Bube 1 Posted September 27, 2017 Prodajem nesto muzike za auto sto mi jeo ostalo viska. Audofilske komponente, mint stanje, nikad silovano, bile su u autu u kojem je muzika slozena za sto kvalitetniji sound a ne za natjecanja ili pijana odvijanja narodnjaka na najjace. Woofer: Focal KX27 u Polyglass kutiji - 2200 kn Pojačalo 2 kanala: DLS RA20, 1000 TV tuner: Alpine TUE-T150DV, 1000 kn KONTAKT NA 091/592 55 32 (moze sms, Viber, Whatsapp) ili u INBOX! CIJENE NISU FIKSNE Moguce zamjene za kvalitetan set zvucnika 165 mm, zimske gume 205/55/16, tablet, Gopro itd. > Besplatno dostava za Vel. Goricu, Zagreb, Sisak i okolocu, te Moslavinu ------------------------------------------ Woofer: Focal KX27, 2200 kn Moze i posebno woofer, bez kutije. Cijena po dogovoru. SPECIFIKACIJE: Nom. power 300 W Maximum power 600 W Sensitivity 88 dB Cone K2 Composite Sandwich® Surround Butyl Nom. impedance 4 ohms DC resistance 4.6 ohms VC diameter 65 mm 2.55 in VC height 26 mm 1.02 in Former Kapton® Layers 1 Wire Flat Copper Inductance 1.9 mH Xmax 9 mm 0.35 in Magnet d x h (12) 60 x 14 mm 2.36 x 0.55 in Magnet weight 2106 g 4.66 Ib Flux density 0.9 T Gap height 8 mm 0.3 in Net weight 7.2 kg 15.87 ------------------------------------------ Pojačalo 2 kanala: DLS RA20, 1000 SPECIFIKACIJE: Number of channels 2 Working mode AB Power output at 13,8 Volt, 20 Hz - 20 kHz, max 0,1 % THD Power output, 4 ohm 2 x 130 W Power output, 2 ohm 2 x 220 W Power output, 4 ohm bridged 1 x 440 W THD @1 W < 0,1% Signal to noise ratio, A-weighted >100 dB Damping factor >200 Frequency response +/- 0,5 dB 10 Hz - 50 kHz Input impedance, low level >10 kohm Input impedance, high level 330 ohm High level input with auto start Yes Input sensitivity 0,2 - 7V Pre amp configuration on Front channel: Filter high pass 20 - 150 Hz* Filter low pass 40 - 125 Hz* Phase shift 0- 180 degrees contiously Yes Grand bass adjustable gain @ 40 Hz 0 - +18 dB Filter slope 12 dB/octave Protection current & thermal Max cable size, DC input 4 AWG, 21 mm2 Max cable size, speakers 5 AWG, 16 mm2 Power consumption: Idle 0,6 A Maximum 50 A Fuse 2 x 25 A Dimensions HxWxD(mm) 59x359x245 Dimensions (inch) 2,33x14,1x9,65 Weight 3,8 kg (8,4 lbs) ------------------------------------------ TV tuner Alpine TUE-T150DV Uz njega dolazi daljinski upravljac i dvije antene koje poklanjam. 1000 kn Share this post Link to post Share on other sites
Bube 1 Posted November 19, 2017 (edited) Up! Woofer 1700 bez, 2000 sa kutijom Alpine TV tuner 800kn + bezicne slusalice gratis DLS pojacalo prodano! https://youtu.be/kVy5zJ97vrs Edited November 20, 2017 by Bube Share this post Link to post Share on other sites
Bube 1 Posted December 10, 2017 Up! Woofer 1500 bez kutije, s kutijom 1800 kn. Alpine TV tuner 800kn + bezicne slusalice gratis 0915925532 Share this post Link to post Share on other sites
