ljubobj 103 Posted April 24, 2017 uuu strari preeeejeebeooo hvala ti uzet cu i ja takav pod hitno Share this post Link to post Share on other sites
Pope 0 Posted April 25, 2017 (edited) Pau li sachs amortizeri i eibach 30mm opruge sa Pola 6r na Pola 9n/9n3 Edited April 25, 2017 by Pope Share this post Link to post Share on other sites
Pikac1.4 0 Posted April 28, 2017 Pase li volan od pola 6n2 (onaj sa srebrnim znakom u sredini) na pola 6n? Hvala Share this post Link to post Share on other sites
Mouse-RI 3 Posted April 28, 2017 Pase, imao sam ja od caddya to godiste u 6n... Share this post Link to post Share on other sites
daniels 1 Posted April 29, 2017 Ekipa dali itko zna, od čega mi pašu prednji sicevi u paju međuliniju? Bez rezanja, varenja itd, jel ako moram rezat/varit onda imam od audia siceve. Share this post Link to post Share on other sites
Passat 0 Posted April 29, 2017 (edited) Od trojke passata i trojke golfa. Sve ostalo flexa tuning. Edited April 29, 2017 by Passat Share this post Link to post Share on other sites
WV Polo 1 Posted April 29, 2017 Pase, imao sam ja od caddya to godiste u 6n... imaš istog i u lupu to godište Share this post Link to post Share on other sites
IvkiIvki 0 Posted May 5, 2017 Moze li mi netko rec ako mozda zna da li paše korpa i lamela sa audija b4 1.9 tdi 110 hp na passata 1997 1.9 tdi 110 hp ? Share this post Link to post Share on other sites
daniels 1 Posted May 6, 2017 Kaj je bio b4 110Ks? da nije B5? 228mm su na oba sa dvostrukim zamašnjakom, ali lamele nemoraju bit iste, na B5 lamella nema federe u sebi, Share this post Link to post Share on other sites
kiki__mk5 0 Posted May 13, 2017 Planiram uzet felge od passata cc interlagos 18. 225 40 18 et41 pa me zanima bi to islo na jettu mk5 Poslano sa mog SM-A510F koristeći Tapatalk Share this post Link to post Share on other sites
<TDI> 416 Posted May 15, 2017 Moram ovdje pitati jer ne mogu dobiti odgovor od servisa ni od AHW Shopa a na internetu nisam mogao pronaći neki tutorijal. Paše li 2DIN kavez za radio sa dekor lajsnama u Golf koji ima kavez bez njih, znači fiksni koji nema dekor lajsne?Kavez sa dekro lajsnama (1J1858069G 01C)Kavez bez dekor lajsni (1J1858069F 1QA) Share this post Link to post Share on other sites
VWTDI 5 Posted May 15, 2017 Pase kolega vidis i sam da je sve isto ali kod ove se mogu odvojiti dekor lajsne a kod ove ne i to je jedina razlika Share this post Link to post Share on other sites
<TDI> 416 Posted May 15, 2017 Je, to ti misliš ali treba točno znati a ne pogađati. No, mislim da je sve OK jer sam već nešto našao ali još malo istražujem da budem sikuran ali ako hoćeš pomoći eto malo potraži pa da vidim kako ti ide. Share this post Link to post Share on other sites
VWTDI 5 Posted May 15, 2017 Ocu kolega pomocu zasto da ne ali ovako po slikama rekao bih da to pase ali nista nije sigurno. Ako sta nadjem javim ti ubrzo Share this post Link to post Share on other sites
<TDI> 416 Posted May 15, 2017 Za sada sve sto sam nasao je izvadi stari bez i stavi novi sa tako da ne bi trebalo biti iznenadjenja ali ako ti nije problem potrazi malo, Sutra ujutro bi trebao potvrditi narudzbu da mi stigne iduci tjedan pa bi ako sto nadjes javi. Share this post Link to post Share on other sites
VWTDI 5 Posted May 15, 2017 Evo trazim ali slabo sta ima bas sam gledao imali razlike neke u plastikama ili nekim nosacima ali nema nista sve je isto sasvim samo sto se kod ove odvajaju dekor lajsne evo nekoliko slika,prva slika ne mogu se odvajati dekor lajsne a ostale slike dvije mogu da se odvajaju. Share this post Link to post Share on other sites
<TDI> 416 Posted May 15, 2017 Znaci, imao sam vise srece. Nasao sam nekoliko tema gdje se bas raspravljalo tako da vjerujem da nema razlike a iz slika se tesko moze saznati ali kada narucim nema vracanja i zbog toga mi je bilo vazno da znam jer nije bas jeftin. Share this post Link to post Share on other sites
VWTDI 5 Posted May 16, 2017 (edited) Svaka cast,i ja mislim da nema razlike neke jeste tesko je po slikama ocjeniti da li ima razlike ali svi nosaci gdje idu sarafi su na istom mjestu,ma i gdje bi bio sada VW da je mjenjao tako djelove tako da su uradili te sine ili kopce da se mogu mjenjati lajsne,mislim da je to najbolje rijesenje, bilo bi glupo da je fiksni i ne mogu da se mjenjaju dekor lajsne, drvo imas a oces da stavi alu pa moras cupati stari kavez da bi stavio ovaj gdje se nalaze alu dekor lajsne,pa je VW samo dodao te sine da se to mnogo lakse moze zamjeniti nego da pola auta rastavljas. Jesi li ti uzeo nov kavez,gledam kod nas nije skupo oko 150 kuna moze se naci u odlicno stanju sa dekor lajsnama. Edited May 16, 2017 by VWTDI Share this post Link to post Share on other sites
<TDI> 416 Posted May 16, 2017 Dobio sam jutros i potvrdu od AHW Shopa tako da bi sada trebalo biti 100% da pase. Uzet cu novi od servisa a preko ebaya mi sve ispadne razlika nekoliko eura. Vidio sam da na vecini njih ona perca koja drze lajsne su popucala tako da mi se ne isplati staro uzet. Plastika nakon nekog vremena daje svoje a ovo radim samo jednom pa nek bude novo. Share this post Link to post Share on other sites
