projektilski 274 Posted August 10, 2018 Dakle u planu je novi volan sa 12 gumbi, iz golfa 7, 6, scirocco itd. Moj modul na volanu to ne podrzava. Prema Ross Techu trebam nesto od ovih modula: 3C0953549AK 3C0953549AJ 3C0953549AH http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions Mogao bi nabaviti mozda povoljno AK verziju no tu pise "#2: Manual Transmission only, does NOT support Ignition Key Lock." Kaj znaci do not support ignition key lock? Da li je to kad skoljcne volan i zakljuca se? Ako da, to mi nije bitno, ali da li bi taj modul mogao javljati kakve greske pritom? Share this post Link to post Share on other sites
projektilski 274 Posted August 10, 2018 Da, i mislih si da ce ovo tesko netko znati. Share this post Link to post Share on other sites
bozic.hrvoje 0 Posted August 11, 2018 javi se na fejsuTihomiru Krizan, on ce znati Sent from my Redmi Note 4 using Tapatalk Share this post Link to post Share on other sites
projektilski 274 Posted August 11, 2018 Thx, budem i njega probao kontaktirati. Regao sam se na Ross Tech pa cu i tamo pitati. Share this post Link to post Share on other sites
