RoMario44 0 Posted March 25, 2015 Pozdrav ekipa, dal ima neko neku shemu da na RNS 315 stavim karte RH odnosno gdje da ih nabavim a da to puno ne kosta??? Vidim na netu se čak daju i skinuti karte za RNS 510 što nije bed, skinem ih na SD card i prebacim na RNS. Ali meni treba za 315, može pomoć!!! P.S. Nisam znao di otvorit temu pa sam je svrstao ovdje Share this post Link to post Share on other sites
RS G60 0 Posted March 25, 2015 (edited) za 315 imas samo original zato sto ga technisat proizvodi i toliko je zakljucan, da nema nista na netu. Edited March 25, 2015 by RS G60 Share this post Link to post Share on other sites
Darko 0 Posted March 25, 2015 (edited) Ca. 1400 kn u ovlatenom i uživaj Edited March 25, 2015 by Darko Share this post Link to post Share on other sites
RI VW 3 Posted March 25, 2015 Bar ih ima za kupiti, za rns mfd2 ih ni nema...tj ima al samo nesto sitno i to glavne prometnice... Share this post Link to post Share on other sites
RoMario44 0 Posted March 26, 2015 hm...a valjda ce se naci neka shema, nesto mora postojat bez ovlastenog, pa to je ludost dat tolke pare... Share this post Link to post Share on other sites
RoMario44 0 Posted March 26, 2015 Gledam na netu na torentu ima za skinuti karte za rns 315 east europa ali nesto mi nece download krenuti... Share this post Link to post Share on other sites
Dario_7R 28 Posted March 26, 2015 skini mape i zbrikaj uređaj NE postoje mape sa torrenta /stranica itd itd koje rade na rns315 i točka ali samo izvoli dobit ces neupotrebljiv uredaj Share this post Link to post Share on other sites
RoMario44 0 Posted March 27, 2015 hhhhhh....velis ha Share this post Link to post Share on other sites
MarioIV 10 Posted March 27, 2015 imenjace, nemoj pokvarit radio...istekla ti garancija Share this post Link to post Share on other sites
Darko 0 Posted March 27, 2015 Ako neproba neće nikad znati :-) Share this post Link to post Share on other sites
RoMario44 0 Posted March 27, 2015 Hehehe imenjace imas pravo radije ne dirat dok ne istekne garancija A cekat cemo...dok se ne razvije neka shema Share this post Link to post Share on other sites
master 0 Posted March 27, 2015 Stavi ga na ebay, kad ode, nadoplati za rns 510 i uzivaj Share this post Link to post Share on other sites
fakefucker 0 Posted March 29, 2015 Di ima za skinut te mape,baš sam svoju slucajno zbriso s sd kartice i sad trazim di ima. Ak imate neki link. Share this post Link to post Share on other sites
Nikki 0 Posted March 30, 2015 Dakle stvarno ti je tesko procitati topic Share this post Link to post Share on other sites
m3 power 3 Posted January 21, 2017 Od nedavno se karte mogu stavit u auto i u kucnoj radinosti. Nasao sam proces negdje na netu ali se nisam zamarao jer sam vec dogovorio s likom za 300kn. I nisam bas pri vremenu. Ali lik mi je dofurao najobicniju sd karticu koju mu moram vratit. Ono sta sam procitao, karte se skidaju s torenta, sd se potpisuje preko nekog programa u linuxu i stvar funkcionira. Poslije instalacije kartica je mrtva ali je se moze formatirat sa necime u linuxu. To su samo osnove jer se nisam trudio saznat vise. Share this post Link to post Share on other sites
polic na kvadrat 25 Posted January 21, 2017 I znaci V 8 karte šljakaju onda i na 315 sa sd kartice? Share this post Link to post Share on other sites
m3 power 3 Posted January 21, 2017 I znaci V 8 karte šljakaju onda i na 315 sa sd kartice?Da. Mozes ih instalirat ili koristit sa sd kartice. Kad piknes karticu auto punudi use sd or install. Share this post Link to post Share on other sites
m3 power 3 Posted January 21, 2017 (edited) Evo tutoriala. Ja cu probat jednom kad nadjem vremena 1 - Card EVO + (I tried 32G and 64G SD) 2 - FAT32 formatted card (in Windows) and copy navpsf_update in rrot (corrected) 3 - Install Ubuntu 32/64 (64's what I used) 4 - Copy local (Desktop linux) folder VW 5 - open the copied folder and right cick -> "open terminal" 6 - check with the command execution rights "ll". You must have attributes besides "r", "w" and a "x". If there is an X writes: "chmod 777 mmc32" linux if you have 32 or "chmod 777 mmc64" if you have linux 64. And the rights and check the "ll" 7 - Insert the SD slot. Terminal command "df" and verify the name card. Somewhere down everything must occur "mmcblk0" + p + a number. The suffix p "number" is the partition on the card, we are not interested, just use "mmcblk0". CID To read the original SD: cat / sys / block / mmcblk0 / device / cid xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 8 - Order To change CID terminal: - Linux 32 sudo ./mmc32 prog_cid / dev / mmcblk0 5d53424c32424d31013917ca53010400 - Linux 64 sudo ./mmc64 prog_cid / dev / mmcblk0 5d53424c32424d31013917ca53010400 After this command will display: Writing new CID: 5d53424c32424d31013917ca53010400 Success! Remove and Reinsert SD card to check new CID. To read the SD CID changed: SD disassemble and remove it from the linux PC SD reader, and then paste it into the PC cat / sys / block / mmcblk0 / device / cid will be displaying the new CID 5d53424c32424d31013917ca53010400 9 - To lock SD terminal command: - For Linux 32 sudo ./mmc32 lock_sd / dev / mmcblk0 C99A20843ED7D90B6801E49F2BC80277 - For Linux 64 sudo ./mmc64 lock_sd / dev / mmcblk0 C99A20843ED7D90B6801E49F2BC80277 After this command will display: SEND_STATUS response: 0x00000900 Remove the card and fuguta car ..! 