by jopa_vr6 Share this post Link to post Share on other sites
Beli 7 Posted December 11, 2014 ovo kad daš pun gas pa trokira ti je najvjerojatnije pumpa goriva ili regulator tlaka goriva... i to ti diagnostika neće pokozati.. a kad je greška senzora bregaste, u većini slučaja motor nije bio u 100%-tnoj fazi... ali to se vidi po kodu greške, da nije slučajno senzor neispravan Share this post Link to post Share on other sites
IVAN_VXR 0 Posted December 11, 2014 (edited) Ako daje grešku senzora bregaste logično je da motor nije u fazi kako bi trebao biti tj. da je lanac dao svoje. Na R32 se može i viditi koliko stupnjeva je OFF. edit: beli je bio brzi u odgovoru Edited December 11, 2014 by IVAN_VXR Share this post Link to post Share on other sites
denisgti 0 Posted December 11, 2014 (edited) PROVJERIO SAM DANAS NEMA STRUJE NA STEKERU MORAM VIDJETI PO SHEMI STA JE PROBLEM MOZDA MI NIJE DOBRO STRUJA SPOJENA Edited December 11, 2014 by denisgti Share this post Link to post Share on other sites
projektilski 274 Posted December 11, 2014 NISAM TE DOBRO CUO, DAJ PONOVI JOS JEDNOM! Share this post Link to post Share on other sites
jopa_vr6 0 Posted December 11, 2014 Na stekeru od senzora bregaste? Po auto dati imas sta mjeris..mozda nije napon mozda je otpor.. Share this post Link to post Share on other sites
denisgti 0 Posted December 11, 2014 hrvoje mi kaze da na jednom od tri pina treba imati 12volti da je gledao auto datu jer je on to i spajao Share this post Link to post Share on other sites
denisgti 0 Posted December 14, 2014 Rijeseno u instalaciji se izgubio plus od senzora bregaste spojio I radi odlicno.hvala Share this post Link to post Share on other sites
denisgti 0 Posted January 3, 2015 Molim pomoc opet izludit cu opet izbacuje gresku senzora bregaste I dok je pod cokom prima gas odlicno cim se zagrije kao baba od 100 godina neprima gas I puca na usis jel moguce da je zbog tog senzora,jer promijenio sam protocnik,kablove,svijecice sensor temperature,vise sam lud,hvala Share this post Link to post Share on other sites
najinvr6turbo 0 Posted January 3, 2015 zamjeni senzor protoka zraka luftmess..zna i on zajebavati mada nije 100% probaj Share this post Link to post Share on other sites
denisgti 0 Posted January 3, 2015 Vec sam jedan zamijenio,ali probate cu nabaviti drugi Share this post Link to post Share on other sites
