MOTA BOY
16VT thread
Dobio sam knock senzor od Pola. Pošto koristim VEMS, dali mi treba to sranje na mom 16VT ili ne? :) Hvala!
Evo jedna stvar za one koji žele veću klapnu gasa(vr6 naprimjer) a žele ili moraju ostati na DIGI1(g60) kompjuteru i struji, onda im treba senzor položaja zaklopke sa prekidačima za ler i pun gas.
tvornički kataloški je ovaj: 037 907 385P
slika: http://i.ebayimg.com/t/VW-Throttle-Positio...jSclg~~60_3.JPG
A senzor je dolazio na slijedećim autima/motorima:
Year Make Model
1995 Volkswagen Cabrio 2.0L ABA
1996 Volkswagen Cabrio 2.0L ABA
1997 Volkswagen Cabrio 2.0L ABA
1998 Volkswagen Cabrio 2.0L ABA
1999 Volkswagen Cabrio 2.0L ABA
2000 Volkswagen Cabrio 2.0L ABA
2001 Volkswagen Cabrio 2.0L ABA
2002 Volkswagen Cabrio 2.0L ABA
1993 Volkswagen Golf 2.0L GTI ABA
1994 Volkswagen Golf 2.0L GTI ABA
1995 Volkswagen Golf 2.0L GTI ABA
1996 Volkswagen Golf 2.0L GTI ABA
1997 Volkswagen Golf 2.0L GTI ABA
1998 Volkswagen Golf 2.0L GTI ABA
1999 Volkswagen Golf 2.0L GTI ABA
1993 Volkswagen Golf 2.0L GL ABA
1994 Volkswagen Golf 2.0L GL ABA
1995 Volkswagen Golf 2.0L GL ABA
1996 Volkswagen Golf 2.0L GL ABA
1997 Volkswagen Golf 2.0L GL ABA
1998 Volkswagen Golf 2.0L GL ABA
1999 Volkswagen Golf 2.0L GL ABA
1995 Volkswagen Golf 2.8L GTI VR6 AAA
1996 Volkswagen Golf 2.8L GTI VR6 AAA
1997 Volkswagen Golf 2.8L GTI VR6 AAA
1998 Volkswagen Golf 2.8L GTI VR6 AAA
1999 Volkswagen Golf 2.8L GTI VR6 AAA
1993 Volkswagen Jetta 2.8L GLX V6 AAA
1994 Volkswagen Jetta 2.8L GLX V6 AAA
1995 Volkswagen Jetta 2.8L GLX V6 AAA
1996 Volkswagen Jetta 2.8L GLX V6 AAA
1997 Volkswagen Jetta 2.8L GLX V6 AAA
1998 Volkswagen Jetta 2.8L GLX V6 AAA
1999 Volkswagen Jetta 2.8L GLX V6 AAA
1995 Volkswagen Passat 2.0L GLS ABA
1996 Volkswagen Passat 2.0L GLS ABA
1997 Volkswagen Passat 2.0L GLS ABA
:zivio
Bilo bi dobro kada bi imali thread gdje bi se stavljali samo motorni prostori, da vidimo kako drugi ljudi imaju smišljene sve te kablove i vakuum/boost crijeva kojih bude milijun...
otvorio sam ja topic pod binaries:16vt, imam hrpe slika motornih prostora, sastavljanja motora i ostalog, ak kome pomogne nešto
a otkud vi uzimate vodu za hladjenje turba? nigdje slika nema.... :/
sve sam searchao... :((
Nisam to još previše istraživao. Mislim da ili iz glave il dovoda malog hladnjaka kabine?
evo 2 primjera, jedan je vr6t16vtgockelj0uy3.jpgrecaro-days-2009-nuer9bux8.jpg
daj ovu prvu u binaries stavi pod 16v slike ...
tako mi se cini najbolje...
kad su ovako plava sva crijeva izgelda još veći nered.. neznam zašto...
Edited by LamaMk1
Predpostavljam da je svejedno koje je dolaz a koje odlaz na turbinu i na mali kiler kabine?
:) Vidim, al mislim svejedno je, el ne?
EDIT:
Ili je još bolja možda verzija povrat u posudu?
Edited by MOTA BOY
Ima netko sliku gdje montirat 2 knock senzora na 1.8 blok? Za jedan znam(između 1. i 2. cilindra), drugi nemam pojma gdje bi dao( 3. i 4.)
nema veze na turbu gdje ce ti biti ulaz a gdje izlaz,bitno je da imas cirkulaciju!
pa ulaz mozda bolje napraviti sa kontra strane od dovoda ulja tako da se sa obje strane dobiva ''ohlađeni'' metrijal za hlađenje/podmazivanje...
Nemožeš s kontra strane, jer je tamo onda izlaz ulja. Najbolje onda sa "prednje strane" ako odozgora dolazi ulje.
Što sa knock senzorima?
daj slikaj blok i pogldaj dal imas dva mjesta gdje su ti rupe? na bloku...
Evo jedan između 1. i 2. cilindra:
jedan ti je kod filtera ulja prema zamašnjaku
ovo je slika 1.8T sa vanjskom pumpom vode
http://www.pohrani.com/f/2M/Li/35JRpC0O/03042010003.jpg' alt='03042010003.jpg'>
Ako tko hoće slagati, imam jedan blok motora viška od 20v sa vanjskom pumpom vode (kao što imam sebi složen na Rallye-a) i ima sve knock senzore :) imam i jednu 20v kompletnu glavu
Edited by Beli
Problem je što je meni tamo ona kocka za iberlauf. Vidi se na slici. :)
