RAZZOR 1 Posted August 24, 2016 (edited) E ovako, Na kvwarner touru sam ostao bez gasa i bacio mi ovu gresku. Maf i map uzeti s drugog auta --> opet isto. gresku baca na davanje kontakta i auto mi je odmah u safe modu. Ponistim gresku prije paljenja auto ide normalno ali jako dimi na ubrzavanju (vjerojatno ocitava vise zraka nego sto treba pa mu siba vise goriva) jer ulje je i dalje na maksimumu. Vakumi istestirani, takodjer sve uredno.Ima li ko koju pametnu prije nego raskupusam instalaciju? 18000/P1592/005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation Possible SymptomsMalfunction Indicator Light (MIL) active Limp Mode active Possible CausesGround Spots corroded Wiring from/to Boost Pressure Sensor (G31) faulty Boost Pressure Sensor (G31) faulty Possible SolutionsCheck/Clean Ground Spots Check/Replace Wiring from/to Boost Pressure Sensor (G31) Check/Replace Boost Pressure Sensor (G31) Edited August 24, 2016 by RAZZOR Share this post Link to post Share on other sites
marko-zd 0 Posted August 24, 2016 Ja bi se samo nadoveza da map senuzor dobija napon. Cudno je sto auto odma daje gresku na kontaktu. Ja nisan ima vrimena se pozabaviti s tim al bi volija znati sto je problem na kraju bija. Share this post Link to post Share on other sites
Beli 7 Posted August 24, 2016 instalacija je problem 100% Share this post Link to post Share on other sites
projektilski 274 Posted August 24, 2016 Kaj nije netko pricao da taj hebeni altitude sensor zna radit probleme? Sent from my SM-G900F using Tapatalk Share this post Link to post Share on other sites
marko-zd 0 Posted August 24, 2016 instalacija je problem 100%Ja sam isto sumnja na instalaciju. Brzinski je pogledano samo i map senzor ima napajanje e sad tribalo bi viditi dalje. Al ono sto buni je to kaf se greska obrise auto ide dalje normalno do ponovnog gasenja i davanja kontakta koliko se sican Share this post Link to post Share on other sites
RAZZOR 1 Posted August 24, 2016 (edited) Da. Ako obrisem gresku poslje davanja kontakta a prije paljenja onda auto ide normalno ali dimi. Nista bacam se na kupusanje instalacije Edited August 24, 2016 by RAZZOR Share this post Link to post Share on other sites
Beli 7 Posted August 25, 2016 Kad otvoris instalaciju, vidit ces da ima za popravit jos koja zica a sad se nije javila ko problem Share this post Link to post Share on other sites
Mouse-RI 3 Posted August 25, 2016 Kaj nije netko pricao da taj hebeni altitude sensor zna radit probleme? Sent from my SM-G900F using Tapatalk Takve probleme je prijatelju taj senzor na puntu radio... Share this post Link to post Share on other sites
bushido 1 Posted November 15, 2019 stari topic ali isti problem... Svjetli check engine lampica, greska je P1592 ..sve vec opisano u topicu... Bez snage je .... ugasim upalim i sve normalno dalje, vozi i poteze... Nakon nekog vremena sam ugasi check engine lampicu i naravno upali nakon nekog vremena..i onda opet jovo-nanovo.. U medjuvremenu zamjenio MAP senzor.. 4 dana ok i evo lampice opet.. Instalacija?? Share this post Link to post Share on other sites
