Boris13 1 Posted December 23, 2020 (edited) Pozdrav da li netko ima u Zagrebu da mi preko dijagnostike vcds-a, isključi grešku na tabli pošto sam stavio original ledice iza za osvjetljenje tablice ? Passat cc, 2011, tdi Hvala Edited December 23, 2020 by Boris13 Share this post Link to post Share on other sites
juka 1 Posted January 27, 2021 Mislim da to nije moguce na CC-u, neka me netko ispravi ako sam nisam u pravu Share this post Link to post Share on other sites
VW_GTD23 134 Posted January 27, 2021 Sve zavisi od BCM-a, na nekima jeste to moguće a na nekima nije nažalost Share this post Link to post Share on other sites
romano010 18 Posted January 27, 2021 Ja jos nisam naletio na nekog da se nije moglo iskljuciti Share this post Link to post Share on other sites
VW_GTD23 134 Posted January 27, 2021 Ne može ni kod mene na mk6 i nisam jedini sigurno. Jednostavno takav je BCM i moraju ići adapteri sa otpornicima Pisao se o tome još ranije... Share this post Link to post Share on other sites
romano010 18 Posted January 28, 2021 Kod mene je cc 2010 god. I mogu iskljuciti cold diagnostic. Tj bilo je iskljuceno dok nisam uzeo odgovarajuce led zarulje, sve radi bez greske. Ja sam narucio od MKled, jos mi tip nudio uz zarulje dodatni otpornik u slucaju da javlja gresku, al nije bilo potrebno stavljati. Dovoljan je bilo onaj samostalni na zarulji Share this post Link to post Share on other sites
VW_GTD23 134 Posted January 28, 2021 Za Audi-a ne znam ali mnogima nije radilo na mk6 eto uzmi pa prelistaj temu ako te interesuje... Share this post Link to post Share on other sites
ALE009 20 Posted January 30, 2021 Moze se na cc ugasit i za non canbus sijalicu al ne preko vcds Share this post Link to post Share on other sites
