projektilski
Passat B8 Variant 2.0 TDI BM R-Line by projektilski
Vrijeme je za temu i za ovog Passata
Evo par podataka:
Marka: Volkswagen
Model: Passat Variant
Godina: 2015
Tip: 3G5
Motor: 2.0 TDI CR DFCA EA288 Euro6 sa BlueMotion
Mijenjac: Rucni
Snaga: 140 kW (190KS)
Boja: Crna sa efektom
Gume: 215/55/R17, 2015/60/R16 i 235/45/R18
Oprema prema naljepnici (ovlasteni mi je poslao PDF u kojem je popis daleko veci):
B0A = Component parts set without country-specific design requirement
U15 = Suspension range 114
G0K = 6-speed manual transmission
H4H = Tires 215/55 R17 94W (polymer coating)
J2D = Battery 380 A (68 Ah)
DE5 = 4-cyl. turbo dies. eng. 2.0 l/140 kW 4V TDI common rail Base engine is TD1
1AT = Electronic stabilization program (ESP)
1G0 = Without spare wheel
2PU = Leather trimmed multi-function sports steering wheel
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
TR1 = 4-cylinder diesel engine 2.0 L unit 04L.A
3S2 = Black roof rails
8TB = Rear fog light
QI6 = Service indicator 30,000 km or 2 year ( variable )
I8E = Standard radio (Gen2)
8GV = Alternator 180 A
8RM = 8 speakers (passive)
1ZA = Disc brakes, front
L34 = Suspension range 34 installation control only, no requirement forecast
0YC = Weight range 3 installation control only, no requirement forecast
G01 = Front shock absorption
7MM = Emission standard EU6 plus
Od bitne opreme auto ima R-Line vanjski i unutarnji paket (spojleri, znacke, sjedala, volan, zatamnjena stakla ali i bez ovjesa itd..), Full Matrix Led prednja svjetla, adaptivni ACC, Lane assist, Front assist, grijana prednja sajba (bez vidljivih grijaca, oznaka 4GW).
Od standardne opreme je klasika, trozonska automatska klima, podzaci stakla, grijanje sjedala, maglenke, isofix, discover media sa bt i takve stvari.
U planu je ugraditi AID aka virtual cluster, straznju kameru i najnoviji MIB, staviti 19" kotace  te mozda preklopne retrovizore. Spustio sam ga Vogtland oprugama koje spustaju cca 35mm.
Ovako je izgledao kad sam ga kupio, stock ovjes i 18"  (koje necu zdrzati)
U medjuvremenu sam presao zgodnu kilometrazu
I evo trenutni zimski setup gdje je vec spusten
Link na komentare
https://www.vwclubcroatia.com/forum/topic/98644-passat-b8-variant-20-tdi-bm-r-line-by-projektilski/
Edited by projektilski
  • Like 5
