DeMit 0906M 0 Posted February 3, 2017 Nemogu pronaci post od felgi nez zasto.. koristim forum na mob.. mozda zato.. ugl zanima me ovo.. Da li netko zna gdje se mogu nabaviti ovakve felge I tko ima rotorice 19" ovakve.. Zanima me koja slika kako stoji itd.. koja guma najšira ide itd... Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Xman 29 Posted February 3, 2017 Ja imam original 19". Moje su bas za VW, 19x8, et 50 i centralna 57.1 Guma je 225/40 trenutno al sigurno ide i sira. Koji et ti ide na Passata? Share this post Link to post Share on other sites
Daci 0 Posted February 3, 2017 ako b6 , et 40 najniže , jer iza će strugat Share this post Link to post Share on other sites
DeMit 0906M 0 Posted February 3, 2017 Ja imam original 19". Moje su bas za VW, 19x8, et 50 i centralna 57.1 Guma je 225/40 trenutno al sigurno ide i sira. Koji et ti ide na Passata? mislio sam et42... imao sam et 35 pa odma prodao.. strugalo.. daj sliku molim te koju Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Xman 29 Posted February 3, 2017 Na 19x8 Et 50 ima jos prostora do ruba, cak bi i distanca dobro legla. Moj auto je i spusten. Share this post Link to post Share on other sites
limp19 6 Posted February 3, 2017 Demit koji ti je sada setup? Koliko jota i koji et? Ja uzeo 18x8j et 35 valjda nece strugati na b6 Share this post Link to post Share on other sites
DeMit 0906M 0 Posted February 4, 2017 Demit koji ti je sada setup? Koliko jota i koji et? Ja uzeo 18x8j et 35 valjda nece strugati na b6 8x18 Et 42 Cak i distance stanu.. al idem na 19 Sent from my iPhone using Tapatalk Na 19x8 Et 50 ima jos prostora do ruba, cak bi i distanca dobro legla. Moj auto je i spusten. Supsten je i moj na vogland -4cm.. mislim Da bi et 42 bio taman.. imao sam Et35 al je ribalo strasno... Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
limp19 6 Posted February 4, 2017 (edited) Da ali je to 9.5j zato su i ribale a spusten Nije isto et35 na 9.5j i 8j Edited February 4, 2017 by limp19 Share this post Link to post Share on other sites
Vec 1 Posted February 4, 2017 koje su dimenzije guma i felgi na ovom crnom B6 ? Share this post Link to post Share on other sites
DeMit 0906M 0 Posted February 4, 2017 koje su dimenzije guma i felgi na ovom crnom B6 ? Bile su 9,5x19 et 35 al to je za audi .. ne moze se atestirsti a najgore sto struze.. pa sam prodao.. et42 mora biti Sent from my iPhone using Tapatalk Da ali je to 9.5j zato su i ribale a spusten Nije isto et35 na 9.5j i 8j Svejedno ti et35 struga koliko god J bile.. ona ide sa J unutra u širinu.. ET ostaje vani istinoromjenom Jota.. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
RI VW 4 Posted February 4, 2017 (edited) Ako je et 35 i 9.5 sirina i u usporedbi sa njom et 35 8 sirina jednako se sa obje strane suzuje. Da su tvoje bile 8 i et 35 bile bi 1.9 cm vise unutra i 1.9 cm udaljenije od amortizera. Edited February 4, 2017 by RI VW Share this post Link to post Share on other sites
limp19 6 Posted February 4, 2017 (edited) To sam i mislio et je isti ali sirina nije pa su vise izbacene i vani i unutra radi sire felge Edited February 4, 2017 by limp19 Share this post Link to post Share on other sites
icorak1 0 Posted February 4, 2017 Na 19x8 Et 50 ima jos prostora do ruba, cak bi i distanca dobro legla. Moj auto je i spusten. Dali je spušten original ili si ga ti spusti..?Imam Golfa 7 spustio bi ga ali iskreno ne znam gdje.. ako tko ima dobru preporuku, Hvala unaprijed. Poslano sa mog SM-G928C koristeći Tapatalk Share this post Link to post Share on other sites
Xman 29 Posted February 4, 2017 Gtd je serijski nizi a ja sam stavio HR opruge. uzmi eibach, HR je jako tvrd, super auto lezi ali dok se ne naviknes na tvrdoću, poludis. Opruge ovak iz glave imas kod Gabreka, Reneko, auto hrvatska a vjerojatno jos na dosta mjesta. Share this post Link to post Share on other sites
RI VW 4 Posted February 4, 2017 (edited) To sam i mislio et je isti ali sirina nije pa su vise izbacene i vani i unutra radi sire felgeDa, ali to sam napisao jer demit pise da sa istim et-om bez obzira na sirinu jednako vire, a to nije tocno. Ako na 8 ima et 35 i na 9.5 jota jednako vire van onda je et 73. A ako je et 35 onda sa svake strane bude po 1.9 cm Ili ako na 9.5 ima et35, onda na 8 mora imati et -3 da bi bile jednako izbacene van. Edited February 4, 2017 by RI VW Share this post Link to post Share on other sites
limp19 6 Posted February 4, 2017 Tacno jer se et gleda sa sredine felge ne sa vanjske ivice Share this post Link to post Share on other sites
RI VW 4 Posted February 4, 2017 Tako je, od sredine do dosjeda Share this post Link to post Share on other sites
projektilski 274 Posted February 4, 2017 8j i et 35 na b6 straga grebe naprijed ne i to je to. Iz tog razloga prodajem svoje ultraleggere Sent from my SM-G900F using Tapatalk Share this post Link to post Share on other sites
icorak1 0 Posted February 4, 2017 Gtd je serijski nizi a ja sam stavio HR opruge. uzmi eibach, HR je jako tvrd, super auto lezi ali dok se ne naviknes na tvrdoću, poludis. Opruge ovak iz glave imas kod Gabreka, Reneko, auto hrvatska a vjerojatno jos na dosta mjesta. Hvala...! Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 4, 2017 8j i et 35 na b6 straga grebe naprijed ne i to je to. Iz tog razloga prodajem svoje ultraleggere Sent from my SM-G900F using Tapatalk Koje su ti dimenzije ultri? Share this post Link to post Share on other sites
projektilski 274 Posted February 4, 2017 235/40 Sent from my SM-G900F using Tapatalk Share this post Link to post Share on other sites
dodoonn 1 Posted February 5, 2017 Ne misli na dimenziju guma. Share this post Link to post Share on other sites
<TDI> 426 Posted February 5, 2017 Ako su ove, onda su dolje dimenzije ... 18" 5x112, ET35 8Jx18H2 OZ Ultraleggera, 18", 5x112, ET35 + Dunlop Sportmaxx RT Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 5, 2017 Nemoguce da su felge Ultraleggere a da njima pise Superleggera. Tu nesto ne stima. Imao sam Ultre pa znam. Share this post Link to post Share on other sites
projektilski 274 Posted February 5, 2017 (edited) Onda je netko radio besramnu kopiju sa svim oznakama (iz vana i unutra - kopije to nikad nemaju a ne znam ni da li mogu bas tako dobro kopirati font i logo) i zeznuo u nazivu. Felge su cvrste i full lagane pa je onda i leguru kopirao Ja mislim da su original ali eto, posto im nisam prvi vlasnik, nikad necu znati istinu. Edited February 5, 2017 by projektilski Share this post Link to post Share on other sites
