DeMit 0906M 0 Posted April 12, 2018 Danas mi se ovo dogodilo.. ne kuzim sta je.. vratio ga na njemacki jezik.. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
DeMit 0906M 0 Posted April 12, 2018 Netko??? Znaci popizdio je.. nece jezik da prebaci.. stanice naziv prikazuje nema zvuka.. stavio na tvornicke nista Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
projektilski 274 Posted April 12, 2018 Skini ga sa struje na pol sata. Zatim na tvornicke. Ako to ne pomogne flashaj ponovno firmware. Share this post Link to post Share on other sites
DeMit 0906M 0 Posted April 12, 2018 Kako da napravim flash ? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
projektilski 274 Posted April 13, 2018 koji ti je kataloski broj uredjaja? Share this post Link to post Share on other sites
DeMit 0906M 0 Posted April 13, 2018 koji ti je kataloski broj uredjaja?rjesen problem.. sam stavio softwer prvi... sve radi.. sutra cu staviti novi i navigaciju.. malo googlao.. ko se kuzi u i formatiku malo sprzi na cd i 10 koraka ima.. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
projektilski 274 Posted April 13, 2018 Tocno tako Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
DeMit 0906M 0 Posted April 14, 2018 Tocno tako Sent from my SM-G950F using Tapatalk sad mogu bez problema staviti najnoviju verziju softwera ?! Nemogu pronaci kako se navigacija ubacuje s kartama.. cak sam skuzio ove opcije kako da promjenis logo.. onda video da moze biti na njemu i tako Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
projektilski 274 Posted April 14, 2018 Ne mozes najnoviju samo tako. Ovisno o reviziji RNSa ovisi koja je zadnja verzija firmwarea Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Krky 5 Posted April 17, 2018 U kojem formatu snimate pjesme na SD? Pokušavam umetnuti karticu i stalno mi prikazuje SD card error please check the SD card. Probam iz tableta SD 8g pa iz mobitela 16g i ista stvar, da možda ne prima veću SD od 2g? 1 Share this post Link to post Share on other sites
projektilski 274 Posted April 17, 2018 Ovisi o firmwareu ali i kako si je formatirao. Mora biti fat32 Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
