Dark Beast 0 Posted March 5, 2017 Gdje i koje otpornike kupiti, i kako sloziti to? Share this post Link to post Share on other sites
Leic 2 Posted March 5, 2017 (edited) Te sa bijelom podlogom i meni na petici 2005 bacaju gresku. Sa zelenom ne. Na golf 6 sve bacaju gresku, tj. rade ali svjetli greska Edited March 5, 2017 by Leic Share this post Link to post Share on other sites
vlaho 2901 1 Posted March 5, 2017 Jebes oem ako i na njih moras dodavati otpornike. Ali dobro, kupit ću ih i ja pa ćemo vidit. Ali 99% da će i kod mene bacat gresku na tabli. Share this post Link to post Share on other sites
MarioIV 11 Posted March 5, 2017 Bacaju i oem jer kod novijih se uredno kodiraju Share this post Link to post Share on other sites
DeMit 0906M 0 Posted March 5, 2017 Ja imam sa bijelom podlogom i rade bez problema.... eo link... https://www.ebay.com/itm/222244707965 Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
vlaho 2901 1 Posted March 5, 2017 Demite druže probat ćemo ih spojit kod mene da vidimo hoće li bacat gresku ili ne. Pa onda lako kupim sebi komplet. Share this post Link to post Share on other sites
dodoonn 1 Posted March 5, 2017 Je slagao ko sta na 7? Ja moram isto stavit neke led. Share this post Link to post Share on other sites
DeMit 0906M 0 Posted March 5, 2017 Demite druže probat ćemo ih spojit kod mene da vidimo hoće li bacat gresku ili ne. Pa onda lako kupim sebi komplet. Ma za tebe sve.. kad se vratis s pučine Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
jooka 1 Posted August 15, 2018 pozdrav, moze pomoc. koja je sad razlika izmedu ovih ledica https://www.ebay.com/itm/10X-6000K-White-158-41MM-COB-12-SMD-Dome-Interior-LED-License-Plate-Light-bulbs/192450358955?rt=nc&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D52935%26meid%3Ddf26a6ce6b53435885b750befb40a8a4%26pid%3D100005%26rk%3D2%26rkt%3D12%26sd%3D141883951019%26itm%3D192450358955&_trksid=p2047675.c100005.m1851 https://www.ebay.com/itm/White-Dome-16-SMD-Festoon-LED-Bulbs-For-Car-License-Plate-Light-31-36-39-41mm/391096322747?hash=item5b0f284abb%3Am%3Am7JOfoOroi6ZA3nffzqWpCw&var=660463337234&_sacat=0&_nkw=2x-Canbus-No-Error-License-Plate-White-LED-Light-Bulbs-6418-41MM-Festoon-Lamps++2x-Canbus-No-Error-License-Plate-White-LED-Light-Bulbs-6418-36MM-Festoon-Lamps++2x-Canbus-No-Error-License-Plate-White-LED-Light-Bulbs-6418-36MM-Festoon-Lamps++2x-Canbus-No-Error-License-Plate-White-LED-Light-Bulbs-6418&_from=R40&rt=nc&LH_TitleDesc=0 Share this post Link to post Share on other sites
vwl51c 2 Posted August 15, 2018 u ovom drugom linku mozes birat duzinu ledice. ne kuzim sto te zanima? jacina svitlosti? Share this post Link to post Share on other sites
projektilski 274 Posted August 16, 2018 I mislim da su sve puno prejake ako bi isle za osvjetljavanje tablica. Share this post Link to post Share on other sites
jooka 1 Posted August 16, 2018 u ovom drugom linku mozes birat duzinu ledice. ne kuzim sto te zanima? jacina svitlosti? Ma to bi mi bilo za unutranje osvjetljenje auta. Kupio nekakvu i nakon 10 dana počela blicati. Trebam takvu od 41 ali da valja. I mislim da su sve puno prejake ako bi isle za osvjetljavanje tablica.Nije za tablicu i treba da jako svijetli. :-) Share this post Link to post Share on other sites
vwl51c 2 Posted August 16, 2018 probaj te prve narucit i vidit kakve su. ne mos te stvari znat dok ne probas, eventualno ako je neko proba.. Share this post Link to post Share on other sites
projektilski 274 Posted August 16, 2018 Ova cob je kvalitetnija Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
jooka 1 Posted August 16, 2018 (edited) Ova cob je kvalitetnija Sent from my SM-G950F using Tapatalk Naruciti cu te cob, a jel isto svijetle ili? Jel vidim da ovih ima vie ledica Edited August 16, 2018 by jooka Share this post Link to post Share on other sites
mur3633 196 Posted August 16, 2018 http://s.aliexpress.com/IBvyQB7b?fromSns=Copy to Clipboard Boljih za enterijer od ovih nema. Sent from my Redmi Note 3 using Tapatalk Share this post Link to post Share on other sites
jooka 1 Posted August 16, 2018 http://s.aliexpress.com/IBvyQB7b?fromSns=Copy to Clipboard Boljih za enterijer od ovih nema. Sent from my Redmi Note 3 using Tapatalk Jel jako svijetle Share this post Link to post Share on other sites
mur3633 196 Posted August 17, 2018 Baš su jake. Sent from my Redmi Note 3 using Tapatalk Share this post Link to post Share on other sites
jooka 1 Posted August 17, 2018 (edited) Ba su jake. Sent from my Redmi Note 3 using Tapatalk E ba super takve mi i trebaju. Naručio sam već. :-)Hvala na pomoći Edited August 17, 2018 by jooka Share this post Link to post Share on other sites
jooka 1 Posted September 11, 2018 hvala mur3633. Lampe svijetle predobro. Čak i vie nego to sam mislio ali super taman treba jako. Može igle tražiti po autu :-) Share this post Link to post Share on other sites
Roby ZD 6 Posted September 12, 2018 Je slagao ko sta na 7? Ja moram isto stavit neke led. Stavi OEM. Jest da kostaju, ali imas pravu stvar. Ostale, pogotove one jeftine jako svijetle i (barem meni) ruzno izgleda. Share this post Link to post Share on other sites
mur3633 196 Posted September 12, 2018 hvala mur3633. Lampe svijetle predobro. Čak i vie nego to sam mislio ali super taman treba jako. Može igle tražiti po autu :-)Baš mi je milo da su ti se sviđele. Tu smo da pomažemo jedni drugima. Sent from my Redmi Note 3 using Tapatalk Share this post Link to post Share on other sites
jooka 1 Posted September 12, 2018 Ba mi je milo da su ti se sviđele. Tu smo da pomažemo jedni drugima. Sent from my Redmi Note 3 using Tapatalk Tako je. Bio sam malo skeptičan jer ove prole radile jedno mjesec dana i počelo zaj. I bilo je vie ledica a vamo samo dvije. Ali kad sam stavio u kuciste bas me je ugodno iznenadila koliko jako svijetli sto i trebam ba. Hvala jo jednom Share this post Link to post Share on other sites
Mouse-RI 3 Posted September 16, 2018 Imao sam ja te, radile manje od mjesec dana i crkle... Share this post Link to post Share on other sites
jooka 1 Posted September 16, 2018 Imao sam ja te, radile manje od mjesec dana i crkle...A daj me nemoj zezati. Pa one prole radile mj dana neće valjda i ove. Share this post Link to post Share on other sites