1. Link to download the content of the maps for RNS315 V8 East Europe. https://archive.org/details/RNS315 here you and .zip torrent OR https://ufile.io/eba56 2.You Need a Linux (Ubuntu) PC with integrated SD card reader. Linux 64bit 3.Only works with Samsung EVO + SD (Red One) Steps: Extract and copy the content on the SD top folder is navpsf_update Look under / dev to see SD is yours Which, in my case it is mmcblk0 Copy folder on Desktop Linux and open folder CID VW Right click here and select "open terminal" In the "terminal" put command: sudo -s Change the execution rights: chmod 777 mmc32 or chmod 777 mmc64 if you have 32 or if you have linux linux 64 Read original CID cat / sys / block / mmcblk0 / device / cid After this display original Will CID command: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Change the CID with the attached tool Password command you know from Below: - For Linux 32 sudo ./mmc32 prog_cid / dev / mmcblk0 5d53424c32424d31013917ca53010400 - For Linux 64 sudo ./mmc64 prog_cid / dev / mmcblk0 5d53424c32424d31013917ca53010400 After this command Will display: Writing new CID: 5d53424c32424d31013917ca53010400 Success! Remove and Reinsert SD card to check new CID. Reinsert the card and remove it Read new CID cat / sys / block / mmcblk0 / device / cid After this command Will new CID display: 5d53424c32424d31013917ca53010400 Now lock the card by password, it's not possible to unlock it with normal MMC Driver, You Need a patched version of the kernel to be Able to unlock it. Password command you know from Below: - For Linux 32 sudo ./mmc32 lock_sd / dev / mmcblk0 C99A20843ED7D90B6801E49F2BC80277 - For Linux 64 sudo ./mmc64 lock_sd / dev / mmcblk0 C99A20843ED7D90B6801E49F2BC80277 After this command Will display: SEND_STATUS response: 0x00000900 Enjoy your new maps! http://richard.burtons.org/2016/07/31/ci...oplus_cid/ https://www.youtube.com/shared?ci=6nxUl2xBvZ4 Izgleda da postoji problem sa mjenjanem CID-a na nekim karticama. Evo cijeli threda sto sam nasao pa kome se da zafrkavat... dakle moze se. Samo je pitanje kome se da s tim zezat. https://www.google.hr/url?sa=t&source=web&rct=j&url=http://cartechnology.co.uk/printthread.php%3Ftid%3D19023&ved=0ahUKEwi5s5v43dPRAhXF0xQKHfNQDDQ4ChAWCCQwBQ&usg=AFQjCNEP0xaaIwCyyV9DlVwFGAQkIhXFZQ&sig2=OoEiViYV44Znlcg_TPgBOA Edited January 21, 2017 by m3 power Share this post Link to post Share on other sites
stom 0 Posted January 21, 2017 Ja sam prije kojih 4 mjeseca kupio sd karticu sa mapom Hrvatske i ostalih zemalja za RNS 315, platio 400kn i sve radi odlicno. Kada se ubaci sd kartica on pokrece instalaciju koja traje cca sat i pol i pohrani ju na njegov hard. Ta sd kartica moze sluziti samo za taj radio. Share this post Link to post Share on other sites
RoMario44 0 Posted January 21, 2017 M3 svaka ti čast za ovo odakle si ovo iskopao strava...ja bi sebi to volio napravit ali ovo mi je jebenica malo žeća...ba me zanima hoće tko sa foruma uspjet... Stom - gdje si kupio za tu lovu ja sam naao najpovoljniju za 100 E....? Imaju neka dva različita lika na njukalu m3 to od jednog od njih uzimas,aj ba kad napravi javi da znam i ja ! Share this post Link to post Share on other sites
m3 power 3 Posted January 22, 2017 M3 svaka ti čast za ovo odakle si ovo iskopao strava...ja bi sebi to volio napravit ali ovo mi je jebenica malo žeća...ba me zanima hoće tko sa foruma uspjet... Stom - gdje si kupio za tu lovu ja sam naao najpovoljniju za 100 E....? Imaju neka dva različita lika na njukalu m3 to od jednog od njih uzimas,aj ba kad napravi javi da znam i ja ! Uzeo od lika s njuskala. Imas jednog iz zg i jednog iz krizevaca. Ja sam uzeo od ovog iz zg-a. Pokrene instalaciju, traje cca sat i pol i poslije se vrati po svoju karticu i to kosta 300kn. Ako hoces da ti ostavi karticu onda 500kn. Share this post Link to post Share on other sites
nikica.misic 1 Posted January 22, 2017 (edited) Evo koliko košta originalana iz VW-na. Ja se nebi igrao.... Uzmeš na 3 rate Poslano sa mog SM-G920F koristeći Tapatalk Edited January 22, 2017 by nikica.misic Share this post Link to post Share on other sites
m3 power 3 Posted January 22, 2017 Ma uzmem na 3... 1100kn... pa nisam s kruske pao da im placam nekaj 3.5X vise. Share this post Link to post Share on other sites
polic na kvadrat 25 Posted January 22, 2017 (edited) Da. Mozes ih instalirat ili koristit sa sd kartice. Kad piknes karticu auto punudi use sd or install.Genijalac sam ... koma...Malo sam istrazivao i nasao koji je model kod mene u auti iako je kao 315 unutra ipak nije nego 310 Valjda moze i na mom modelu šljakati s kartice ili ipak ne? Edited January 22, 2017 by polic na kvadrat Share this post Link to post Share on other sites
