nightwalker93
golf 5 1.9 01314 greška
Treći put mi dolazi več ova greška(unutar 5 mjeseci) i svaki put pri davanju kontakta gori abs lampica i grijaci blicaju i auto ne pali odmah nego kao da mu treba sekundu ili dve vergla, spojim na vcds i dobim "01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent" i kad ih izbrisem sve lijepo ode i miran sam mjesec i pol dva cirka i onda opet nasumično se pojavi, za grijače sam svjestan da 2 ne rade i bit ce zamjena uskoro ali to je vec od prije.
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 QJ    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1984
   Revision: --H08---    Serial number: VWX7Z0H63NL8KN
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 77FD5DDD06CD43F2E4-8022
3 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130619 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:44:18
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.55 V
                    Bin. Bits: 00001100
                    Temperature: 15.3°C
                    Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130619 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:44:18
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.55 V
                    Bin. Bits: 00001100
                    Temperature: 15.3°C
                    Bin. Bits: 00110000
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 000 - Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B200D092900FB881204E9901E00413000
   Shop #: WSC 01316 785 00200
   VCID: 74E76AD1D7BB28EAC1-8020
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 207
                    Mileage: 153373 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 2
                    Count: 2
                    Count: 12544
                    Count: 8196
                    Count: 44288
                    Count: 2816
                    Count: 0
                    Count: 0
Pa pise da su ti otisli grijaci.
Sent from my Nokia 6.1 Plus using Tapatalk
2 grijača su otišla al ima već godinu i pol i nije mi zbog toga nikad javljalo išta i palio je bez problema, citaj cijeli post...
Provjeri strujnu letvicu grijača. S vremenom od topline guma se stvrdne i ispuca te gubi kontakt.
Imao isti problem, riješio zamjenom letvice.
Pa šta je moguće da mi javlja ovu grešku zbog grijača makar godinu i po vozim samo s 2 i nije nikad ništa javljalo?
Sve je moguće, jer se očito ili izgubio ili vratio kontakt...kažem isti problem, malo pobrišem greške, ok neko vrijeme...pa se opet vrati itd..sve do zamjene letvice. Sad je sve ok već 2 godine.
