pikzibner Posted February 22, 2008 Posted February 22, 2008 elsa za ??kodu, jel ima netko Po??to vidim da nisi uopče čitao na onom linku di sam dao za download, NEČEMO TI REČI :D Sve je tamo, za kompletni V.A.G.
Dottore Posted February 22, 2008 Posted February 22, 2008 Ma da a ja sam blesav pa neznam ic po redu, ako nisi shvatio pitanje, glupi komentari netrebaju ! ma sve pet.. ni??ta ne zamjeram
marijančilica Posted February 25, 2008 Posted February 25, 2008 prečesto mi puca veza pa nemrem skinut(??ugavi homebox ), pa sam mislio ak ima neko na dvd-u da mi po??alje , za ??kodu
MarkoŠb Posted February 26, 2008 Posted February 26, 2008 (edited) jel se mogu vi dodaci skinit samo za vw?A ne ostala auto jer mene ne zanima za ova ostala edit:nemogu updaet elsu jer nemam crack nema ga na ovim linkovima sto je pik stavio,znaci skinio sam elsu i snimio ali cracka nema Edited February 26, 2008 by Marko??b
MarkoŠb Posted February 27, 2008 Posted February 27, 2008 prebacio sam i keygen,ali nece da se update samo sam skinio elsu,jesam li trebao skinit jos one dole linkove za vw da mi update mozda??
pikzibner Posted February 27, 2008 Posted February 27, 2008 --> QUOTE(Marko??b @ Feb 27 2008, 01:47 PM) prebacio sam i keygen,ali nece da se update samo sam skinio elsu,jesam li trebao skinit jos one dole linkove za vw da mi update mozda?? Pa nema crack-a. Keygen ti da broj sa kojim registrira?? elsu.
MarkoŠb Posted February 27, 2008 Posted February 27, 2008 ok pik,sve sam sredio jos kada vremena uhvatim poskidati one linkove za vw i to je to
Petar 001 Posted March 3, 2008 Posted March 3, 2008 evo nije keygen htio ali sam evo kupio elsu i instaliro sve i elsa kao program radi i update imam na 3.5 ali nemogu podatke instalirat moram se jos mucit
marin-82 Posted March 4, 2008 Posted March 4, 2008 ima neka dobra du??a da mi to (i jos sličnog sw-a) sprzi i po??alje ili se negdje nadjemo (relacija zg-karlovac)?
tihca Posted March 18, 2008 Posted March 18, 2008 oću skinut s ovog linka http://peb.pl/motoryzacja/135709-elsa-v-3-...l-download.html ali stanem na drugom koraku ili rapidshare-u ako dole kliknem na Premium tra??i me pasword,a ako odem na Free onda pi??e Pay pal nekoliko puta,nisam ba?? na "Ti" sa tim skidanjem pa vjerujem da netko razumije o čem se radi,a radi se o neznanju
dambos Posted March 18, 2008 Posted March 18, 2008 ja imam drukčiji problem....uspio sam instalirati elsu ali ništa mi ne radi... kada bilo što pokušam pokrenuti uvijek mi izbaci jednu te istu poruku: "Odabir blokiran! Prvo pokrenite funkciju identifikacije vozila." molio bih one koji imaju iskustva sa ovim programom da mi objasne kako i što dalje... inaće, nabavio sam si obd2 usb kabl i radi mi sa vagcom-om....sve greške izbrisao i otklonio one koje su pronađene (npr. prednji lijevi senzor abs-a)
tihca Posted March 19, 2008 Posted March 19, 2008 ja imam drukčiji problem....uspio sam instalirati elsu ali ni??ta mi ne radi... kada bilo ??to poku??am pokrenuti uvijek mi izbaci jednu te istu poruku: "Odabir blokiran! Prvo pokrenite funkciju identifikacije vozila." molio bih one koji imaju iskustva sa ovim programom da mi objasne kako i ??to dalje... inaće, nabavio sam si obd2 usb kabl i radi mi sa vagcom-om....sve gre??ke izbrisao i otklonio one koje su pronađene (npr. prednji lijevi senzor abs-a) aj mi onda reci kak da skinem,kaj da radim s tim rapidshareom,jel moram imat neki download program da bi skinuo?
pikzibner Posted March 19, 2008 Posted March 19, 2008 aj mi onda reci kak da skinem,kaj da radim s tim rapidshareom,jel moram imat neki download program da bi skinuo? Rapidshare usluga se plaća ako hoče?? downloadat vi??e fajlova. Za pojedinačni download pomoću free opcije treba?? pričekati da ti odbroji onaj brojač, ukuca?? kod koji ti izbaci i skida??. Nakon ??to skine?? 1 file treba čekati oko 100min da bi mogao skidati drugi ili sru??iti vezu na net da bi dobio novi IP i onda ispočetka. Uglavnom zamorno. Onda si kupui?? acc i u??iva??
