subzero26 0 Posted October 31, 2016 Pozdrav , ovako auto je uvezen iz njemacke ima 157000 km 2005 godiste , nigdje ne pise koje je ulje toceno u njega osim na naljepnici kod vrata pise castrol sad tocno koji ne pise. Imam neke njegove papire od servisa na svima pise vw norma 504 i 507 a na jednom pise 505.1 . E sad ti servisi su svi bili ispod 100000 km a procitao sam na nekom forumu da se 504 i 507 toce ispod 100000 km. Sad mene zanima koje ulje bi trebao staviti tj koje norme ? Za sad imam u planu staviti castrol edge turbo diesel 5w40. Share this post Link to post Share on other sites
RI VW 4 Posted October 31, 2016 (edited) . Edited October 31, 2016 by RI VW Share this post Link to post Share on other sites
Mouse-RI 3 Posted October 31, 2016 Ako ima dpf, odi na 5w30 Share this post Link to post Share on other sites
AUTOFREAK 217 Posted October 31, 2016 imaš temu o uljima..... bitna je norma... 505.01 507.00 nes fulat s izborom... Share this post Link to post Share on other sites
Roza 0 Posted October 31, 2016 Za tvoj auto Castrol Edge Turbo Diesel 5w40. I samo gas Share this post Link to post Share on other sites
tommek10 7 Posted October 31, 2016 505.01 5w30 shell Share this post Link to post Share on other sites
nightwalker93 5 Posted November 1, 2016 Ako nema dpf 5w40, a ako ima 5w30 Share this post Link to post Share on other sites
subzero26 0 Posted November 1, 2016 Nista hvala onda ce biti castrol turbo diesel 5w40 pa cemo vidjet . Share this post Link to post Share on other sites
tommek10 7 Posted November 4, 2016 Ako nema dpf 5w40, a ako ima 5w30Zato 5w30 ako ima dpf? ... ja koristim od prvog dana 5w30 a nemam dpf Share this post Link to post Share on other sites
Roza 0 Posted November 4, 2016 A zavisi mozes i 5w30 ako po broju odgovara Ali najbolje je 5w40 od castrola jer je bas radeno za pd motore Share this post Link to post Share on other sites
luka93 19 Posted November 4, 2016 Za dpf je bitno da ulje ima c3 standard po acea specifikaciji Share this post Link to post Share on other sites
Roza 0 Posted November 4, 2016 Da zbog nekih manjih cestica necega haha Share this post Link to post Share on other sites
RAZZOR 1 Posted November 4, 2016 2005 godina nema dpf sigurno. castrol edge 5w40 505.01 i miran si 4 litre ti ide u njega. to i ja koristim vise od 5 godina i vise od 100tkm Share this post Link to post Share on other sites
AUTOFREAK 217 Posted November 4, 2016 Nek se nebrine ide i 505.01 5w30 ga ima isto... a moze i 507.00.... Share this post Link to post Share on other sites
