22 22
RI VW
VCDS - Sva pitanja i pomoc
Probaj ponovo instalirat program
Meni nekad to pokaze i samo ponovo instaliram i radi
Momci i cure, vcds 17.8 radio normalno i nakon stajanja par miseci u ladici u kuci danas nece, izbaciva poruku da nije povezan sa autom. Ima li mu spasa ili je gotov, kabel je kineski
Da nije pokupio update... ako si bio ne netu s tim racunalom.
Probao i ne pomaze, probat cu jos na drugi komp
Nije bio na netu, laptop osto nisam palio par mjeseci, a odis se spajao bez problema tako da nije ni do auta, jedino ako nisam ugasio antivirus skroz, mada mi je win defender onemogucen
Pozdrav!
Da li netko zna procitat fault kodove iz VCDS auto iscitavanja ?
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAP076703 Mileage: 268900km-167086miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 B HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9971
Revision: --H23--- Serial number: 00000000000000
Coding: 00114016030400080000
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_ECM16TDI02103L906023B 003011
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: 2540C90824E1076ED9-8070
1 Fault Found:
7300 - Throttle Position Sensor (G69)
P0123 00 [175] - Signal too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 34 °C
Intake air temperature: 16 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.311 V
Unlearning counter according OBD: 40
Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.990 V
Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
Readiness: 0000 0000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B200D09290000881204E4901C00403000
Shop #: WSC 00028 028 00001
VCID: 74E6E44CD7BB2EE69E-8020
No fault code found.
Address 08: Auto HVAC (J255) Labels:. 5K0-907-044.clb
Part No SW: 5K0 907 044 BC HW: 5K0 907 044 BC
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00028 028 00025
ASAM Dataset: EV_Lcimatronic A01001
ROD: N/A
VCID: 6DD0F128BC91FF2E51-8038
No ASAM data for: "EV_Lcimatronic" (VW36 *)
2 Faults Found:
9474418 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 268394 km
Date: 2018.11.09
Time: 13:03:25
9481988 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 4
Mileage: 268394 km
Date: 2018.11.09
Time: 13:03:25
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 B HW: 1K0 937 084 B
Component: BCM PQ35 B 103 0573
Revision: 00103 AF
Coding: 00180A3A983A16C040000080100000E443010088524D8160648000200000
VCID: 2D50312874113F2E11-8078
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 08100 21 0501
Coding: 009795
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 268394 km
Time Indication: 0
Date: 2013.04.01
Time: 13:03:25
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12920928704341
Coding: 100001
VCID: 36621E4481477CF660-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 036 0604
Serial number: 003C2D0H3WC8
Coding: 00003139
Shop #: WSC 01383 790 00064
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FCD340CECD45FEBB-8022
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 1547444CZZZZZZZZZZZZ
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3724464CZZZZZZZZZZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 043D3D5CZZZZZZZZZZZZ
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 18093D57ZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 0304B7904215195E97-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 860 G HW: 5K0 920 860 G
Component: KOMBI H06 0206
Coding: 070B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 306E285C6B2352C63A-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 091009F2000740
Coding: E9A07F06000202000002
VCID: 66C28E045167CC7610-8032
1 Fault Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 244
Mileage: 268394 km
Time Indication: 0
Date: 2013.04.01
Time: 13:03:27
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H06 0206
Serial number:
ASAM Dataset: EV_Imm_oUDS_VDD_RM09 A03004
ROD: N/A
No ASAM data for: "EV_Imm_oUDS_VDD_RM09" (VW36 *)
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2123
Coding: 0000180
VCID: 33642750523569DE47-8066
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H17000
Shop #: WSC 00000 000 00000
VCID: 2F6C2B20BE1D4D3E23-807A
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Coding: 0000436
VCID: 356019485C4177EE69-8060
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 3466244C573B6EE65E-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
End-------------------------(Elapsed Time: 02:07)--------------------------
Pozdrav!
Ne znam koje auto ti je upitanju. Prva greska na motoru ti je senzor izduvni gasova ili samo zacepljena gasna klapna senzor moze biti da je otisao ili da je ostao bez napona ali prije da je otisao. Oatale greske samo ponisti dijagnostikom i vidi da li se vracaju jer u 80% slucajeva je da si nekad ostao bez struje u autu akumulator slab skidana klema itd...
Edited by paja_dino
Golf 6 TDI 77kw da istekalo se nesta na motoru kad je majstor nesta drugo mjenjao pa zaboravio ustekat ili je slucajno zapeo :)
moze pomoc, prva znam koja je greska sad promjenili turbinu pa isao obrisati ali neznam drugu sta je. obrisao i nju i ponovno ocitao je i nema je ali me zanima sto je. koliko sam ja shvatio moram dijagnostiku aktivirati ili sta vec
Edited by jooka
Inačica Shareware, dekodiranje svih DTC-a molimo registrirajte se aktivirajte
Sent from my SM-N950F using Tapatalk
gdje , sta? mozes mi malo objasniti.
