gavranovic 20 Posted November 19, 2017 Nista Kiki, nadam se da ti nece trebati. Mozda da stavis nove gumice i limeno brtvilo pa stegnes ko sivonja i mir bozji Salim se naravno Share this post Link to post Share on other sites
<TDI> 416 Posted November 20, 2017 Budemo vidjeli ako i zatreba tu je. Ma, bit će po PS-u samo origigi brtvo kako je Ivo rekao, ništa drugo a do tada će biti jedno detaljnije čišćenje. Share this post Link to post Share on other sites
limp19 6 Posted November 25, 2017 (edited) Moze li neko da provjeri kataloski od brtve tandem pumpe jer danas sam vidio da je poprilicno zabalavilo tamo ispod nje. Sa autom nemam nuspojava jedino sto vidim da je masno tuda oko tandem pumpe. Pasat b6 1.9tdi 77kw bkc kod motora 2006 god Edited November 25, 2017 by limp19 Share this post Link to post Share on other sites
Mouse-RI 3 Posted November 25, 2017 Sta ce ti kataloski, odi u ovlasteni sa brojem sasije i kupi oem kako je vec preporuceno na forumu, kvaliteta bolja, a cijena ista... Share this post Link to post Share on other sites
AUTOFREAK 217 Posted November 25, 2017 Odi 2stranice u rikverc i budes vidio onu za mk5 1.9 i to je to... Share this post Link to post Share on other sites
limp19 6 Posted November 26, 2017 (edited) Svakako sam oem i mislio uzeti.Prvo cu malo brake cleanerom da ocistim pa da vidim stanje. Ivo ne bi trebalo skoditi brake cleaner onim crijevima oko tandemke? Ps sad citam znaci kod mene je starija tipa sa gumenim brtvama? Edited November 26, 2017 by limp19 Share this post Link to post Share on other sites
dr.restaurator 5 Posted November 26, 2017 slikaj tandem pumpu,spoj glave i pumpe kod golf 5 nije bilo ovih gumenih Share this post Link to post Share on other sites
limp19 6 Posted November 26, 2017 Aj postavim sliku. Kod mene je passat b6 2006 Share this post Link to post Share on other sites
AUTOFREAK 217 Posted November 26, 2017 Rekoh vrni se nazad...tamo smo razglabali kakvu pumpu i brtvu imaju pd nakon prvih pd.motora. Trebas limenu. Share this post Link to post Share on other sites
limp19 6 Posted November 26, 2017 Znaci samo limenu narucim u ovlastenom i to je to. Nema se nista drugo mijenjati? Ja se istripovao da je moj jedan od prvih pd motora ? Share this post Link to post Share on other sites
AUTOFREAK 217 Posted November 27, 2017 Samo je jedna brtva... ako mislis da pusta izmedju pumpe i glave ona samo imas tu brtvu... Share this post Link to post Share on other sites
limp19 6 Posted November 27, 2017 Hvala Ivo po ko zna koji put ? Svakako mislim prvo cleanerom ocistiti malo pa propratiti. Nemam nekih nuspojava sve radi kako treba. Ako opet podje pustati tu onda cu uzimati brtvu Share this post Link to post Share on other sites
<TDI> 416 Posted November 27, 2017 I na mojoj tandemki je isto sve bilo masno i nakon što sam ju malo sa ivasolom pošpricao i obrisao krpom ne vidim za sada ništa, to su naslage od tko zna kada ali zato sada pratim pa ako se nešto pojavi odmah ide novo brtvo. Share this post Link to post Share on other sites
limp19 6 Posted November 27, 2017 Tako i ja planiram. Da li se brake cleanerom smije tuda prskati s obzirom da ima gumenih dijelova Share this post Link to post Share on other sites
<TDI> 416 Posted November 27, 2017 Imam ga i sada mi stoji na polici, nikad korišten. Share this post Link to post Share on other sites
AUTOFREAK 217 Posted November 27, 2017 naravno da smije.... samo deri.... Ja to dimmer-om tamanim Share this post Link to post Share on other sites
matecro007 0 Posted December 11, 2017 Meni se pojavljuju mjehurici na G4 , oso danas kod bošiste Kereš , kaze reparacija brtve tandem pumpe. 900kn. Evo videa https://www.mediafire.com/file/hojc74hba9ynno4/VID_20171211_104228.mp4 Share this post Link to post Share on other sites
<TDI> 416 Posted December 12, 2017 Zanimljivo, morat ću i ja pogledati kada motor radi da vidim ima li nešto slično, kontrole radi. Nova ali Bosch pumpa u Tokiću cca. 2500 kn pa sada ako ti se popravak isplati ili potraži još negdje. Share this post Link to post Share on other sites
Kamenarić 0 Posted December 12, 2017 Meni se pojavljuju mjehurici na G4 , oso danas kod bošiste Kereš , kaze reparacija brtve tandem pumpe. 900kn. Evo videa https://www.mediafire.com/file/hojc74hba9ynno4/VID_20171211_104228.mp4 Prosli tjedan reparirao ja na svojem u sesvetama kod svog mehanicara 700 kuna platio Bosch Preden servis je trazio 1000 kuna Share this post Link to post Share on other sites
<TDI> 416 Posted December 12, 2017 Znaš li točno što je sve rađeno na pumpi? Share this post Link to post Share on other sites
Kamenarić 0 Posted December 12, 2017 Zamijenjen je set za reparaturu -brtve, gumice i serafi. Nije mi toliko jako bila u banani kao na videu al je bila. Osjetim sad da mi auto mirnije i bolje radi Share this post Link to post Share on other sites
matecro007 0 Posted December 12, 2017 Prosli tjedan reparirao ja na svojem u sesvetama kod svog mehanicara 700 kuna platio Bosch Preden servis je trazio 1000 kuna Ja vecinom idem isto u sesvete kod tupeka. Rekli su da oni to nemogu napravit i poslali me kod tog Kereša. E sad nisam se raspitivo dal postoji nesto jeftinije al ak je za 200 kn jeftinije rade cu dat u ovlasteni bosch servis. Zvao sam i tokica za novu pumpu ,drugacija cifra nego kod kolege tdi, meni su rekli oko 2100 bosch pumpa. A meni treba luk. Al opet tolko para mi je previse dat. Share this post Link to post Share on other sites
projektilski 274 Posted December 13, 2017 Tupek? Hmm oni su mi prodali sat u boji od passata cc debelo ispod cijene jer nisu znali sto prodaju Share this post Link to post Share on other sites
<TDI> 416 Posted December 13, 2017 Mislim da Tokic samo Bosch drzi a LUK mozda preko ovlastenog, samo onda za cifru ne pitaj. Ne znam kakva je Bosch pumpa u praksi ali pipac im je bolje fiksiran nego kod LUK-a. Share this post Link to post Share on other sites
AUTOFREAK 217 Posted December 13, 2017 U nas na jugu bosh bio 1800kn. Puks je ima za toliko novu. Set za rep neznaci da ce dugo trajat nakon. Ako je iznutra poderana i iskrivljena djaba rep set. Mex da je odika bi vam sve napisao.. Share this post Link to post Share on other sites
