GTI rsr 0 Posted January 27, 2012 (edited) pozz htio sam vam predstaviti corrada g60 od moga kuma posto on nece radi se o corradu sa americko trziste u potpunosti razjeb.... :rotfl 1.9 8v g60 project "STIHL" BOTTOM END: -forged pistons (82,5mm) -forged conecting rod -lightened,balanced and knifeedge crankshaft -lightened and balanced flywheel -oil windage tray HEAD: -fully ported end polished by overboost motorsport -biger valves (41mm,35mm) -mechanical valve lifters -schrick camshaft -fully ported intake manifold made by overboost motorsport -65mm throtle with adapter EXHAUST: -exhaust manifold 4-1 made by overboost motorsport -70mm catless exhaust with muffler made by overboost motorsport G LADER: -RS2 modification made by overboost motorsport -63,5mm pully -18mm wide belt -RS bearings -90mm ansaugbogen -K&N filter -70mm boost pipes -large intercooler -oil intercooler 13 rov -silicon hoses FUEL: -630ccm siemens injectors -fuel pressure regulator -044 fuel pump bosch motorsport IGNITION: -bosch multicoils -iridium spark plugs -60-2 flyweel for timing ignition made by overboost motorsport ECU: -VEMS standalone ecu WIZARD OF NOS: -controled by VEMS ecu car is registered and the ful legal for the road -power steering -aircondition -cruise control -leather -music this car is completely tune by overboost motorsport ovdje je link nase stranice gdje se mogu viditi slike i jos neka druga auta : http://www.facebook.com/overboostmotorspor...2809&type=1 auto nazalost nije gotov jer po ovoj hladnoci nemamo bas neku volju raditi inace imamo mali problemcic sa triger senzorom pa nam trokira na 6800 rpm vasi cjenjeni komentari http://www.vwclubcroatia.com/forums/index....showtopic=60444 g60_slike.htm Edited January 27, 2012 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted January 27, 2012 (edited) grana 4-1 supersprint 4-2-1 smo izbacili pa ako kome treba neka se javi ako netko zeli moze mu se namontirati na auto grana supersprint dizne rs2 68 remenica a bregastu schrick 268 je obavezno staviti chipan je bio u rsr i tada je imao 207 hp imamo i viska map senzor do 1.5 bara Edited January 27, 2012 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted August 8, 2012 (edited) danas se napokon uhvatilo malo vremena i mogu reci da je auto napokon slozen nema vise trigger errora auto se vrti do 7500rpm kao lud stvarno brutalan auto za voziti .Kad smo slozili senzor auto ide bolje za nekih 70tak konja razlika nebo i zemlja vuce jako u niskim a u visokim jos jace druga brzina uopce nije iskoristiva 215/40zr16 pali do blokade sutra ujutro idemo na valjke pa se nadam da ce to sve ici gori za nekih 15-tak konja stavljam sutra video i dyno graf Edited August 8, 2012 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted August 9, 2012 (edited) danas se napokon uhvatilo malo vremena i mogu reci da je auto napokon slozen nema vise trigger errora auto se vrti do 7500rpm kao lud stvarno brutalan auto za voziti .Kad smo slozili senzor auto ide bolje za nekih 70tak konja razlika nebo i zemlja vuce jako u niskim a u visokim jos jace druga brzina uopce nije iskoristiva 215/40zr16 pali do blokade sutra ujutro idemo na valjke pa se nadam da ce to sve ici gori za nekih 15-tak konja stavljam sutra video i dyno graf napokon kuci cijeli dan na valjcima glava mi puca od smoga i buke ali nije mi zao auto je izdrzao bez vecih problema i pokazao 286.3bhp na 7000rpm s tim da je to bio 5 ili 6 run prvo je izbacio 259hp na 6500rpm a na 7000 je pao na 245bhp .Nakon par runova ispeglali smo paljenje da autu raste snaga preko 7000 rpm ali zbog straha od g ladera smo stali DOBILI SMO BOLJI MOMENT KROZ OKRETJE CIJELIM PUTEM STVARNOI SAM PREZADOVOLJAN usisna temperatura je zadnje runove pokazivala 55c tako da se tu krije jos nekih 10-tak konja stoga sam