Guest D M Posted January 1, 2008 Imam mali problem ne prima mi oglas i javlja gresku THE FOLLOWING ERROR(S) WERE FOUND There is an error with your BBCode. It is possible that you have incorrectly used a tag such as [TAG] when it is meant to be used as [TAG=] or vice-versa. Ako neko zna o cemu se radi molim pomoc Share this post Link to post Share on other sites
MATAVR6 0 Posted January 1, 2008 (edited) ---- Edited January 1, 2008 by MATAVR6 Share this post Link to post Share on other sites
Bagi 0 Posted January 1, 2008 Vjerojatno stavlja?? duple TAG-ove. Kad kopira?? link, onda ga samo PASTE-a??, bez da prije klika?? na prozorčić, jer tako ostavi?? duple TAG-ove. Znači ako ima?? link na Image Shack-u ili već gdje (ako bi kopirao sliku) kopiraj link sa "direct to image" i zalijepi direktno na onaj prozorčić nakon ??to se otvori URL, bez da prije klikne?? na polje, samo PASTE i OK. Share this post Link to post Share on other sites
derWOLF 0 Posted January 2, 2008 ajd stavio sam ja umjesto njega oglas... Dado CARE!! Share this post Link to post Share on other sites
