tommek10 7 Posted March 17, 2016 Jeli imao tko problema s spuzvom ispod poklopca (plastike) motora??? Moja se pocela mrviti i otpadati i to dost ruzno izgleda kad se skine. A mislim da da plastika i malo se cuje kad se vozi. Razmisljao sam neku spuzvu zaljepit ispod umjesto ove stare jel plastika je ko nova. Ima tko kakavih ideja?? Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 (edited) Imas vec govora o tome ako uspijem nac link objavit cu ima izolacija koja se kupi i ispila po tvojoj,nije puno novaca Evo ga http://www.vwclubcroatia.com/forum/index.php?/topic/80302-Izolacija-poklopca-motora Edited March 17, 2016 by markol5 Share this post Link to post Share on other sites
D.M 0 Posted March 17, 2016 Armaflex,ima u par tema ? Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 Evo taman naleti na netu u Splitu firma sto ga prodaje odmah mi je ispod stana,sad cu se spustit i vidit sta kazu i koja je cijena. U mene je jos cijela,meni ne treba,al svejedno. Share this post Link to post Share on other sites
tommek10 7 Posted March 17, 2016 Marko aj ispitaj pa javi... a gdje bi moglo biti armaflexa za kupit, koliko sam na brzinu procitao za centalno gdijanje oprema jos mozda gdje? Share this post Link to post Share on other sites
kostolomac_cro 13 Posted March 17, 2016 Feroterm, Petrokov, Mariterm..... Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 (edited) 90kn 1m2 imaju dvi debljine,13 i 19,preporuca mi deblji. Nije puno naspram ovlastenog. Edited March 17, 2016 by markol5 Share this post Link to post Share on other sites
tommek10 7 Posted March 17, 2016 19 mm? mislim da 1 kvadrat dosta ima a s cim ga pricvrstit na plastiku da stoji?? Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 Da. Dosta kvadrat. Samoljepljiva je Share this post Link to post Share on other sites
dr.restaurator 5 Posted March 17, 2016 koja to firma u splitu ima? Share this post Link to post Share on other sites
<TDI> 404 Posted March 17, 2016 Isti problem sam imao sa poklopcem i riješio sa 19mm Armafleksom prošle godine. Bolje nego OEM spužva koja se raspala i puno je tanja od Armafleksa kojeg sam stavio. Dolje ti je link do teme, post #54 ako ti zatreba koji dodatni podatak oko izrade, ima posla ali se isplati.PVC POKLOPAC MOTORA (IZOLACIJA)...http://www.vwclubcroatia.com/forum/index.php?/topic/81663-vw-golf-iv-19-tdi-130-ps/page-3 Share this post Link to post Share on other sites
vlaho 2901 1 Posted March 17, 2016 Morat cu i ja to napravit, jer ja ispod same plastike od poklopca motora nemam nista. I ta plastika malo i klepece.. Anaton Marko jeli mozes pitat salju li postom mozda? Da ne trazim po Vinkovcima di ima to za uzet.. Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 Mogu,vidim ovih dana pa cu ti javit Share this post Link to post Share on other sites
vlaho 2901 1 Posted March 17, 2016 Hvala puno! Platim sendvic u Popaju kad budem u Splitu.. ?? Share this post Link to post Share on other sites
<TDI> 404 Posted March 17, 2016 Kod mene je sada sve tiho ispod poklopca ali me izludjuju cvrcci od kutije filtera zraka. Sve pokusao, podmazao, nosace, stavio kockice armafleksa izmedju kutije zraka i akumulatora ali nista ne pomaze. Najvise se cuje dok radi u leru a nikako da nadjem gdje je problem. Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 Nemoj sendvice,ja sam u Rizza Joker,svrati kad budes ja castim Share this post Link to post Share on other sites
