Dark Beast 0 Posted September 2, 2021 Pozdrav, imam Gomf 5 2008 god sa oroginal RNS 510 radiom u njemu, sve je odlicno radilo do nedavno, sada se radio uopce ne pali kada se i auto upali, nego ga moram rucno paliti i onda se svakih 30min gasi (ne prepoznaje da auto radi), a samim time mi onda ni ne rade tipke na volalanu.. Problem sa vozacevim vratima je da kad otkljucam auto, otvorim vozaceva vrata i ne prepoznaje da su otvorena dok ne upalim auto, onda tek prepoznaje da su otvorena vrata, dok sva ostala vrata normalno prikazuje... Također sam mogao sa kljucem duzim pritiskom na otkljucavanje/zakljucavanje otvoriti/zatvoriti prozore, dok to sad mogu jedino sa rezervnim kljucem.. nista mi vise nije jasno 😰 Share this post Link to post Share on other sites
Dark Beast 0 Posted September 22, 2021 Evo sa VCDS su očitane greške pa ako netko zna u cemu je problem? Quote Address 01: Engine Labels: 03G-906-021-BLS.clb Part No SW: 03G 906 056 J HW: 03G 906 021 AB Component: R4 1,9L EDC G000SG 2391 Revision: --H07--- Serial number: VWX7Z0H33N67S4 Coding: 0000071 Shop #: WSC 00028 028 00001 VCID: 2E53BBBFB9174CFB61-807A No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0021121 Shop #: WSC 00028 028 00001 VCID: 73E56ACB12B52113CE-8026 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE Component: ClimatronicPQ35 130 1213 Revision: 00130023 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 6DD17CB37491F7E318-8038 1 Fault Found: 01809 - Actuating Motor for Temperature Flap; Left (V158) 000 - - ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005691185 Coding: ED8B8F2700041500471400001400000000097F075C000100000000000000 Shop #: WSC 00028 028 00001 VCID: 71E960C368A913033C-8024 Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB Component: Wischer 290308 021 0501 Coding: 00038805 Shop #: WSC 00028 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 090408 046 0204 Coding: 00471077 Shop #: WSC 00028 1 Fault Found: 00061 - Footwell Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 52 Mileage: 277379 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 12.00 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: 37 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1XET1+ Coding: 0013111 Shop #: WSC 00028 028 00001 VCID: 3D718CF36471A763E8-8068 Subsystem 1 - Serial number: 6332MSME36002674% Subsystem 2 - Serial number: 6342MSME3531375FE Subsystem 3 - Serial number: 6352QSME5C244C3FY Subsystem 4 - Serial number: 6362QSME5C01414DI No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP Component: J0527 051 0101 Coding: 0002022 Shop #: WSC 00028 028 00001 VCID: 0109300358090383CC-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 4 Faults Found: 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent 00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent 00884 - Ignition Switch (D) Terminal X 012 - Electrical Fault in Circuit - Intermittent 01744 - Ignition Switch Terminal P (D) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K0 920 874 M HW: 1K0 920 874 M Component: KOMBIINSTRUMENT VDD 2220 Revision: V0002000 Serial number: VWX7Z0H33N67S4 Coding: 0005103 Shop #: WSC 01286 386 08256 VCID: 377D9EDB464D8D3332-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 290308F2019597 Coding: E9801F0E4006020002 Shop #: WSC 00028 028 00001 VCID: 306FA5C7A3235A0B73-8064 2 Faults Found: 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 51 Mileage: 277379 km Time Indication: 0 Date: 2000.00.00 Time: 16:50:28 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 51 Mileage: 277379 km Time Indication: 0 Date: 2000.00.00 Time: 16:50:28 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1K0 920 874 M HW: 1K0 920 874 M Component: IMMO VDD 2220 Revision: V0002000 Serial number: VWX7Z0H33N67S4 Shop #: WSC 00000 000 00000 VCID: 377D9EDB464D8D3332-8062 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 168226 km Time Indication: 0 Date: 2000.00.00 Time: 16:35:25 ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb Part No SW: 1K0 959 701 N HW: 1K0 959 701 N Component: Tuer-SG 006 1219 Coding: 0000052 Shop #: WSC 00028 028 00001 VCID: 397998E370599B43C4-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb Part No: 1K1 909 144 M Component: EPS_ZFLS Kl.069 H08 1901 Shop #: WSC 00028 028 00001 VCID: 356194D35C417F2320-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 CR HW: 1K0 959 433 CR Component: KSG PQ35 G2 044 0203 Revision: 00044000 Serial number: 00000000000000 Coding: 809002085103087F2D0484056008CB03E0BC00 Shop #: WSC 00028 028 00001 VCID: 020B3F0F5D0F189BD5-8056 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb Part No SW: 1K0 959 702 N HW: 1K0 959 702 N Component: Tuer-SG 006 1219 Coding: 0000308 Shop #: WSC 00028 028 00001 VCID: 3A7B87EF755F905BCD-806E No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1K0-919-283.lbl Part No: 1K0 919 283 A Component: 22 Einparkhilfe 0101 Shop #: WSC 00000 000 00000 VCID: 2D51BCB3B41137E358-8078 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 3C0-035-729.lbl Part No SW: 3C0 035 729 G HW: 3C0 035 729 G Component: Telefon 3011 Revision: 00009000 Serial number: 30800000031894 Coding: 0016041 Shop #: WSC 00000 000 00000 VCID: 275D4E9B96ED1DB3A2-8072 1 Fault Found: 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 00000100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 51 Mileage: 277379 km Time Indication: 0 Date: 2000.00.00 Time: 16:51:20 Share this post Link to post Share on other sites
projektilski 274 Posted September 22, 2021 Imas ti tu svakojakih gresaka. Da se moram kladiti rekao bi da je uzrok svih problema ovo 4 Faults Found:00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent00884 - Ignition Switch (D) Terminal X 012 - Electrical Fault in Circuit - Intermittent01744 - Ignition Switch Terminal P (D) 012 - Electrical Fault in Circuit - Intermittent 1 Share this post Link to post Share on other sites
Dark Beast 0 Posted September 22, 2021 Znaci modul volana 1K0 953 549 BP, dali kupiti novi pa samo zamjeniti ili koja je procedura? Share this post Link to post Share on other sites
derba 3 Posted September 23, 2021 Da se skinut rastaviti i ocistiti od prašine , svojevremeno mi se desilo isto na seatu i riješeno ciscenjem 1 Share this post Link to post Share on other sites
projektilski 274 Posted September 23, 2021 Ja ne mogu tvrditi da je to to, ali nekako mi se cini sve povezano.Sent from my SM-G991B using Tapatalk Share this post Link to post Share on other sites
Dark Beast 0 Posted November 5, 2021 On 23. 09. 2021. at 6:29, derba said: Da se skinut rastaviti i ocistiti od prašine , svojevremeno mi se desilo isto na seatu i riješeno ciscenjem Rastavio i cini mi se cisto, na koji nacin si ocistio? Share this post Link to post Share on other sites
derba 3 Posted November 6, 2021 18 hours ago, Dark Beast said: Rastavio i cini mi se cisto, na koji nacin si ocistio? Nisam cistio sam bio sam kod dijagnosticara , špricao je nekim sprejem doslovno kao da ga je uronio u vodu kapljalo je na sve strane . Kad je sve vratio na svoje mjesto proradilo je.. Rastavio je modul do diodne ploce i po njoj špricao Share this post Link to post Share on other sites
Dark Beast 0 Posted November 26, 2021 Dali zna netko kako iskljucit preko vcds da se ugase pozicije, osvjetljenje tablice i kontrolne ploce kad ugasim auto, moram izvadit kljuc i nakon toga se ugase svjetla se ugasi sve to, dali je moguce da se to ugasi kada samo auto ugasim beh vađenja ključa iz brave? Share this post Link to post Share on other sites
projektilski 274 Posted November 26, 2021 Zar nemas dva zuba, prvi na kojem sve gori, drugi na kojem se sve ugasi, prije vadjena kljuca? Jel to krivo brijem, ali mislim da je tako. Share this post Link to post Share on other sites
projektilski 274 Posted November 28, 2021 Nek se vlasnici petice jave jel stvarno to tako, mozda ti je bravica kaput pa zato tako se ponasa... 1 Share this post Link to post Share on other sites