Verzija softwarea je shareware. Nije aktivirana pa ne čita sve greške
Gdje si dijagnostiku nabavio?
ma na ebayu par kuna, i dosad je sve uredno radilo i sad kad sam ocitao greske tj. da iste obrisem pojavila je ta druga. ova prva je zbog turbine jer je stekala pa kako sam istu promjenio ajd reko idem obrisati kad i tamo ova druga.
neznam ni kako ju aktivirati i jel uopce smijem i sto dobivam s tim
Mozda sam s tim pitanjima dosadan ako netko moze reci koje greske sad biljezi ?Mozda nesto nije dobro podeseno ili je krivo podesene radi se o Golf 6 1.6. TDI 77kw!
Thursday,29,November,2018,15:18:12:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
Scan: 01 03 08 09 0F 10 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
ASAM Dataset: EV_EC1M6TDI02103L906023B 003011
ROD: N/A
No ASAM data for: "EV_EC1M6TDI02103L906023B" (VW36 *)
Revision: 00H35001
1 Fault Found:
02781 - ASR/ESP Button (E256)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 71
Mileage: 269450 km
Time Indication: 0
Date: 2039.14.08
Time: 15:23:09
Freeze Frame:
Count: 0
Count: 32770
Count: 4608
Count: 156
Count: 50688
Count: 1
Count: 0
Count: 0
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
2 Faults Found:
9474418 - Motor for Front Air Distribution Flap
B1091 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 269341 km
Date: 2103.14.06
Time: 11:18:18
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 40
Reset counter: 75
Mileage: 269364 km
Date: 2103.14.07
Time: 09:30:15
Revision: 00103 AF
Coding: 009795
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 17
Mileage: 269341 km
Time Indication: 0
Date: 2039.14.06
Time: 11:18:18
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
OFF
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 73
Mileage: 269758 km
Time Indication: 0
Date: 2039.14.13
Time: 18:47:46
Freeze Frame:
Term 15 Off
Voltage: 12.70 V
OFF
ON
Term 50 Off
OFF
OFF
Address 0F: Digital Radio
Cannot be reached
Coding: 100001
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Coding: 00003139
ASAM Dataset: EV_AirabVW10SMEVW360 A01009
ROD: N/A
No ASAM data for: "EV_AirabVW10SMEVW360" (VW36)
Coding: 0000004
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Coding: 070900
ASAM Dataset: EV_Kmobi_UDS_VDD_RM09 A04040
ROD: N/A
No ASAM data for: "EV_Kmobi_UDS_VDD_RM09" (VW36 *)
1 Fault Found:
9453074 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 75
Mileage: 269844 km
Date: 2103.14.14
Time: 12:20:37
Coding: E9A07F06000302000002
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 269341 km
Time Indication: 0
Date: 2039.14.06
Time: 11:18:20
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Coding: 0000180
Revision: 00H17000
Coding: 0000436
Address 56: Radio
Cannot be reached
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 02:08)--------------------------
Hvala!
Edited by Jole112
Problem sa vcds, u pitanju golf 4 2002g
Sve se normalno spajalo i na jendom nece pise "no response from controller" skinem klemu, vratim i spoji se jednom, izadem i opet nece..
To se desava smao kad ulazim u engine, airbags i central electric
Poslano sa mog FIG-LX1 koristeći Tapatalk
Ma jesam vec 5 puta ali nista ne pomaze..
Mozda je do vcds nesta jer ovaj kad mi se spojio da iscita mapu isto nije mogo se spojit, skinili klemu i dalje sve normalno sljakalo dok nisam opet vcds prikopco
Edited by klikiTDI
Dečki jel se susreo tko s ovim i da probam ju aktivirati ili da se nespajam na internet?
Hm. Da nije negdje prekid kabela.
Probo na se spojit na drugu cetvorku i sve normalno
Šta je bolje uzeti OBDELEVEN ili HEX V2 VAG COM 18.9 VCDS
bok
Zašto moj modul ne prihvaća sigurnosni kod 31347  - Central Electronics.
Dali se to promijenilo u 2014. automobilima
Hvala vam.
Pitanje za korisnike sklad66 kabela...
Obzirom da mi 17.13 ne prepoznaje tiguana maloprije sam naručio i ja kabel i platio preko paypal-a... piše između 3 i 8 dana dostava ali me zanima za update...
Nisam shvatio da li smije iz aplikacije chekiranje updejta ili samo preko linka koji oni daju?
Upravo sam instalirao 18.90 iz foldera koji mi je bugar dao i automatski je nakon instalacije pitao za updejt preko vag com aplikacije i to sam skinuo i instalirao 18.91 veličine 48462kb...
Moje pitanje je da li vam odgovara ta veličina fajla da mi nije povukao službeni updejt pa da ne sje... kabel...
Hvala
btw. za 3-8 dana prodajem 17.1.3. koji uredno radi :)
Mozes i iz same aplikacije i preko linka koji ti se instalira u start menu. Krekana verzija provjerava na krekanom serveru :D
Velicina je tocno 49516544 bytes taj 18.9.0
Da li tko spajao novog tiguana na vcds?
Stigao mi sklad66 kabel i skinuo update ali na autoscanu imam hrpu "no ASAM data"...
Ne mogu kodirati ništa...
Auto je mjesec dana star...
Chassis Type: 5N (3Q0)...
22 22