tihca Posted March 19, 2008 Posted March 19, 2008 pomoću čega da skinem onda,reci kaj mi treba,neki program ili WTF Onda si kupui?? acc i u??iva?? kaj ti je pak to?
pikzibner Posted March 19, 2008 Posted March 19, 2008 Account iliti račun iliti kad plati?? dobije?? username (korisničko ima) i password (lozinku) :D i skida?? do mile volje
dambos Posted March 19, 2008 Posted March 19, 2008 meni uopće nije bilo teško stalno se skidati i ponovo spajati na net samo ne znam što sada da radim s tim programom
tihca Posted March 19, 2008 Posted March 19, 2008 meni uopće nije bilo te??ko stalno se skidati i ponovo spajati na net samo ne znam ??to sada da radim s tim programom sku??io sam da se mo??e na taj način,ba?? skidam ovak samo kaj če mi trebat mjesec dana
MarkoŠb Posted March 19, 2008 Posted March 19, 2008 ljudi skidam 2 tjedna ovih 42 fajla za vw i kako sada da to updatam u elsu uprem update a alsa se samo ugasi poludit cu
jady Posted March 19, 2008 Posted March 19, 2008 instaliras prvo program "elsa"..zatim si update stavis u 4 foldera za svaku marku.onda otvoris folder npr vw i pogledas gdje je "install" i tak jos 3 puta i voila...elsa radi...al opet samo ak mu ispunis one upite koje treba za rad...kao vozilo,godina,motor,getriba itd itd al da je neko to 2 mjeseca skino....rade sam platio tih 7eur i roku 3 dana skino sve
MarkoŠb Posted March 19, 2008 Posted March 19, 2008 ma 2 tjedna sam skidao i samo za vw non stop sam gasio palio internet,a i nemam bas brz net znaci netreba ulaziti u elsa administrator i tamo update jer kada tako uradim elsa mi se ugasi
miki321oc Posted April 6, 2008 Posted April 6, 2008 (edited) 23)Na pulpicie mamy teraz dwie ikonki ElsaWin i ElsaWin Administration klikamy ElsaWin Administration. 24)Wyskakuje okienko jako nazwisko uzytkownika wpisujemy admin jako haslo tez admin klikamy OK. 25)Wchodzimy w prace wybieramy kod wybieramy odczyt kodu 26)Wyskakuje okienko teraz wchodzimy sobie na plytke instalacyjna Elsa klikamy folder Keygen klikamy Elsa 2.5 keygen klikamy READ wskakuje nam kod klikamy GENERATE wskakuje nam kolejny kod ten kod kopiujemy do g??rnej lini tam gdzie wskoczyl pierwszy kod i klikamy znowu GENERATE wyskakuje kolejny kod ten kod kopiujemy do lini(KOD DEFINITYWNY) okienka do rejestracji i klikamy OK. I MAMY PROGRAM W WERSJI BEZTERMINOWEJ. 27)Wchodzimy w prace wybieramy wprowadzenie uzytkownika 2Wyskakuje okienko wpisujemy swoje imie i nazwisko klikamy DALEJ 29)Wyskakuje okienko wybieramy jezyk polski-Polska(NIE ZAZNACZAC ADMINISTRATOR!!!!!!)klikamy DALEJ 30)Kolejne okienko wpisujemy sobie haslo wedlug uznania klikamy DALEJ 31)Kolejne okienko w lini NR. IMPORTERA wpisujemy 123 w lini NR. DEALERA wpisujemy 12345 klikamy DALEJ 32)Kolejne okienko klikamy DALEJ 33)Kolejne okienko klikamy UTW?“RZ 34)Kolejne okienko klikamy OK. 35)Zamykamy ELSA ADMINISTRATONS i mozemy zaczac instalacje danych z plyt ZACZYNAJAC OD: 1 AUDI 2 VW 3 SEAT 4 SKODA 36)Na pulpicie klikamy ElsaWin wyskakuje okienko jako nazwe uzytkownika i haslo wpisujemy admin. 37)Odpala sie Elsa wchodzimy w EINSTELLUNGEN wybieramy SPRACHE i wybieramy polski-Polska klikamy OK. skinuo sam VW i program Elsa krenuo instalaciju po upustvu i sve je bilo OK dok nisam dosao do 23) moze li mi neko pomoci kada pokrenem program otvori se porgram i izbaci poruku sa slike Edited April 6, 2008 by miki321oc
pikzibner Posted April 7, 2008 Posted April 7, 2008 skinuo sam VW i program Elsa krenuo instalaciju po upustvu i sve je bilo OK dok nisam dosao do 23) moze li mi neko pomoci kada pokrenem program otvori se porgram i izbaci poruku sa slike MIslim da je to Ime, Prezima i nadimak (user name)