uvjeren da smo blizu 300ks saljem kasnije video i slike i da punimo 1.3bara na 7200rpm Edited August 9, 2012 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted August 9, 2012 (edited) evo video na nasoj fcb stranici link od youtube-a kasnije sutra http://www.facebook.com/photo.php?v=318981...mp;notif_t=like Edited August 18, 2012 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted August 18, 2012 evo video na nasoj fcb stranici link od youtube-a kasnije sutra http://www.facebook.com/photo.php?v=318981...mp;notif_t=like youtube link: Share this post Link to post Share on other sites
GTI rsr 0 Posted August 25, 2012 danas skinut lader na corradu poceo je proizvoditi buku sve jacu i nije prestajao kad se davao gas pa smo morali viditi sto se desilo jer smo to jedanput prosli pa kad smo ga otvorili imali smo sta viditi ovaj smo puta imali srecu jel se radi o onom utegu sto ide na osovinu on je dobio lufta tj, kajla je bila losa pa je uteg isao ljevo desno oko kajle valjda od skidanja kajla se potrosila pa nije vise imala toleranciju kakvu je trebala trebamo u ponedjeljak kod tokara da se napravi novu posto nenam gdje ima to za kupiti Share this post Link to post Share on other sites
GTI rsr 0 Posted August 19, 2013 (edited) evo malo smo pocele radit na corradu tocnije zelimo ugradit pogone na sve kotace kupio sam most kardan gitriba 02m od dizela 6 brzina sa haldex spojkom stavili drugi kuplung 550nm+ nadam se da ce to brzo na cestu pa da se popravi rezultat malo evo malo slika malo se cistilo i farbalo Edited August 19, 2013 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted October 6, 2014 nisam dugo postao ali ukratko auto vozi sve super krece puno puno bolje ,ovaj novi 6 brzina mjenjac i nije duzi koliko sam ocekivao cetvrta brzina mi je dulja samo 5 kmh ovaj tjedan idem u zminj na sr nadam se dobrom vremenu Share this post Link to post Share on other sites
GTI rsr 0 Posted November 7, 2014 (edited) https://www.facebook.com/video.php?v=684977581598828&set=vb.102304496532809&type=3&theater link s valjaka 291 ks napravvili smo novu ispusnu granu 48mm i dobili par ks javio nam se trigerr error vidi se na ekranu kasnije smo to rijesili malo je i dimuckao otisao mi semering na reduktoru pa je spricao po grani to smo rjesili novi je gore bio sam u zminju vozio sam 13'7 na sljepo bez turcelera nisam znao s koliko krecem ni na koliko saltam bojao sam se ici visoko radi ladera i okretaja tako da mislim da bi mogao i bolje http://www.vwclubcroatia.com/forum/index.php?/topic/60444-g60-rs2/kometari Edited November 8, 2014 by GTI rsr Share this post Link to post Share on other sites
GTI rsr 0 Posted June 9, 2015 pozz nisam se dugo javljao pa da samo obavjestim auto je jos uvijek ziv radi malo me muce sitnice ali doci ce na red i to za vikend sam bio na sr u gorici i bilo je super rostiljada zezancija druzenje .Vozio sam dva dana ali sam imao neke male kvarove ali uspio sam odvoziti dvije tri dobre voznje napravio sam 13.0 uz rekciju 0.47 znaci vrijeme auta 12.6 sto i nije lose za 1.8 8v malo me muci start jako mi vrti kotace kad krenem pod okretajima pa cu izgleda morati malo poradit na gumama i ovjesu 60ft 2.1 sto je za 4x4 lose Share this post Link to post Share on other sites
GTI rsr 0 Posted June 9, 2015 evo jedan mali video nisam bas dobro prosao naletio sam na 10 sec auto ficek me namazao bimoto hayabusa Share this post Link to post Share on other sites
GTI rsr 0 Posted June 19, 2016 (edited) Malo da napisem radilo se na autu uglavn sitnice koje su odlazile tj hardijev pucao oa smo to morali rijesit necim boljim vozio sam zagreb i bilo je sve super suto po prvi pufa dosao doma ispravan napravio 12.800 uvjeren da moze bolje Edited June 19, 2016 by GTI rsr Share this post Link to post Share on other sites
