necko_sa 1 Posted September 4, 2018 U pitanju je passat b6 2007 god. Datum mi kasni dva dana pa bih htjeo to podesiti, ali ne znam kako. U pitanju je MFD displej bez MF tipki na volanu. Share this post Link to post Share on other sites
dzoni 17 Posted September 5, 2018 (edited) Edited September 5, 2018 by dzoni Share this post Link to post Share on other sites
necko_sa 1 Posted September 5, 2018 Pokusao, ali ne mogu da udjem u ovaj MENU. Share this post Link to post Share on other sites
dzoni 17 Posted September 5, 2018 (edited) the car parked and on push and hold the down button on the wiper control stock a menu should then appear and then select setup buy pushing the reset button on the stock and then select date and time Dakle u menu ulazis tako sto duze drzis donju tipku koja je sa strane na rucici za brisace. Edited September 5, 2018 by dzoni Share this post Link to post Share on other sites
necko_sa 1 Posted September 5, 2018 Pokusao vise puta, ali bez uspjeha. I ranije sam gledao neke upute preko youtube-a i pokusao uci prema uputama sa videa. Da li se ta opcija (ulaska u menu preko rucice od brisaca)moze iskljuciti/ukljuciti putem dijagnostike, jer jedino logicno objasnjenje vidim jos jedino u tome. Share this post Link to post Share on other sites
projektilski 274 Posted September 5, 2018 Ne znam, cudno mi je da ne mozes uci u menu tako da dugo drzis tipku Share this post Link to post Share on other sites
dzoni 17 Posted September 5, 2018 Da moze se iskljiucit/ukljucit preko dijagnostike ali kompletno upravljanje boardom preko rucice, cudno mi je da ne mozes u menu. Onda jedino preko dijagnostike promijeniti. Share this post Link to post Share on other sites
romano010 18 Posted September 5, 2018 Jesi pokusao zadrzat gornju tipku na rucici? Share this post Link to post Share on other sites
necko_sa 1 Posted September 5, 2018 Da @dzoni Znas li kako se zove ta opcija da je pokusam potraziti preko vcds-a? Share this post Link to post Share on other sites
dzoni 17 Posted September 5, 2018 (edited) ja sam stimao preko VCDS-a mislim da je pod Instruments ako se dobro sjecam sto se tice datuma. A upravljanja preko rucice morao bih potraziti ali nema mi logike jer se moze ukljuciti/iskljuciti da radi ili ne radi nikako upravljanje boardom. Edited September 5, 2018 by dzoni Share this post Link to post Share on other sites
necko_sa 1 Posted September 6, 2018 I ja sam u cudu. Dake, i donja i gornja tipka uredno vrsi prebacivanje na one osnovne podatke kao sto su prosjecna potrosnja 1 i 2, trenutna potrosnja, prosjecna brzina, vrijeme pitaovanja itd, ali u MENU se ne moze uci. Share this post Link to post Share on other sites
RI VW 4 Posted September 7, 2018 Ja na A3 nisam mogao uci medutim bilo je islkljuceno preko vcds-a. Kad sam ukljucio ulazio bez problema. Kako sam ukljucio tocno, ne sjecam se ali ima negdje opcija za ukljuciti taj menu. Share this post Link to post Share on other sites
necko_sa 1 Posted September 7, 2018 Pa da, pretpostavljao sam da ima opcija koja se preko vcds moze aktivirati/deaktivirati, jos da skontamo kako se zove, bilo bi extra. Share this post Link to post Share on other sites
projektilski 274 Posted September 7, 2018 A cek, ti imas MFD preko cijelog ekrana ili samo na pola? Share this post Link to post Share on other sites
necko_sa 1 Posted September 7, 2018 Preko cijelog ekrana Share this post Link to post Share on other sites
necko_sa 1 Posted October 2, 2018 Jos uvjek pokusavam rijesiti ovaj problem, pa ako neko imas moguce rjesenje, bio bih mu zahvalan. Share this post Link to post Share on other sites
zrnojed2 2 Posted October 8, 2018 Probaj podesavanja zemlje/drzave,moguce je da ona prave sranje. Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