markol5 15 Posted March 17, 2016 Kod mene je sada sve tiho ispod poklopca ali me izludjuju cvrcci od kutije filtera zraka. Sve pokusao, podmazao, nosace, stavio kockice armafleksa izmedju kutije zraka i akumulatora ali nista ne pomaze. Najvise se cuje dok radi u leru a nikako da nadjem gdje je problem.Za koliko se smanji buka motora kad se stavi nova izolacija? Jel se bas osjeti razlika ili je neznatna? U mene je golf dosta bučan,izolacija je ok skroz,nije se poderala,al ako ce se smanjit buka idem odma na novu soluciju. Tamam sam gleda kod tebe u temi kako si radio,sve pod "liver" Share this post Link to post Share on other sites
Dottore 0 Posted March 17, 2016 E tooo, baš mi treba na Polu iz 2003. Spužva je raspala skroz Share this post Link to post Share on other sites
tommek10 7 Posted March 18, 2016 Isti problem sam imao sa poklopcem i rijeio sa 19mm Armafleksom prole godine. Bolje nego OEM spužva koja se raspala i puno je tanja od Armafleksa kojeg sam stavio. Dolje ti je link do teme, post #54 ako ti zatreba koji dodatni podatak oko izrade, ima posla ali se isplati. PVC POKLOPAC MOTORA (IZOLACIJA)...http://www.vwclubcroatia.com/forum/index.php?/topic/81663-vw-golf-iv-19-tdi-130-ps/page-3 Samo mislim da je 19 mm malo previse jer ona oem nije niti centimetar debela. Mislim da je onda prikladnija 13mm. Share this post Link to post Share on other sites
<TDI> 404 Posted March 18, 2016 Za koliko se smanji buka motora kad se stavi nova izolacija? Jel se bas osjeti razlika ili je neznatna? U mene je golf dosta bučan,izolacija je ok skroz,nije se poderala,al ako ce se smanjit buka idem odma na novu soluciju. Tamam sam gleda kod tebe u temi kako si radio,sve pod "liver" Nisam radio test da vidim koliko je razlika u buci, sa i bez, tako da ti ne mogu konkretno reći. Imam snimljen audio zapis bez izolacije a mogu naknadno snimiti i ako se osjeti onda više nije rekla, kazala a sa mjeračem decibela bi točno znao. Ujedno izloacija se ne stavlja samo radi buke koja mu je istina primarna funkcija, nego da utiša plastični poklopac koji zna dosta vibrirati i klepetati što je čest slučaj. Samo mislim da je 19 mm malo previse jer ona oem nije niti centimetar debela. Mislim da je onda prikladnija 13mm. Armafleks od 19mm je taman, iako je OEM puno tanji ali je zato kao izolator buke sa tom debljinom ipak bolji od 13mm, ujedno naliježe perfektno kod mene. Ako misliš da je 13mm bolja opcija stavi 13mm jer ni sa tom debljinom nećeš pogriješiti. Share this post Link to post Share on other sites
projektilski 274 Posted March 18, 2016 Posto je svrha poklopca cisto vizualne prirode, cisto sumnjam da ona zastita ispod poklopca smanjuje buku nego vise sluzi za uklanjanje vibracija. Posto se i meni ta spuzva raspala, ja cu ici na 13mm debljinu. Share this post Link to post Share on other sites
vlaho 2901 1 Posted March 18, 2016 Ja bi isto uzeo 13mm.. na brodu sam pa ne mogu normalno surfati po internetu, pa ako neko moze neka napise koja su svojstva tog Armafleks-a. Hvala unaprijed! Share this post Link to post Share on other sites
<TDI> 404 Posted March 18, 2016 Opis proizvoda:Armaflex je fleksibilan elastomerni materijal baziran na vulkaniziranoj sintetičkoj gumi zatvorenih ćelija. Vrlo je fleksibilan i postojan. Fina ćelijska struktura materijala omogućuje dobru termičku iskoristivost. Njegove tehničke karakteristike garantiraju izvrsna izolaciona svojstva i kontrolu kondenzacije.Zvučna izolacija:Redukcija prijenosa zvuka po instalaciji...Izolacijski učinak do 30dB(A)...................D 3660...DIN 52219 i DIN EN ISO 3822-1Koeficijent apsorpcije zvuka.................................................do 0,56.........................D 2551...EN ISO 20354Nije zapaljiv, isprobao osobno. Share this post Link to post Share on other sites
markol5 15 Posted March 18, 2016 Sta mislite o armasound-u? Bi li bio bolji od flexa? Share this post Link to post Share on other sites
