<TDI> 416 Posted February 13, 2016 Nema veze, ionako sam mislio uzeti jedan pa isprobati.Hvala na infu. Edit: Našao sam opis mirisa. "An adventurous, masculine fragrance with an air of mystery." Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 13, 2016 I aj ti sad to prevedi na hrvatski onima koji npr. ne razumiju? Totalno debilno zvuci ?? Share this post Link to post Share on other sites
bruiser 0 Posted February 13, 2016 Mirisi nesto kao muski parfem, aftershave Share this post Link to post Share on other sites
said 3 Posted February 13, 2016 tako je...neki jak miris je...meni odlican...nije nikakvo voce i slicno a sta je s onim wunderbaum clip...jel to tko probao, to je nesto novo? Share this post Link to post Share on other sites
Royal mk7 0 Posted February 14, 2016 Ja imam wunder-baum clip sport...(ovaj drugi po redu tamno plavi) odličan je nije pre intenzivan a evo već skoro 4 tjedna mi je u autu i osjeti se kao prvi dan....stari ima ovaj tropical,isto kao i sport malo "mekši" nezz kako drugačije da opišem....uglavnom ako netko razmišlja o kupnji isplati se i traje dugo... Share this post Link to post Share on other sites
tommek10 7 Posted February 14, 2016 Di ima za kupit clip sport? Share this post Link to post Share on other sites
Royal mk7 0 Posted February 14, 2016 imaš u svakom intersparu,kauflandu i autopraonici u N.zagrebu.... Share this post Link to post Share on other sites
said 3 Posted February 14, 2016 Ja sam ih vidio na INI mislim da je bilo 25kn cjena... Share this post Link to post Share on other sites
tommek10 7 Posted February 14, 2016 Plodine? lidl? konzum? Nema bas kod mene interspara i kauflanda... svakako cu probati jer mi se cine prakticni i jos ako toliko drze super Share this post Link to post Share on other sites
master 2 Posted February 14, 2016 Imas u plodinama, koristim ih i meni su super Share this post Link to post Share on other sites
Royal mk7 0 Posted February 15, 2016 Ima na ini malo prije tocio gorivo 25 kn....said zna... Share this post Link to post Share on other sites
said 3 Posted February 15, 2016 Jel je 25? Nisam siguran u cijenu...sutra cu bas stat da natocim pa cu uzet jedan da vidim kakv je...taman ova usteda sto ce pojeftinit benzin ostane za jedan miris ? Share this post Link to post Share on other sites
master 2 Posted February 15, 2016 (edited) Meni je ovaj tropical najbolji, paše mi uz boju auta Trenutno čekam da se ovaj od vanilije potroši Edited February 15, 2016 by master Share this post Link to post Share on other sites
said 3 Posted February 16, 2016 Evo uzeo i ja 1 od vanilije(nije bilo drugih kaze rasprodalo se) Cijena 23,99kn Nije los za sad...osjeti se onako ugodno nije zestok ko boric od vanilije...vidjet cemo koliko ce trajat Share this post Link to post Share on other sites
master 2 Posted February 16, 2016 Samo da napomenem, ok mozda sam ja lud al tako sam primjetio kod tih clip, ovaj dio u boji okreni prema retrovizoru, ne sajbi, jer kad je sunce onda isparava i kao da masti sajbu. Share this post Link to post Share on other sites
kostolomac_cro 13 Posted February 16, 2016 Uzeo neki dan da isprobam od Alfa cara 21kn. Nije jak miris, kao neki da te ubije kad uđeš u auto. Za sad mi se sviđa, ima više verzija pa ću ih sve isprobat. Share this post Link to post Share on other sites
RI VW 4 Posted February 16, 2016 Di sve te borice i te bočice okacite a da nije retrovizor? Share this post Link to post Share on other sites
said 3 Posted February 16, 2016 Ja samo na retrovizor i nigdje vise Iako sam vidio i na onim rukohvatima iznad glave odozad i oko rucice mjenjaca itd Share this post Link to post Share on other sites
kostolomac_cro 13 Posted February 16, 2016 (edited) Samo retrovizor, zato mi i odgovaraju ovi sam užetom Pa ne staviš 10 komada odjednom, borića i bočica, iako ima i takvih Edited February 16, 2016 by kostolomac_cro Share this post Link to post Share on other sites
master 2 Posted February 16, 2016 Ako je boric u pitanju onda okacim o kopcu od pojasa, tako da je izmedju sjedala i ne ubija pod nosom i mrzim kad mi nešto visi iznad glave Zato i koristim taj clip da ga ne vidim, a ako uzmem boric onda dolje za kopcu i nek visi Share this post Link to post Share on other sites
markol5 15 Posted February 16, 2016 Ja borice sve ispod volana malo ih skratim da ne diram nogama i ne smetaju Share this post Link to post Share on other sites
Dottore 0 Posted February 16, 2016 Uzeo neki dan da isprobam od Alfa cara 21kn. Nije jak miris, kao neki da te ubije kad uđeš u auto. Za sad mi se sviđa, ima više verzija pa ću ih sve isprobat. Samo pazi da ne iscuri po klimama. Bit će puno fleke nagrizanih. Share this post Link to post Share on other sites
rox 6 Posted February 16, 2016 Di sve te borice i te bočice okacite a da nije retrovizor? Di sve te borice i te bočice okacite a da nije retrovizor? Ispod naslona za glavu, izvadis naslon, stavis oko nosaca i uguras nazad. Lijepo se osjeti miris i ne visi mi ispred glave. Share this post Link to post Share on other sites
said 3 Posted February 16, 2016 Samo pazi da ne iscuri po klimama. Bit će puno fleke nagrizanih. Bas sam gore pisao o tome rasuo se i ostale fleke od toga uspio sam ocistit al jos se malo vidi Share this post Link to post Share on other sites
projektilski 274 Posted February 16, 2016 Treba paziti s tim bocicama ali mislim da je to najbolje i najdugotrajnije rijesenje Share this post Link to post Share on other sites
