Loge 0 Posted October 31, 2018 Pozdrav ekipa,, zanima me da li itko zna kako spojiti android sa RCD 310 u golfu vi.. Da li se to moze spojiti samo iphone ili ima neka sema i za android uredjaje..moze li se takodjer spojiti android za onaj sustav poziva sa komandama na volanu? Share this post Link to post Share on other sites
ssrki 1 Posted October 31, 2018 Da bi ga spojio sa rcd310 moras da imas modul ispod vozacevog sedista. Nesto ovakvo https://m.aliexpress.com/item/1800556800.html?trace=wwwdetail2mobilesitedetail&productId=1800556800&productSubject=VW-Bluetooth-Module-9w2-Fit-RCD510-RCD310-1K8035730D-harness-with-microphone-PLUG-AND-PLAY Jer on nema integrisan bluetooth u sebi Sent from my TA-1052 using Tapatalk Share this post Link to post Share on other sites
Loge 0 Posted November 8, 2018 (edited) Boga mi to dosta skupo. Sranje sto nema vec integrirano kad vec ima toliko opreme i mogucnost spajanja na volanu i postavke na radiu Poslano sa mog SM-A520F koristeći Tapatalk Edited November 8, 2018 by Loge Share this post Link to post Share on other sites
Jole112 1 Posted November 8, 2018 Za sta ti je to za telefon*? Imam ja Parrot CK3100 Handsfree! Sve bilo spojeno na rcd310 Golfu 6 radi OK! Share this post Link to post Share on other sites
Loge 0 Posted November 8, 2018 Pa treba mi da spojim komande na volanu sa mobom i radio sa bluetoothom za mjuzu.. Nije mi i dalje jasno zasto ima to na radiju i komande na volanu a nemam mogucnost se spojiti.. glupost kad moram jos dodatno kupovati Poslano sa mog SM-A520F koristeći Tapatalk Share this post Link to post Share on other sites
Jole112 1 Posted November 8, 2018 E neznam da li to sljaka ja sam sluzio za mobitem jer nemam komande na volanu imam to i radio RCD 310 blaupunkt ! Share this post Link to post Share on other sites
Edge330 0 Posted August 21, 2020 Pozdrav ekipa, proučavam forum već neko vrijeme no par stvari mi je ostalo nejasno. Dakle, u Golfu 6 se mogu spojiti na Bluetooth za razgovore, i s tim featurom upravljam s onim malim ekrančićem koji je kod brzinomjera. Međutim ne mogu se povezati s RCD 310 za streamanje muzike s moba. Gledao sam malo YT videe, ima ona opcija Bluetooth on, odnosno off (na RCD 310), ali nema nikakvih rezultata. Sad mene zanima da li je modul za handsfree odvojen od modula koji koristi RCD 310 (ako da di mi je mikrofon)? Recimo da kupim RCD315 koji ima ugrađen BT da li bi mi onda izvor razgovora bio trenutni BT handsfree + radio? Rezime svega je da pokušavam naći način za povezivanje moba preko BT-a. Share this post Link to post Share on other sites
goran sdi 3 Posted August 23, 2020 (edited) On 8/21/2020 at 4:50 PM, Edge330 said: Pozdrav ekipa, proučavam forum već neko vrijeme no par stvari mi je ostalo nejasno. Dakle, u Golfu 6 se mogu spojiti na Bluetooth za razgovore, i s tim featurom upravljam s onim malim ekrančićem koji je kod brzinomjera. Međutim ne mogu se povezati s RCD 310 za streamanje muzike s moba. Gledao sam malo YT videe, ima ona opcija Bluetooth on, odnosno off (na RCD 310), ali nema nikakvih rezultata. Sad mene zanima da li je modul za handsfree odvojen od modula koji koristi RCD 310 (ako da di mi je mikrofon)? Recimo da kupim RCD315 koji ima ugrađen BT da li bi mi onda izvor razgovora bio trenutni BT handsfree + radio? Rezime svega je da pokušavam naći način za povezivanje moba preko BT-a. Handsfree modul je odvojen od RCD 310 i nalazi se ispod suvozačevog sjedala. Mikrofon se nalazi u krovu kod osijetljenja. Promijeni modul ispod sjedala i moči češ streamati muziku. Ja sam na Jetti imao premium modul i mogao sam slušati muziku na radiu. Jedino što sam ja imao RNS 310. Evo kataloški za BT modul 7P6035730H . Edited August 23, 2020 by goran sdi Share this post Link to post Share on other sites
Dankas 2 Posted January 9 Ima netko možda iskustva s dodavanjem BT modula (neki generički Mpow kao AuxIn...tako mi je radio u prijačnjem autu. Sada mi se mob spoji na MPOW preko BT-a no RCD310 uopće ne registrira da ima nešto na AUXin iako je upaljen. Share this post Link to post Share on other sites
Dankas 2 Posted February 23 OK, evo mali update.... napokon sam otkrio zašto mi ne radi AUX - in...bez obzira što je na RCD-u upaljen. Dokle god mi je spojen USB stick na MEDIA-IN, AUX je automatski isključen. Kad iskopčam USB sa muzikom, AUX proradi. Na žalost ne prenose se nikakve informacije na ekranu, pa ne možeš upravljati glazbom osim da opališ MUTE na volanu. E sada, zanima me postoji li ikakava oopcija da mi ostane USB spojen a da mogu odabrati za izvor AUX ili MEDIA...jel moram u nekom posbnom formatu napraviti Stick, moraju li biti pjesme možda u ROOT folderu ili nešto tome slično. Jer ovo kako je sada je totalno jadno. Fala svima Share this post Link to post Share on other sites
